AC cooling, how much?
08-28-2006, 13:44
Two roof airs, ambient coach temperature 73*,
Temperature at AC out 54*, 19* difference. An A/C man told me if you have a 20* difference (house)that's about as good as it gets. Same for coach roof airs? If I could hang meat I can handle it. Bob Janes '87FC35 Greenville, SC |
08-28-2006, 14:13
The 20 F Delta T is right.
Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:44 AM 8/29/2006 +0000, you wrote: >Two roof airs, ambient coach temperature 73*, >Temperature at AC out 54*, 19* difference. >An A/C man told me if you have a 20* difference >(house)that's about as good as it gets. > >Same for coach roof airs? > >If I could hang meat I can handle it. >Bob Janes '87FC35 Greenville, SC > > |
08-29-2006, 09:20
--- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot"
> > Two roof airs, ambient coach temperature 73*, > Temperature at AC out 54*, 19* difference. > An A/C man told me if you have a 20* difference > (house)that's about as good as it gets. > > Same for coach roof airs? > > If I could hang meat I can handle it. > Bob Janes '87FC35 Greenville, SC > Howdy, Bob. We have been in Fort Worth, TX for about 3.5 weeks. And it had been in the triple digits outside for 16 days straight. I tried keeping our coach comfortable at around 74 degrees by using two of the three roof airs. Nope, when the outside temp reached 100+ degrees, the temp inside of our coach was 80 - 82. So, we ran all three roof airs and THEN we could keep the inside at 74 degrees. Just our two cents' worth. Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Currently in Fort Worth, TX |
08-29-2006, 10:15
Jack and Liz,
Bob was stating the ambient temperature inside the coach not outside temp. I certainly understand trying to keep the inside comfortable with 100+ temp outside. We have our RV parked in the front yard at my mother-in-laws in East Tx about 60 miles of Dallas. She has been ill and we are trying to help. I only have 30A service to the RV so I am limited to one A/C unit. These 100+ degrees days are hard to keep the inside below 80. I have made some sun shades for the inside of the front windshield in the last month and they have really helped. The RV is facing south so the sun in always on the front windshield. I bought some corrugated plastic, cut it to size, glued aluminum clad sun blocker on it, and taped the outside edges with the good aluminum tape that A/C installers use. Dropped the inside temp by 5 degrees. I plan on adding some more to the bedroom windows. Helps the drapes from fading also. Good luck, Jimmy -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Jack and Liz Pearce Sent: Tuesday, August 29, 2006 4:20 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: AC cooling, how much? --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Two roof airs, ambient coach temperature 73*, > Temperature at AC out 54*, 19* difference. > An A/C man told me if you have a 20* difference > (house)that's about as good as it gets. > > Same for coach roof airs? > > If I could hang meat I can handle it. > Bob Janes '87FC35 Greenville, SC > Howdy, Bob. We have been in Fort Worth, TX for about 3.5 weeks. And it had been in the triple digits outside for 16 days straight. I tried keeping our coach comfortable at around 74 degrees by using two of the three roof airs. Nope, when the outside temp reached 100+ degrees, the temp inside of our coach was 80 - 82. So, we ran all three roof airs and THEN we could keep the inside at 74 degrees. Just our two cents' worth. Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Currently in Fort Worth, TX [Non-text portions of this message have been removed] |
