ZF oil change
08-25-2006, 09:52
ZF oil change
Bruce I still use dextron 111 in mine. I haven't had any trouble with
heat. I guess I don't run too many hills. Last year when I was at a ZF shop
near Philly the Tech said my fluid look good. He said not to be afraid to use
the retarder. I only use 20 Quarts on a change. Not a big deal to do.
Don
89 SP 36'
Butler, PA
According to the ZF web site this will allow me to go 2 years and up to
75,000 km depending on the brand of oil. Transynd and ZF oil have the
longest change interval. I also noticed that with Dexron the interval
is every year. However I would think that the synthetic would handle
the heat from the "retarder" better than dino oil. Then I opened up my
Blue Box and it shows the capacity as 47 quarts!! I realize that not
all the oil will drain but that is still a lot of oil. Questions: Have
any of you changed to a synthetic? Does ZF have a special procedure for
this ( Allison does). Do you think it is worth the expense ( about
$5.00 a quart or more)? Any tips on changing the oil? BTW : For any
Amway, oops I mean Amsoil lovers, this oil is not on the approved list.
Bruce 1988 FC 35
08-25-2006, 13:31
ZF oil change
I am considering changing the oil in my ZF tranny to a synthetic.
Bruce 1988 FC 35
08-25-2006, 14:23
ZF oil change
One other question. Where can I get a filter for the ZF. They do not
show any centers in AZ which is closest to my location (Mexico). Web
site says it is about $25.00
Bruce 1988 FC35
08-26-2006, 03:10
ZF oil change
Hi Bruce,
In Oct 04, I changed to Transynd, I am not a big fan of synthetics.
Still use dino oil in the 3208 and rear axle.
But hoped that Transynd would tolerate the heat generated by the
retarder better. The procedure is in the ZF Blue Book, nothing
special, just pull the plug , drain, replace the filter and gasket.
In 2004 the Transynd was $35 per gallon & filter # 4139298038 was
$35.
The system holds about 8 Gallon, almost 5 gallon for a change.
I had no leaks and did not want to create any, so I did not drain
the cooler, this holds about another gallon.
Do not know what Transynd cost today (Expensive)
This is the, if it costs more, it must be better theory Wink
I use the retarder all the time , works great, I have no real
experience or data that ensures that this is a good decision.
The plan is to change it again and spend more $ to further dilute
the Dextron.
This is one of those piece of mind personal decisions for me.
We need to take care of the ZF, it is great and the retarder to even
better than great.
One must keep an eye on the temp gage. The retarder heats up the ZF
quickly,
Bill 88 FC Michigan
up to
interval
handle
up my
not
Have
procedure for
about
any
list.
> Bruce 1988 FC 35
