air leak left front
09-04-2006, 10:56
air leak left front
I've got an air leak in the left front, up high kind of behind the left
headlight. Any ideas what it might be? Are any air lines accessible by opening up the headlight door? Saturday it was leaking periodically when the coach was aired up, now it seems to be leaking all the time. I can get the pitch to change by wiggling the big bunch of wires and hoses up behind the bumper but the leak is higher than can be accessed from underneath. Advice? Kerry 82 FC 35 Denver |
09-04-2006, 11:59
air leak left front
Kerry,
Open up the front panel. Yours may be the same or similar to our '87 PT. Behind that panel I found Clippard air/12V controls leaking air as well as the manifolds they are screwed into. I changed out the Clippard controls for new ones, tightened up the leaking manifold plugs and all is good. Could be all that's needed is to cut off a quarter inch of the leaking black small diameter tube(s) and re-insert them. Do you have the air system schematic(s) for your Bird? Call Bennie at Blue Bird and request them. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. davidkerryedwards wrote: > I've got an air leak in the left front, up high kind of behind the > left headlight. Any ideas what > it might be? Are any air lines accessible by opening up the headlight > door? Saturday it was > leaking periodically when the coach was aired up, now it seems to be > leaking all the time. I > can get the pitch to change by wiggling the big bunch of wires and > hoses up behind the > bumper but the leak is higher than can be accessed from underneath. > Advice? > > Kerry > 82 FC 35 > Denver > > |
09-05-2006, 03:01
air leak left front
> > I've got an air leak in the left front, up high kind of behind the left headlight. Any ideas what > it might be? Are any air lines accessible by opening up the headlight door? Saturday it was > leaking periodically when the coach was aired up, now it seems to be leaking all the time. I > can get the pitch to change by wiggling the big bunch of wires and hoses up behind the > bumper but the leak is higher than can be accessed from underneath. Advice? > > Kerry > 82 FC 35 > Denver > It sounds like your vacum generator is leaking. Look for a small round aluminium object in the air line. It uses air to create a vacum( ventrui method) for the crusie control. If the vacum is leaking off the unit will need to operate more often. Jim 82 FC Calif |
09-05-2006, 03:25
air leak left front
It is a vacuum leak off the cruise control canister on the engine. Check
to make sure the tube did not come off. Larry 82fc35 Austin bluebird3208 wrote: > > --- In WanderlodgeForum@yahoogroups.com > > > > > > I've got an air leak in the left front, up high kind of behind the > left headlight. Any ideas what > > it might be? Are any air lines accessible by opening up the > headlight door? Saturday it was > > leaking periodically when the coach was aired up, now it seems to be > leaking all the time. I > > can get the pitch to change by wiggling the big bunch of wires and > hoses up behind the > > bumper but the leak is higher than can be accessed from underneath. > Advice? > > > > Kerry > > 82 FC 35 > > Denver > > > It sounds like your vacum generator is leaking. Look for a small > round aluminium object in the air line. It uses air to create a vacum( > ventrui method) for the crusie control. If the vacum is leaking off > the unit will need to operate more often. > > Jim > 82 FC > Calif > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.405 / Virus Database: 268.11.7/434 - Release Date: 8/30/2006 > |
