Por 15
08-26-2006, 22:55
Por 15
Leroy Have you ever sprayed Por 15 ? I have my fan off & all cleaned up
& was thinking about spraying it. I think it says you can. Raining today
hear.
Don
89 SP 36'
Butler, PA
08-27-2006, 03:29
Por 15
Don:
Yes sir I have many times. Take your time with two light coats and one finish
coat. I have even dipped small parts with excellent results. It works well
particularly if there is humidity. It flows out nicely. Good luck, let me know
how the parts turn out.
Leroy Eckert
1990 WB-40
Niceville, FL.
Sent: Sunday, August 27, 2006 9:55 AM
Subject: [WanderlodgeForum] Por 15
hear.
Don
89 SP 36'
Butler, PA
08-27-2006, 04:06
Por 15
Don, I have sprayed POR15. You need a reduced viscosity & a large tip
for your gun. Be sure that you clean your gun real good when you finish
or that will be the last time you use it. Use their prep coating on the
fan first for good adhesion. Be sure to wear gloves etc too (disposable
ones).
Terry Neal
Bozeman, MT
82PT40
74FC34
> hear.
> Don
> 89 SP 36'
> Butler, PA
08-27-2006, 07:00
Por 15
Leroy I guess that is why it flowed so well on the pipes that I hand
painted today. It is extra high humidity here in PA today.
Thanks Don
89 SP 36'
Butler, PA
Don
finish coat. I have even dipped small parts with excellent results. It works
well
know how the parts turn out.
Leroy Eckert
1990 WB-40
Niceville, FL.
08-27-2006, 08:16
Por 15
Great I didn't know you could use the cheap foam. I though they would maybe
melt down.
Don
89 SP 36'
Butler, PA
Hey Don:
Alright, happy to hear the parts look great. You can even use cheap foam
brushes and get a beautiful product. POR-15 loves moisture in the air.
Leroy
1990 WB-40
Niceville, FL
08-27-2006, 11:19
Por 15
Hey Don:
Leroy
1990 WB-40
Niceville, FL
Sent: Sunday, August 27, 2006 6:00 PM
Subject: Re: [WanderlodgeForum] Por 15
Thanks Don
89 SP 36'
Butler, PA
Don
well
Leroy Eckert
1990 WB-40
Niceville, FL.
