COOLING FANS
08-22-2006, 02:45
COOLING FANS
Questions concerning cooling fans on 1995 BMC 37'
1) should both electric fans for the transmission cooler come on at
the same time ? I found that at 200 degrees only 1 was active
2) at what temperature should the hydraulic fan for the radiator come
on ? I found that at 185 degrees it was not active. there also appears
to be some hydraulic fluid residue around the shaft area although no
signs of an active leak.
3)is there a selenoid that turns on the hydraulic fan ?
Donald Brown
1995 BMC 37'
Palmetto Florida
