Radiator repair
08-27-2006, 11:24
Radiator repair
Gardner When I took my 79 FC rad off to get the neck soldered at a rad
shop he looked inside & said the inside was corroied & needed to be recored. I
would have a shop look at it to see if it needed to recored. That is
important have a good clean rad. I thought that is all I needed was some solder
to.
Don
89 SP 36'
Butler, PA
I discovered a small crack in my radiator where the filler neck
attaches to the radiator. I am thinking that I can clean this area
well and use silver solder to seal it up. Has anyone tried this remedy
and can you enlighten me as to yout methods and results?
Gardner
78FC33
08-27-2006, 14:23
Radiator repair
Gardner
78FC33
08-28-2006, 04:22
Radiator repair
It depends entirely on what the materials used in the filler neck
are... if brass or copper alloy, brazing with a similar alloy might
be a better choice.
aeonix1@...
'95 Bluebird Wanderlodge WBDA 4203
El Sobrante, CA
> Gardner
> 78FC33
08-28-2006, 04:44
Radiator repair
All radiator shops use a acid flux and low temp solder to make
repairs on radiators. Its not necessary to repair them with brass etc
since it gets the metal hotter and can work harden it.
tom warner
1985 PT 40
>be a better choice.
>Pete Masterson
>aeonix1@...
>El Sobrante, CA
> > Gardner
> > 78FC33
>Yahoo! Groups Links
08-28-2006, 06:10
Radiator repair
remedy
> Gardner
> 78FC33
Had same problem with 1985fc. Repaired at Kinch's in Escondido Ca.Acid
flux and low temp solder.$75.Just drove 1000 miles looks great. Mario
1985FC35 in Seaside OR.
08-28-2006, 07:04
Radiator repair
Hi Gardner,
I repaired the same area several years ago with a high quality epoxy
after cleaning it and roughing it up a little with a wire brush . I'm
sure soldering is the best solution, but if you don't have the tools
or the time, the epoxy has done the job very well.
Regards, Eric
84FC35SBWL2
> Gardner
> 78FC33
08-28-2006, 12:18
Radiator repair
Tom,
I am not sure what 'low temp' solder is. Is that a softer silver solder?
Gardner
78FC33
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Tom Warner
Sent: Monday, August 28, 2006 12:44 PM
Subject: Re: [WanderlodgeForum] Radiator repair
tom warner
1985 PT 40
>be a better choice.
>Pete Masterson
> aeonix1@...
>El Sobrante, CA
> > Gardner
> > 78FC33
>Yahoo! Groups Links
08-28-2006, 12:37
Radiator repair
Tom,
Is normal lead free plumbing solder suitable. I have done tons of
plumbing sweat connections. I use the acetylene/propane gas which
great for plumbing.
--- In WanderlodgeForum@yahoogroups.com, Gardner Yeaw
> Tom,
silver solder?
> Gardner
> 78FC33
etc
> tom warner
> 1985 PT 40
might
> >be a better choice.
> >Pete Masterson
> > aeonix1@...
> >El Sobrante, CA
area
this remedy
> > > Gardner
> > > 78FC33
> >Yahoo! Groups Links
08-28-2006, 14:32
Radiator repair
Gardner:
I took out my radiator and took it to a pro. My local radiator shop
pressure tested it, cleaned it out-- which he found and repaired a
couple of small leaks, and also soidered the filler neck. No more
leaks, and looks like new! Saved $1100..... for now.... As you may
know.. be sure if you do get it pressure tested, to be careful and
make sure they DO NOT exceed your rad cap pressure-- or you will have
many NEW leaks!
Stephen H
81 FC-33SB
Plant City, FL
------Original Message-------------
> remedy> and can you enlighten me as to yout methods and results?
> > Gardner
> > 78FC33
08-29-2006, 01:19
Radiator repair
Sage advice, they flow test as well.
Bob Janes
--- In WanderlodgeForum@yahoogroups.com, share@... wrote:
> Gardner:
have
> many NEW leaks!
> Stephen H
> 81 FC-33SB
> Plant City, FL
area
> > > Gardner
> > > 78FC33
