minor problems 91 PT
09-04-2006, 10:24
I have a few items that are a constant pain. 1)tire valve stems keep
leaking ,I have replaced them , an in about 30 days when you check the air pressure it will keep leaking.2) My fauset in the kitchen keep leaking ,I checked the o-ring, it looks good.it now sprays out all over.3)My ice maker now will not drop the ice on regular intervals.The wire gaurd will remain in the up position when you push it down it will drop ice.if any one can give me any advice that would be great. Dave 91 WLWB 40 |
09-04-2006, 11:11
You have to be careful when either letting a tire shop replace your
valve stems or buying them yourself. There is a big difference in quality today with many of them made in china. I had a bad one and it turned out it was a chinese stem and had a cheap rubber grommet. Got all new ones from Prier tire http://www.priertiresupply.com/ very nice chrome plated ones for aluminum truck wheels $3.29 each (TR 509S) about $3.00 cheaper then chinese ones locally. I bought enough for all my tires and a few spares to carry with me. They come with valve cores and a nice chrome plated steel cap with oring. tom warner Vernon Center,NY 1985 PT 40 At 06:24 PM 9/4/2006, you wrote: >I have a few items that are a constant pain. 1)tire valve stems keep >leaking ,I have replaced them , an in about 30 days when you check the >air pressure it will keep leaking.2) My fauset in the kitchen keep >leaking ,I checked the o-ring, it looks good.it now sprays out all >over.3)My ice maker now will not drop the ice on regular intervals.The >wire gaurd will remain in the up position when you push it down it >will drop ice.if any one can give me any advice that would be great. >Dave 91 WLWB 40 > |
09-05-2006, 07:16
Will these work with any brand balancing beads in the tires?
Troy Tikalsky Waconia, MN 1986 Newell ----- Original Message ----- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 04, 2006 6:11 PM Subject: Re: [WanderlodgeForum] minor problems 91 PT You have to be careful when either letting a tire shop replace your valve stems or buying them yourself. There is a big difference in quality today with many of them made in china. I had a bad one and it turned out it was a chinese stem and had a cheap rubber grommet. Got all new ones from Prier tire http://www.priertiresupply.com/ very nice chrome plated ones for aluminum truck wheels $3.29 each (TR 509S) about $3.00 cheaper then chinese ones locally. I bought enough for all my tires and a few spares to carry with me. They come with valve cores and a nice chrome plated steel cap with oring. tom warner Vernon Center,NY 1985 PT 40 At 06:24 PM 9/4/2006, you wrote: >I have a few items that are a constant pain. 1)tire valve stems keep >leaking ,I have replaced them , an in about 30 days when you check the >air pressure it will keep leaking.2) My fauset in the kitchen keep >leaking ,I checked the o-ring, it looks good.it now sprays out all >over.3)My ice maker now will not drop the ice on regular intervals.The >wire gaurd will remain in the up position when you push it down it >will drop ice.if any one can give me any advice that would be great. >Dave 91 WLWB 40 > [Non-text portions of this message have been removed] |
