Back Up Camera
08-25-2006, 12:11
Back Up Camera
Hi,
I need to replace my Sanyo VDC 2512 black/white back up camera. I have done a web search and can't find that exact model number. Can anyone tell me where I can find a Sanyo replacement or recommend another comparable camera? I don't have time to be modifying the box where the camera sits, so I need something that will mount like the Sanyo. Any help will be greatly appreciated. Randy Merrill 1993 WLWB Ocala, Florida |
08-25-2006, 12:19
Back Up Camera
Randy
Go to http://rvcams.com/ call Tim he might even be there yet tonight, he works long hours. He did a great job for me. Steve Quandt 1993-PT40 Iron Mountain, Mi -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Randy Merrill Sent: Friday, August 25, 2006 7:11 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Back Up Camera Hi, I need to replace my Sanyo VDC 2512 black/white back up camera. I have done a web search and can't find that exact model number. Can anyone tell me where I can find a Sanyo replacement or recommend another comparable camera? I don't have time to be modifying the box where the camera sits, so I need something that will mount like the Sanyo. Any help will be greatly appreciated. Randy Merrill 1993 WLWB Ocala, Florida [Non-text portions of this message have been removed] |
08-25-2006, 17:51
Back Up Camera
Hi Randy,
I have a B & W camera that I replaced with a Sony color setup. My monitor went bad and became intermittent. I have no idea what the camera is worth. (If I can still find it). I saved the camera & monitor because I've heard that someone on the forum fixes the monitors. Anyway, I'm not going to use either. Make an offer if interested in the camera. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Randy Merrill To: WanderlodgeForum@yahoogroups.com Sent: Friday, August 25, 2006 5:11 PM Subject: [WanderlodgeForum] Back Up Camera Hi, I need to replace my Sanyo VDC 2512 black/white back up camera. I have done a web search and can't find that exact model number. Can anyone tell me where I can find a Sanyo replacement or recommend another comparable camera? I don't have time to be modifying the box where the camera sits, so I need something that will mount like the Sanyo. Any help will be greatly appreciated. Randy Merrill 1993 WLWB Ocala, Florida [Non-text portions of this message have been removed] |
08-25-2006, 23:36
Back Up Camera
Randy,
Not knowing your problem Let me tell you about mine. My camera picture would flicker badly. I took it out took out the circuit board and checked the solder joints on the back. about 4 or 5 were cracked. I resoldered put camera back in and it works beautiful. I had afuzzy picture and I took the cover off of the camera there is a piece of 1/4 inch plexi glass in the cover it had crazed badly. I replaced it and now have a stable clear picture. Saved several hundred dollars to buy fuel with. Howard Truitt Camilla, Ga. 86 8V92 PT40 From: Randy Merrill To: WanderlodgeForum@yahoogroups.com Sent: Friday, August 25, 2006 8:11 PM Subject: [WanderlodgeForum] Back Up Camera Hi, I need to replace my Sanyo VDC 2512 black/white back up camera. I have done a web search and can't find that exact model number. Can anyone tell me where I can find a Sanyo replacement or recommend another comparable camera? I don't have time to be modifying the box where the camera sits, so I need something that will mount like the Sanyo. Any help will be greatly appreciated. Randy Merrill 1993 WLWB Ocala, Florida ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.405 / Virus Database: 268.11.5/425 - Release Date: 8/22/2006 [Non-text portions of this message have been removed] |
08-26-2006, 04:18
Back Up Camera
I concur with the recommendation of http://www.rvcams.com Tim helped me immensely.
For around $400 I put in a colour flat panel monitor and new rear camera. I used existing coaxial cable with a Radio Shack S/Coax adapter. I have pictures of dash install and rear camera install if interested. On 25/08/06, Randy Merrill > > Hi, > > I need to replace my Sanyo VDC 2512 black/white back up camera. I have > done a web search and can't find that exact model number. Can anyone > tell me where I can find a Sanyo replacement or recommend another > comparable camera? I don't have time to be modifying the box where the > camera sits, so I need something that will mount like the Sanyo. > > Any help will be greatly appreciated. > > Randy Merrill > 1993 WLWB > Ocala, Florida > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
08-26-2006, 06:01
Back Up Camera
Rob,COLOUR monitor are they 50 Hertz?
GregoryO'Connor 94pt NotFromNiceville --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > I concur with the recommendation of http://www.rvcams.com Tim helped me immensely. > For around $400 I put in a colour flat panel monitor and new rear camera. I > used existing coaxial cable with a Radio Shack S/Coax adapter. I have > pictures of dash install and rear camera install if interested. > > On 25/08/06, Randy Merrill > > > > Hi, > > > > I need to replace my Sanyo VDC 2512 black/white back up camera. I have > > done a web search and can't find that exact model number. Can anyone > > tell me where I can find a Sanyo replacement or recommend another > > comparable camera? I don't have time to be modifying the box where the > > camera sits, so I need something that will mount like the Sanyo. > > > > Any help will be greatly appreciated. > > > > Randy Merrill > > 1993 WLWB > > Ocala, Florida > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
08-26-2006, 06:46
Back Up Camera
Greg here are the specs for the particular system I bought......
*Complete Specs for 68-CHNV* *Camera Specs:* TV System NTSC Image Sensor Panasonic 1/4" CCD CCD Effective Pixels (NTSC)510(H) x 492(V) Resolution 380 TV lines Horizontal Sync Frequency EIA: 15.750 khz -- CCIR:15.625 khz Scanning System 2:1 Interlace Sensitivity 0 lux (IR On), with >30' IR Range SYNC System Internal Signal to Noise Ratio better than 48dB Electronic Shutter (NTSC)1/60-1/100,000 sec. Gamma Correction 0.45 Lens f 2.5 mm Video Output 1.0 Vp-p composite video at 75 ohm Backlight Compensation Automatic Gain Control AGC Power Supply DC 12V (+/-10%), 125 ma Weight 480 gr Storage Temperature -22°F to 140°F Operation Temperature 32°F to 122°F View Angle 130° diagonally -- 78°/104° Ver/Hor Construction Aluminum, with painted finish Dimensions 3.75"w x 3.20"h x 2.64 "d *Monitor Specs:* Display TFT Color LCD Exterior Dimensions (6.8) 6.77"W x 5.6"H x 1.25"D Display Dimensions 5-7/16" W x 4-1/8"H Number of Pixels 268,568 Screen Size 6.8" Diagonally LCD Display Dots 1152(H)x234(V) System Selectable NTSC or PAL Input Signal 1.0 V p-p Composite at 75 ohms Power Source DC 12V Operation Temperature 23 °F to 122 °F Storage Temperature -13 °F to 158 °F Power Consumption 6 watts max Weight 1.05 lbs Inputs 2 audio/video On 26/08/06, Gregory OConnor > > Rob,COLOUR monitor are they 50 Hertz? > GregoryO'Connor > 94pt > NotFromNiceville > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > > I concur with the recommendation of http://www.rvcams.com Tim helped me > immensely. > > For around $400 I put in a colour flat panel monitor and new rear > camera. I > > used existing coaxial cable with a Radio Shack S/Coax adapter. I > have > > pictures of dash install and rear camera install if interested. > > > > On 25/08/06, Randy Merrill > > > > > > Hi, > > > > > > I need to replace my Sanyo VDC 2512 black/white back up camera. I > have > > > done a web search and can't find that exact model number. Can > anyone > > > tell me where I can find a Sanyo replacement or recommend another > > > comparable camera? I don't have time to be modifying the box > where the > > > camera sits, so I need something that will mount like the Sanyo. > > > > > > Any help will be greatly appreciated. > > > > > > Randy Merrill > > > 1993 WLWB > > > Ocala, Florida > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
08-27-2006, 05:38
Back Up Camera
Rob, is it worth an upgrade from the factory B&W system? and is there
a way to get intercom to enhance voice contact with lookout 'ComeOnBack' person? When I back up my Dumptruck and trailer I get out and take a walk around then I place a mini cone next to landmarks. Never do I hit a thing, no camera, life is stressfree and easy. However backing up the bus is very stressful as the copilot says "I'll look" and my walk around review would spark a 'you have no trust debate'. Who wants to start a trip this way. As I back up I hear "a little to the right". My question is "my right or your right" Then I hear "we are facing the same way what do you think". I respond "I shouldn't be thinking, you are directing me, just point, damit" Then I see clearly in the monitor a single digit reply. This is the only time I can see a command as every other time he is in view of a mirror or the camera and only an arm in one and a torso in the other. Then a new sign language, hands to the side, what's that mean? As he starts to push on the bumper I realize the Umpire SAFE sign L is equivalent to Bus driver STOP sign L. Then the walk to the drivers window. The pace is reminiscent of an Umpite walk to the mound, does the repeated over exaggerated 'He's safe motion' evoke a Baseball authority ambition in someone? As he approaches I adjust my cup and wait for his first pitch. The co pilot says "when I do this ( he motions safe)it means stop". I hold my arms out forward, thumbs side by side, palms facing him and say "I thought this meant stop". He replies "that means, Ouh - hay - Beep -Beep, are you wearing double knit polyester or something". I reply "What?, are you Donna Sommers now?, this aint a Prevost, no Discoball hanging in the galley". I then jump out of my seat, take a walk around, place some landmark indicators and back the bus in safe. I often wondered if the nightstand placed rear and center was a selling feature in the classic FC's, prompted by backup /setup anxiety. GregoryO'Connor 94ptRomolandCA --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Greg here are the specs for the particular system I bought...... > > > > *Complete Specs for 68-CHNV* > *Camera Specs:* TV System NTSC Image Sensor Panasonic 1/4" CCD CCD > Effective Pixels (NTSC)510(H) x 492(V) Resolution 380 TV lines Horizontal > Sync Frequency EIA: 15.750 khz -- CCIR:15.625 khz Scanning System 2:1 > Interlace Sensitivity 0 lux (IR On), with >30' IR Range SYNC System > Internal Signal > to Noise Ratio better than 48dB Electronic Shutter > (NTSC)1/60-1/100,000 sec. Gamma > Correction 0.45 Lens f 2.5 mm Video Output 1.0 Vp-p composite video at 75 > ohm Backlight Compensation Automatic Gain Control AGC Power Supply DC 12V > (+/-10%), 125 ma Weight 480 gr Storage Temperature -22°F to 140°F Operation > Temperature 32°F to 122°F View Angle 130° diagonally -- 78°/104° Ver/Hor > Construction Aluminum, with painted finish Dimensions 3.75"w x 3.20"h x 2.64 > "d *Monitor Specs:* Display TFT Color LCD Exterior Dimensions (6.8) 6.77"W > x 5.6"H x 1.25"D Display Dimensions 5-7/16" W x 4-1/8"H Number of Pixels > 268,568 Screen Size 6.8" Diagonally LCD Display Dots 1152(H)x234(V) > System Selectable > NTSC or PAL Input Signal 1.0 V p-p Composite at 75 ohms Power Source > DC 12V Operation > Temperature 23 °F to 122 °F Storage Temperature -13 °F to 158 °F Power > Consumption 6 watts max Weight 1.05 lbs Inputs 2 audio/video > > > On 26/08/06, Gregory OConnor > > > > Rob,COLOUR monitor are they 50 Hertz? > > GregoryO'Connor > > 94pt > > NotFromNiceville > > > > --- In WanderlodgeForum@yahoogroups.com > > "Rob Robinson" > > > > > > > > > > I concur with the recommendation of http://www.rvcams.com Tim helped me > > immensely. > > > For around $400 I put in a colour flat panel monitor and new rear > > camera. I > > > used existing coaxial cable with a Radio Shack S/Coax adapter. I > > have > > > pictures of dash install and rear camera install if interested. > > > > > > On 25/08/06, Randy Merrill > > > > > > > > Hi, > > > > > > > > I need to replace my Sanyo VDC 2512 black/white back up camera. I > > have > > > > done a web search and can't find that exact model number. Can > > anyone > > > > tell me where I can find a Sanyo replacement or recommend another > > > > comparable camera? I don't have time to be modifying the box > > where the > > > > camera sits, so I need something that will mount like the Sanyo. > > > > > > > > Any help will be greatly appreciated. > > > > > > > > Randy Merrill > > > > 1993 WLWB > > > > Ocala, Florida > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Rob, Sue & Merlin Robinson > > > 94 WLWB > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
08-27-2006, 05:59
Back Up Camera
Cheap walkie talkies, DON'T talk unless you KNOW I
am going to hit something. Bob Janes --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Rob, is it worth an upgrade from the factory B&W system? and is there > a way to get intercom to enhance voice contact with > lookout 'ComeOnBack' person? > > When I back up my Dumptruck and trailer I get out and take a walk > around then I place a mini cone next to landmarks. Never do I hit a > thing, no camera, life is stressfree and easy. However backing up > the bus is very stressful as the copilot says "I'll look" and my walk > around review would spark a 'you have no trust debate'. Who wants to > start a trip this way. > As I back up I hear "a little to the right". My question is "my > right or your right" Then I hear "we are facing the same way what do > you think". I respond "I shouldn't be thinking, you are directing > me, just point, damit" Then I see clearly in the monitor a single > digit reply. This is the only time I can see a command as every > other time he is in view of a mirror or the camera and only an arm > in one and a torso in the other. > > Then a new sign language, hands to the side, what's that mean? As > he starts to push on the bumper I realize the Umpire SAFE sign L is > equivalent to Bus driver STOP sign L. Then the walk to the drivers > window. The pace is reminiscent of an Umpite walk to the mound, does > the repeated over exaggerated 'He's safe motion' evoke a Baseball > authority ambition in someone? As he approaches I adjust my cup and > wait for his first pitch. The co pilot says "when I do this ( he > motions safe)it means stop". I hold my arms out forward, thumbs side > by side, palms facing him and say "I thought this meant stop". He > replies "that means, Ouh - hay - Beep -Beep, are you wearing double > knit polyester or something". I reply "What?, are you Donna Sommers > now?, this aint a Prevost, no Discoball hanging in the galley". I > then jump out of my seat, take a walk around, place some landmark > indicators and back the bus in safe. I often wondered if the > nightstand placed rear and center was a selling feature in the > classic FC's, prompted by backup /setup anxiety. > > GregoryO'Connor > 94ptRomolandCA > --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > > > > Greg here are the specs for the particular system I bought...... > > > > > > > > *Complete Specs for 68-CHNV* > > *Camera Specs:* TV System NTSC Image Sensor Panasonic 1/4" CCD > CCD > > Effective Pixels (NTSC)510(H) x 492(V) Resolution 380 TV lines > Horizontal > > Sync Frequency EIA: 15.750 khz -- CCIR:15.625 khz Scanning System > 2:1 > > Interlace Sensitivity 0 lux (IR On), with >30' IR Range SYNC System > > Internal Signal > > to Noise Ratio better than 48dB Electronic Shutter > > (NTSC)1/60-1/100,000 sec. Gamma > > Correction 0.45 Lens f 2.5 mm Video Output 1.0 Vp-p composite video > at 75 > > ohm Backlight Compensation Automatic Gain Control AGC Power Supply > DC 12V > > (+/-10%), 125 ma Weight 480 gr Storage Temperature -22°F to 140°F > Operation > > Temperature 32°F to 122°F View Angle 130° diagonally -- 78°/104° > Ver/Hor > > Construction Aluminum, with painted finish Dimensions 3.75"w x > 3.20"h x 2.64 > > "d *Monitor Specs:* Display TFT Color LCD Exterior Dimensions > (6.8) 6.77"W > > x 5.6"H x 1.25"D Display Dimensions 5-7/16" W x 4-1/8"H Number of > Pixels > > 268,568 Screen Size 6.8" Diagonally LCD Display Dots 1152(H)x234 (V) > > System Selectable > > NTSC or PAL Input Signal 1.0 V p-p Composite at 75 ohms Power Source > > DC 12V Operation > > Temperature 23 °F to 122 °F Storage Temperature -13 °F to 158 ° F > Power > > Consumption 6 watts max Weight 1.05 lbs Inputs 2 audio/video > > > > > > On 26/08/06, Gregory OConnor > > > > > > Rob,COLOUR monitor are they 50 Hertz? > > > GregoryO'Connor > > > 94pt > > > NotFromNiceville > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > "Rob Robinson" > > > > > > > > > > > > > > I concur with the recommendation of http://www.rvcams.com Tim helped me > > > immensely. > > > > For around $400 I put in a colour flat panel monitor and new > rear > > > camera. I > > > > used existing coaxial cable with a Radio Shack S/Coax adapter. I > > > have > > > > pictures of dash install and rear camera install if interested. > > > > > > > > On 25/08/06, Randy Merrill > > > > > > > > > > Hi, > > > > > > > > > > I need to replace my Sanyo VDC 2512 black/white back up > camera. I > > > have > > > > > done a web search and can't find that exact model number. Can > > > anyone > > > > > tell me where I can find a Sanyo replacement or recommend > another > > > > > comparable camera? I don't have time to be modifying the box > > > where the > > > > > camera sits, so I need something that will mount like the > Sanyo. > > > > > > > > > > Any help will be greatly appreciated. > > > > > > > > > > Randy Merrill > > > > > 1993 WLWB > > > > > Ocala, Florida > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Rob, Sue & Merlin Robinson > > > > 94 WLWB > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > |
08-27-2006, 06:07
Back Up Camera
Hi Greg. I rarely ever back up without someone behind me, especially in an
campground. There is always the chance a small child or pet will dart in behind. They seem to love the vacant campsite next door. I use my Backup Camera system to watch the toad. I rarely use it for backing info. Often Sue will notice something in the campsite that I miss (ie overhanging branches). My old b&w system died and since it was 11 years old I didn't want to frig with it. It has been my experience that jury-rigging-fixing something electronic that old is often an exercise in futility and expensive. I think b&w gives you better picture, especially at night but I opted for the colour camera. I've heard that colour shows up fire but b&w doesn't. A fire shows up like dust or grey smoke but the flames are not easily seen. That's not the reason I opted for colour. Colour is cool. I think your sign-language problem is beyond my help. You both need expert advice VBG. Kidnap the local 'flag person' and hold them ransom until they part with the secret hand motions for traffic control. On 27/08/06, Gregory OConnor > > Rob, is it worth an upgrade from the factory B&W system? and is there > a way to get intercom to enhance voice contact with > lookout 'ComeOnBack' person? > > When I back up my Dumptruck and trailer I get out and take a walk > around then I place a mini cone next to landmarks. Never do I hit a > thing, no camera, life is stressfree and easy. However backing up > the bus is very stressful as the copilot says "I'll look" and my walk > around review would spark a 'you have no trust debate'. Who wants to > start a trip this way. > As I back up I hear "a little to the right". My question is "my > right or your right" Then I hear "we are facing the same way what do > you think". I respond "I shouldn't be thinking, you are directing > me, just point, damit" Then I see clearly in the monitor a single > digit reply. This is the only time I can see a command as every > other time he is in view of a mirror or the camera and only an arm > in one and a torso in the other. > > Then a new sign language, hands to the side, what's that mean? As > he starts to push on the bumper I realize the Umpire SAFE sign L is > equivalent to Bus driver STOP sign L. Then the walk to the drivers > window. The pace is reminiscent of an Umpite walk to the mound, does > the repeated over exaggerated 'He's safe motion' evoke a Baseball > authority ambition in someone? As he approaches I adjust my cup and > wait for his first pitch. The co pilot says "when I do this ( he > motions safe)it means stop". I hold my arms out forward, thumbs side > by side, palms facing him and say "I thought this meant stop". He > replies "that means, Ouh - hay - Beep -Beep, are you wearing double > knit polyester or something". I reply "What?, are you Donna Sommers > now?, this aint a Prevost, no Discoball hanging in the galley". I > then jump out of my seat, take a walk around, place some landmark > indicators and back the bus in safe. I often wondered if the > nightstand placed rear and center was a selling feature in the > classic FC's, prompted by backup /setup anxiety. > > GregoryO'Connor > 94ptRomolandCA > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > Greg here are the specs for the particular system I bought...... > > > > > > > > *Complete Specs for 68-CHNV* > > *Camera Specs:* TV System NTSC Image Sensor Panasonic 1/4" CCD > CCD > > Effective Pixels (NTSC)510(H) x 492(V) Resolution 380 TV lines > Horizontal > > Sync Frequency EIA: 15.750 khz -- CCIR:15.625 khz Scanning System > 2:1 > > Interlace Sensitivity 0 lux (IR On), with >30' IR Range SYNC System > > Internal Signal > > to Noise Ratio better than 48dB Electronic Shutter > > (NTSC)1/60-1/100,000 sec. Gamma > > Correction 0.45 Lens f 2.5 mm Video Output 1.0 Vp-p composite video > at 75 > > ohm Backlight Compensation Automatic Gain Control AGC Power Supply > DC 12V > > (+/-10%), 125 ma Weight 480 gr Storage Temperature -22°F to 140°F > Operation > > Temperature 32°F to 122°F View Angle 130° diagonally -- 78°/104° > Ver/Hor > > Construction Aluminum, with painted finish Dimensions 3.75"w x > 3.20"h x 2.64 > > "d *Monitor Specs:* Display TFT Color LCD Exterior Dimensions > (6.8) 6.77"W > > x 5.6"H x 1.25"D Display Dimensions 5-7/16" W x 4-1/8"H Number of > Pixels > > 268,568 Screen Size 6.8" Diagonally LCD Display Dots 1152(H)x234(V) > > System Selectable > > NTSC or PAL Input Signal 1.0 V p-p Composite at 75 ohms Power Source > > DC 12V Operation > > Temperature 23 °F to 122 °F Storage Temperature -13 °F to 158 °F > Power > > Consumption 6 watts max Weight 1.05 lbs Inputs 2 audio/video > > > > > > On 26/08/06, Gregory OConnor > > > > > > Rob,COLOUR monitor are they 50 Hertz? > > > GregoryO'Connor > > > 94pt > > > NotFromNiceville > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > "Rob Robinson" > > > > > > > > > > > > > > I concur with the recommendation of http://www.rvcams.com Tim helped me > > > immensely. > > > > For around $400 I put in a colour flat panel monitor and new > rear > > > camera. I > > > > used existing coaxial cable with a Radio Shack S/Coax adapter. I > > > have > > > > pictures of dash install and rear camera install if interested. > > > > > > > > On 25/08/06, Randy Merrill > > > > > > > > > > Hi, > > > > > > > > > > I need to replace my Sanyo VDC 2512 black/white back up > camera. I > > > have > > > > > done a web search and can't find that exact model number. Can > > > anyone > > > > > tell me where I can find a Sanyo replacement or recommend > another > > > > > comparable camera? I don't have time to be modifying the box > > > where the > > > > > camera sits, so I need something that will mount like the > Sanyo. > > > > > > > > > > Any help will be greatly appreciated. > > > > > > > > > > Randy Merrill > > > > > 1993 WLWB > > > > > Ocala, Florida > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Rob, Sue & Merlin Robinson > > > > 94 WLWB > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
