Toad wiring
08-26-2006, 13:56
Toad wiring
I have my SMI brake system installed, by Blue ox tow bar, my Blue Ox
tow bar base for my 1995 Jeep Cherokee Sport. Now to the wiring of the lights. It seems I have no choice but to use separate lights for the turn signals since the SMI will activate the normal brake light circuit in the toad, so I will not be able indicate a turn when the SMI is active. I believe I will also need to use diodes at the brake lights so the lights work with both the RV and the toad brake lighting without feeding back into either vehicle. Also, dumb question: Does the 78FC use the same lights for the brakes and turn signals? Mine is at the storage facility and I completely forgot to check this when I was there. Has anyone out there had experience with this and can you add any comments to what my observations. Thanks Gardner 78FC33 |
08-26-2006, 14:42
Toad wiring
Gardner,
You bring up a good point. I wondered about that too. I get around the potential issue by using a light bar. I made up a tail light bar that is inserted into the towed vehicle hitch receiver, and ran separate wiring from the coach to that light bar. With the SMI unit I'll have stacked brake lights at the rear of the toad...starting to look like Volvo tail lights on the later Birds... Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Gardner Yeaw wrote: > I have my SMI brake system installed, by Blue ox tow bar, my Blue Ox > tow bar base for my 1995 Jeep Cherokee Sport. Now to the wiring of > the lights. It seems I have no choice but to use separate lights for > the turn signals since the SMI will activate the normal brake light > circuit in the toad, so I will not be able indicate a turn when the > SMI is active. I believe I will also need to use diodes at the brake > lights so the lights work with both the RV and the toad brake > lighting without feeding back into either vehicle. > > Also, dumb question: Does the 78FC use the same lights for the > brakes and turn signals? Mine is at the storage facility and I > completely forgot to check this when I was there. > > Has anyone out there had experience with this and can you add any > comments to what my observations. > > Thanks > Gardner > 78FC33 > > |
08-26-2006, 15:10
Toad wiring
Curt,
That is one issue I was contemplating. If I have a light bar, and the toad brake lights are not in synch with the light bar, then it might get confusing for someone behind me. If I use diodes then the toad lights would be in synch with the RV and the confusion would be eliminated. However, I still need to deal with the turn signals. So it looks like a combination of separate turn signal lights and diode operated toad lights will be required. Gardner 78FC33 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Curt Sprenger Sent: Saturday, August 26, 2006 10:42 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Toad wiring Gardner, You bring up a good point. I wondered about that too. I get around the potential issue by using a light bar. I made up a tail light bar that is inserted into the towed vehicle hitch receiver, and ran separate wiring from the coach to that light bar. With the SMI unit I'll have stacked brake lights at the rear of the toad...starting to look like Volvo tail lights on the later Birds... Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Gardner Yeaw wrote: > I have my SMI brake system installed, by Blue ox tow bar, my Blue Ox > tow bar base for my 1995 Jeep Cherokee Sport. Now to the wiring of > the lights. It seems I have no choice but to use separate lights for > the turn signals since the SMI will activate the normal brake light > circuit in the toad, so I will not be able indicate a turn when the > SMI is active. I believe I will also need to use diodes at the brake > lights so the lights work with both the RV and the toad brake > lighting without feeding back into either vehicle. > > Also, dumb question: Does the 78FC use the same lights for the > brakes and turn signals? Mine is at the storage facility and I > completely forgot to check this when I was there. > > Has anyone out there had experience with this and can you add any > comments to what my observations. > > Thanks > Gardner > 78FC33 > > [Non-text portions of this message have been removed] |
08-26-2006, 15:23
Toad wiring
If you see light(s) ahead of you that go steady bright(er) red, that
means a slowing or braking vehicle. As long as the light bar lights are at the legal height it should not be a problem...my thinking...and less work for me. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Gardner Yeaw wrote: > Curt, > That is one issue I was contemplating. If I have a light bar, and the > toad brake lights are not in synch with the light bar, then it might get > confusing for someone behind me. If I use diodes then the toad lights > would > be in synch with the RV and the confusion would be eliminated. However, I > still need to deal with the turn signals. So it looks like a > combination of > separate turn signal lights and diode operated toad lights will be > required. > > Gardner > 78FC33 > > > > |
08-26-2006, 22:57
Toad wiring
The legal height for the light bar is? I am using magnetic mounted lights
on top of the Honda CRV presently for the same reason stated by Curt, less work. Steve Quandt 1993-PT40 Iron Mountain, MI _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger Sent: Saturday, August 26, 2006 10:23 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Toad wiring If you see light(s) ahead of you that go steady bright(er) red, that means a slowing or braking vehicle. As long as the light bar lights are at the legal height it should not be a problem...my thinking...and less work for me. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Gardner Yeaw wrote: > Curt, > That is one issue I was contemplating. If I have a light bar, and the > toad brake lights are not in synch with the light bar, then it might get > confusing for someone behind me. If I use diodes then the toad lights > would > be in synch with the RV and the confusion would be eliminated. However, I > still need to deal with the turn signals. So it looks like a > combination of > separate turn signal lights and diode operated toad lights will be > required. > > Gardner > 78FC33 > > > > [Non-text portions of this message have been removed] |
08-27-2006, 01:45
Toad wiring
Gardner, Curt,
We have a 2001 Jeep Cherokee. Found the Cherokee tail light/stop light wires and spliced in two DPDT switches, This method uses the existing Jeep lights and sockets. Switches are UP for Bird towing, DOWN for Jeep Driving. The Jeep tail lights are used for turn signals, hazards, and stop lights. No need for diodes, But I must remember to throw the manual switches. Easy to install. I do not know if this works with the SMI. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > I have my SMI brake system installed, by Blue ox tow bar, my Blue Ox > tow bar base for my 1995 Jeep Cherokee Sport. Now to the wiring of > the lights. It seems I have no choice but to use separate lights for > the turn signals since the SMI will activate the normal brake light > circuit in the toad, so I will not be able indicate a turn when the > SMI is active. I believe I will also need to use diodes at the brake > lights so the lights work with both the RV and the toad brake > lighting without feeding back into either vehicle. > > Also, dumb question: Does the 78FC use the same lights for the > brakes and turn signals? Mine is at the storage facility and I > completely forgot to check this when I was there. > > Has anyone out there had experience with this and can you add any > comments to what my observations. > > > Thanks > Gardner > 78FC33 > |
08-27-2006, 01:54
Toad wiring
I judge the minimum height for my light bar tail lights by where the
California trailer manufactures are placing tail lights. As long as I meet that minimum I should be fine. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. smquandt wrote: > The legal height for the light bar is? I am using magnetic mounted lights > on top of the Honda CRV presently for the same reason stated by Curt, less > work. > > Steve Quandt > > 1993-PT40 > > Iron Mountain, MI > > _____ > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com > > Sent: Saturday, August 26, 2006 10:23 PM > To: WanderlodgeForum@yahoogroups.com > > Subject: Re: [WanderlodgeForum] Toad wiring > > If you see light(s) ahead of you that go steady bright(er) red, that > means a slowing or braking vehicle. As long as the light bar lights are > at the legal height it should not be a problem...my thinking...and less > work for me. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > Gardner Yeaw wrote: > > > Curt, > > That is one issue I was contemplating. If I have a light bar, and the > > toad brake lights are not in synch with the light bar, then it might get > > confusing for someone behind me. If I use diodes then the toad lights > > would > > be in synch with the RV and the confusion would be eliminated. > However, I > > still need to deal with the turn signals. So it looks like a > > combination of > > separate turn signal lights and diode operated toad lights will be > > required. > > > > Gardner > > 78FC33 > > > > > > > > > > [Non-text portions of this message have been removed] > > |
08-27-2006, 01:57
Toad wiring
Bill,
I like what you have done. Should work with any dual wiring. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. pattypape wrote: > > > Gardner, Curt, > > We have a 2001 Jeep Cherokee. > Found the Cherokee tail light/stop light wires and > spliced in two DPDT switches, This method uses the existing Jeep > lights and sockets. Switches are UP for Bird towing, DOWN for Jeep > Driving. The Jeep tail lights are used for turn signals, hazards, > and stop lights. No need for diodes, But I must remember to throw > the manual switches. Easy to install. > I do not know if this works with the SMI. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > I have my SMI brake system installed, by Blue ox tow bar, my Blue > Ox > > tow bar base for my 1995 Jeep Cherokee Sport. Now to the wiring of > > the lights. It seems I have no choice but to use separate lights > for > > the turn signals since the SMI will activate the normal brake > light > > circuit in the toad, so I will not be able indicate a turn when > the > > SMI is active. I believe I will also need to use diodes at the > brake > > lights so the lights work with both the RV and the toad brake > > lighting without feeding back into either vehicle. > > > > Also, dumb question: Does the 78FC use the same lights for the > > brakes and turn signals? Mine is at the storage facility and I > > completely forgot to check this when I was there. > > > > Has anyone out there had experience with this and can you add > any > > comments to what my observations. > > > > > > Thanks > > Gardner > > 78FC33 > > > > |
08-27-2006, 02:21
Toad wiring
Curt,
Yes, this works for us, simple, No light bar, no diodes. Others have made holes into the tail light housings and installed an additional double filement 1157 bulb and socket. But there must be room in the housing. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Bill, > I like what you have done. Should work with any dual wiring. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > pattypape wrote: > > > > > > > Gardner, Curt, > > > > We have a 2001 Jeep Cherokee. > > Found the Cherokee tail light/stop light wires and > > spliced in two DPDT switches, This method uses the existing Jeep > > lights and sockets. Switches are UP for Bird towing, DOWN for Jeep > > Driving. The Jeep tail lights are used for turn signals, hazards, > > and stop lights. No need for diodes, But I must remember to throw > > the manual switches. Easy to install. > > I do not know if this works with the SMI. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > > > > > I have my SMI brake system installed, by Blue ox tow bar, my Blue > > Ox > > > tow bar base for my 1995 Jeep Cherokee Sport. Now to the wiring of > > > the lights. It seems I have no choice but to use separate lights > > for > > > the turn signals since the SMI will activate the normal brake > > light > > > circuit in the toad, so I will not be able indicate a turn when > > the > > > SMI is active. I believe I will also need to use diodes at the > > brake > > > lights so the lights work with both the RV and the toad brake > > > lighting without feeding back into either vehicle. > > > > > > Also, dumb question: Does the 78FC use the same lights for the > > > brakes and turn signals? Mine is at the storage facility and I > > > completely forgot to check this when I was there. > > > > > > Has anyone out there had experience with this and can you add > > any > > > comments to what my observations. > > > > > > > > > Thanks > > > Gardner > > > 78FC33 > > > > > > > > |
08-27-2006, 13:46
Toad wiring
Bill,
Iâm thinking that I could use relays instead of switches. That way when a signal from the coach arrived, it would activate the relay and route the 12 volts to the tail light/brake light. The coach signal would be connected to the relay coil and the normally open point of the relay. The toad light would be connected to the common point, and the toad signal to the normally closed point. So when the coach signal arrived it would energize the relay and light the bulb. When no coach signal was present, the toad signal would be connected by default. Gardner 78FC33 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of pattypape Sent: Sunday, August 27, 2006 9:45 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Toad wiring Gardner, Curt, We have a 2001 Jeep Cherokee. Found the Cherokee tail light/stop light wires and spliced in two DPDT switches, This method uses the existing Jeep lights and sockets. Switches are UP for Bird towing, DOWN for Jeep Driving. The Jeep tail lights are used for turn signals, hazards, and stop lights. No need for diodes, But I must remember to throw the manual switches. Easy to install. I do not know if this works with the SMI. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com wrote: > > I have my SMI brake system installed, by Blue ox tow bar, my Blue Ox > tow bar base for my 1995 Jeep Cherokee Sport. Now to the wiring of > the lights. It seems I have no choice but to use separate lights for > the turn signals since the SMI will activate the normal brake light > circuit in the toad, so I will not be able indicate a turn when the > SMI is active. I believe I will also need to use diodes at the brake > lights so the lights work with both the RV and the toad brake > lighting without feeding back into either vehicle. > > Also, dumb question: Does the 78FC use the same lights for the > brakes and turn signals? Mine is at the storage facility and I > completely forgot to check this when I was there. > > Has anyone out there had experience with this and can you add any > comments to what my observations. > > > Thanks > Gardner > 78FC33 > [Non-text portions of this message have been removed] |
