QUESTION ON VIN #'S
09-08-2006, 06:37
QUESTION ON VIN #'S
I am trying to title my 81fc35 in Florida and am being told by the DMV
down here that it does not have the right Vin# on the Title. I remember
conversations in the past that the older birds do not have the 16 digit
numbers. My Michigan title show a letter and 5 digits. Can anyone shed
some light on this and also if there is some documentation to verify this
that can be given to the Florida DMV would be great
Chuck Somers
269-929-3044
81FC35SB
cfsomers@...
09-08-2006, 06:44
QUESTION ON VIN #'S
Chuck my '81 did have a VIV # but was not being used when I bought the coach.
It can be found over the driver's head under the inside overhang attached to the
sheet metal above the driver's sun visor. It is hard to read especially from
the outside. If possible, I would get a digital camera picture of it so you
will have a record.
Sent: Friday, September 08, 2006 11:37 AM
Subject: [WanderlodgeForum] QUESTION ON VIN #'S
Chuck Somers
269-929-3044
81FC35SB
cfsomers@...
09-08-2006, 06:49
QUESTION ON VIN #'S
Chuck Somers
269-929-3044
81FC35SB
cfsomers@...
09-08-2006, 07:17
QUESTION ON VIN #'S
The DMV clerk is probable young enough to have never heard of anything
less than a 17 digit VIN#. Ask the clerk to take it to a higher
authority within the DMV. I experienced the same thing registering our
1974 Bird, and it was already registered in the same state...clerk had
to be informed by a higher (older) authority. Good luck.
Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif.
> Chuck Somers
> 269-929-3044
> 81FC35SB
> cfsomers@...
09-08-2006, 10:53
QUESTION ON VIN #'S
My 81 FC-33 is titled in Florida and has the 5-digit VIN on the
registration so it isn't a Florida DMV thing, its a local clerk
issue.
Have them pull up my tag, J96CFX, and they can see for themselves.
Good luck,
Tim Hannink
Fulltiming in Paradis, LA
1981 FC-33SB
DMV
remember
digit
shed
verify this
> Chuck Somers
> 269-929-3044
> 81FC35SB
> cfsomers@...
09-08-2006, 12:59
QUESTION ON VIN #'S
If you have a letter and 5 numbers its the BB body number not the
VIN! If you have just 5 numbers its the Chassis serial #. The BB VIN
should be in the form of 1BBXXXXXXXXX etc.
Tom Warner
Vernon Center,NY
1985 PT 40
>issue.
>Good luck,
>Tim Hannink
>1981 FC-33SB
>DMV
>remember
>digit
>shed
>verify this
> > Chuck Somers
> > 269-929-3044
> > 81FC35SB
> > cfsomers@...
>Yahoo! Groups Links
09-08-2006, 13:56
QUESTION ON VIN #'S
Tom, on my '77 the VIN# IS the chassis number, mine is 11100.This is
on title, registration, and insurance. SC accepted this, FL should
too.
Kind of like the Model "A" Ford, 1928-31, the VIN# is the number
of the motor block and chassis number stamped on the frame at the
front fender. If motor was swapped the title remained the same????
Bob Janes, Greenville, SC
VIN
> Tom Warner
> Vernon Center,NY
> 1985 PT 40
> >issue.
> >Good luck,
> >Tim Hannink
> >1981 FC-33SB
> >DMV
> >remember
16
> >digit
anyone
> >shed
> >verify this
> > > Chuck Somers
> > > 269-929-3044
> > > 81FC35SB
> > > cfsomers@
> >Yahoo! Groups Links
09-08-2006, 18:20
QUESTION ON VIN #'S
your bird was built before the long number requirement came into effect
I would suggest you talk to the clerks supervisor
not all the bluebird vins start with 1bb
before the long number requirement set by law some of the numbers were
only 5 digits long went on production number
sorry tom
Stephen 77fc35 with only 5 numbers in vin
> Tom Warner
> Vernon Center,NY
> 1985 PT 40
> >issue.
> >Good luck,
> >Tim Hannink
> >1981 FC-33SB
> >DMV
> >remember
> >digit
> >shed
> >verify this
> > > Chuck Somers
> > > 269-929-3044
> > > 81FC35SB
> > > cfsomers@
> >Yahoo! Groups Links
