Battery setup
06-30-2005, 04:40
Battery setup
Mark,
On my 1986 38' PT, the batteries were originally set up so that all 6 of the 6v golf cart batteries were all tied together into a 12 v system. I changed my system slightly, and installed a marine Perko battery selector switch, whi ch has a big rotary dial to select battery banks "1", "2", "All" and "off". I dedicated four of the batteries as house batteries (Bank 1), and two for engine starting (Bank 2). I leave the switch to "All" when driving, and while hooked up to shore power (110v). When dry camping, I select just the Bank 1 batteries, so I won't draw down the engine starting batteries. If you plan on storing your BB for an extended time, and when no 110v shore power is available, I turn the Perko switch to "off", and it disconnects the batteries completely. You will lose your stored radio stations, the refrigerator will be off, and you'll lose your clock readouts until you turn the switch back on. This works fine for me, because I'm always paranoid of losing all batt power when dry camping and being unable to start the bus. This gives me a little more peace of mind. The Aux Batt switch simply temporarily connects your generator starting battery (via a solenoid behind the front step) to your coach's 12v battery system, so you can use the genset batt to assist in starting the coach's engine. It works the other way also...if your genset batt is so low that it won't start the genset, holding down the Aux Batt switch will allow you to use the coach's batts to spin the genset starter (assuming there's enough juice to energize the solenoid). Other's have installed much more elaborate battery/12v systems, using "combiners", "isolators", etc, but my system works fine for me. By the way, you'll have to make up new battery cables to install the Perko switch. I put my switch in the battery compartment. I used heavy welding cables and a "hit it with a hammer" lug crimper and soldered them just to be sure before adding the heat shrink to the lugs. Hope this helps...sorry for the long response. Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
06-30-2005, 08:16
Battery setup
Have the original setup in my 88 BB, so I have six batteries all tied
together. Are there two that usually just start the coach? And how does the auxilliary battery switch work? Where does it draw power from to start the coach when the other batteries won't? I think I have one bad battery and it's drawing power down from the others. Mark 88 PT40 San Diego 75 & sunny |
06-30-2005, 12:55
Battery setup
Mark,
Where in San Diego? Were you driving down Pomerado towing a boat last Friday or the one before? As far as the auxiliary battery, BB separates the house from chassis batteries. If you run down the start batteries for the engine, you can use the au. switch to tap the house batteries for starting power. Be careful not to use it all the time or you will just run down all batteries. Tom McCarthy Poway, CA 95 PT42 --- In WanderlodgeForum@yahoogroups.com, "soxmark2000" <MDahlAssc@a...> wrote: > Have the original setup in my 88 BB, so I have six batteries all tied > together. Are there two that usually just start the coach? And how > does the auxilliary battery switch work? Where does it draw power from > to start the coach when the other batteries won't? I think I have one > bad battery and it's drawing power down from the others. > > Mark > 88 PT40 > San Diego > 75 & sunny |
