air leak/vacuum generator leak
09-08-2006, 06:54
I investiagted my air leak a little more. It does appear to be the
vacuum generator mounted on the bottom of an air manifold behind the bumper. Air is coming out of the one of the fittings that has never had a hose on it. When I plug that fitting, the air must backfeed thru the cruise control vacuum system because it blows the hose off the vacuum canister on the engine. Do I need to replace the vacuum generator (if that is what it is)? If so, where would I purchase a replacement? Kerry Edwards 82 FC 35 Denver |
09-08-2006, 09:33
Kerry,
My 81 does the same thing. After shutting off the engine, it will make a air leak sound for a little while, that changes when the lines are moved. It has been awhile since I have looked at it, but if memory serves- I have the same device, with a leaking sound coming from a empty port as well. I will be monitoring this post for a repair and or replacement for the device. Let me Stephen H 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Friday, September 08, 2006 2:55 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] air leak/vacuum generator leak I investiagted my air leak a little more. It does appear to be the vacuum generator mounted on the bottom of an air manifold behind the bumper. Air is coming out of the one of the fittings that has never had a hose on it. When I plug that fitting, the air must backfeed thru the cruise control vacuum system because it blows the hose off the vacuum canister on the engine. Do I need to replace the vacuum generator (if that is what it is)? If so, where would I purchase a replacement? Kerry Edwards 82 FC 35 Denver [Non-text portions of this message have been removed] |
09-08-2006, 10:12
I think someone wrote earlier that the device will 'leak' if there is
a vacuum leak in the cruise control system. This makes sense. My next test will be to remove the input vacuum line from the cruise control, plug it and see if it stops the air leak. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...> wrote: > > Kerry, > > > > My 81 does the same thing. After shutting off the engine, it will make a air > leak sound for a little while, that changes when the lines are moved. It has > been awhile since I have looked at it, but if memory serves- I have the same > device, with a leaking sound coming from a empty port as well. I will be > monitoring this post for a repair and or replacement for the device. Let me > > > > > Stephen H > > 81 FC-33SB > > Plant City, FL > > > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards > Sent: Friday, September 08, 2006 2:55 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] air leak/vacuum generator leak > > > > I investiagted my air leak a little more. It does appear to be the > vacuum generator mounted on the bottom of an air manifold behind the > bumper. Air is coming out of the one of the fittings that has never > had a hose on it. When I plug that fitting, the air must backfeed > thru the cruise control vacuum system because it blows the hose off > the vacuum canister on the engine. Do I need to replace the vacuum > generator (if that is what it is)? If so, where would I purchase a > replacement? > > Kerry Edwards > 82 FC 35 > Denver > > > > > > [Non-text portions of this message have been removed] > |
09-08-2006, 14:23
I am new to all the details on the bluebirds, but my cruise stopped
working out of the blue going down the road. what is this vacumm generator and is it's sole purpose to run the cruise? Chuck S 81FC35SB Florida > I think someone wrote earlier that the device will 'leak' if there is > a vacuum leak in the cruise control system. This makes sense. My next > test will be to remove the input vacuum line from the cruise control, > plug it and see if it stops the air leak. > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...> wrote: >> >> Kerry, >> >> >> >> My 81 does the same thing. After shutting off the engine, it will > make a air >> leak sound for a little while, that changes when the lines are > moved. It has >> been awhile since I have looked at it, but if memory serves- I have > the same >> device, with a leaking sound coming from a empty port as well. I will be >> monitoring this post for a repair and or replacement for the device. > Let me >> >> >> >> >> Stephen H >> >> 81 FC-33SB >> >> Plant City, FL >> >> >> >> >> >> _____ >> >> From: WanderlodgeForum@yahoogroups.com >> [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards >> Sent: Friday, September 08, 2006 2:55 PM >> To: WanderlodgeForum@yahoogroups.com >> Subject: [WanderlodgeForum] air leak/vacuum generator leak >> >> >> >> I investiagted my air leak a little more. It does appear to be the >> vacuum generator mounted on the bottom of an air manifold behind the >> bumper. Air is coming out of the one of the fittings that has never >> had a hose on it. When I plug that fitting, the air must backfeed >> thru the cruise control vacuum system because it blows the hose off >> the vacuum canister on the engine. Do I need to replace the vacuum >> generator (if that is what it is)? If so, where would I purchase a >> replacement? >> >> Kerry Edwards >> 82 FC 35 >> Denver >> >> >> >> >> >> [Non-text portions of this message have been removed] >> > > > > > > |
09-08-2006, 15:07
I had a similar air leak just after I purchased our '81 FC in 2000. AS
mentioned before, it was the cruise control vacuum generator. After replacing it all was well in that area. I tried capping the leaking port but, it just blew the cap off. That's when I knew I needed help. I was just starting out then and had a lot to learn, still do. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Stephen H To: WanderlodgeForum@yahoogroups.com Sent: Friday, September 08, 2006 2:33 PM Subject: RE: [WanderlodgeForum] air leak/vacuum generator leak Kerry, My 81 does the same thing. After shutting off the engine, it will make a air leak sound for a little while, that changes when the lines are moved. It has been awhile since I have looked at it, but if memory serves- I have the same device, with a leaking sound coming from a empty port as well. I will be monitoring this post for a repair and or replacement for the device. Let me Stephen H 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com Sent: Friday, September 08, 2006 2:55 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] air leak/vacuum generator leak I investiagted my air leak a little more. It does appear to be the vacuum generator mounted on the bottom of an air manifold behind the bumper. Air is coming out of the one of the fittings that has never had a hose on it. When I plug that fitting, the air must backfeed thru the cruise control vacuum system because it blows the hose off the vacuum canister on the engine. Do I need to replace the vacuum generator (if that is what it is)? If so, where would I purchase a replacement? Kerry Edwards 82 FC 35 Denver [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-08-2006, 15:14
Describe what the unit looks like, name(s), number(s), etc. Send me a
digital picture, 2, or 3. When I overhauled the jeep I wanted the cruise control to work. I recall someone in Texas that would rebuild the unit. I did not use his facility as I located a never used identical unit, free. Our previous 1974 Bird had a vacuum cruise control unit. It looked like the one on the Jeep. To get it to work I replaced ALL the vacuum lines, the bellows, removed the electrical connections, twisted the contact blades slightly (to tightened them in their sockets) and plugging them back in, unit worked perfect. If your unit has a constant vacuum leak, the unit my need the attention stated above, rebuilding, or replacing. Send me information. If the unit is what I'm thinking it is, I'll do my best to locate that outfit in Texas. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. cfsomers@... wrote: > I am new to all the details on the bluebirds, but my cruise stopped > working out of the blue going down the road. what is this vacumm generator > and is it's sole purpose to run the cruise? > > Chuck S > 81FC35SB > Florida > > > I think someone wrote earlier that the device will 'leak' if there is > > a vacuum leak in the cruise control system. This makes sense. My next > > test will be to remove the input vacuum line from the cruise control, > > plug it and see if it stops the air leak. > > > > Kerry > > 82 FC 35 > > Denver > > > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > >> > >> Kerry, > >> > >> > >> > >> My 81 does the same thing. After shutting off the engine, it will > > make a air > >> leak sound for a little while, that changes when the lines are > > moved. It has > >> been awhile since I have looked at it, but if memory serves- I have > > the same > >> device, with a leaking sound coming from a empty port as well. I > will be > >> monitoring this post for a repair and or replacement for the device. > > Let me > >> > >> > >> > >> > >> Stephen H > >> > >> 81 FC-33SB > >> > >> Plant City, FL > >> > >> > >> > >> > >> > >> _____ > >> > >> From: WanderlodgeForum@yahoogroups.com > > >> [mailto:WanderlodgeForum@yahoogroups.com > > davidkerryedwards > >> Sent: Friday, September 08, 2006 2:55 PM > >> To: WanderlodgeForum@yahoogroups.com > > >> Subject: [WanderlodgeForum] air leak/vacuum generator leak > >> > >> > >> > >> I investiagted my air leak a little more. It does appear to be the > >> vacuum generator mounted on the bottom of an air manifold behind the > >> bumper. Air is coming out of the one of the fittings that has never > >> had a hose on it. When I plug that fitting, the air must backfeed > >> thru the cruise control vacuum system because it blows the hose off > >> the vacuum canister on the engine. Do I need to replace the vacuum > >> generator (if that is what it is)? If so, where would I purchase a > >> replacement? > >> > >> Kerry Edwards > >> 82 FC 35 > >> Denver > >> > >> > >> > >> > >> > >> [Non-text portions of this message have been removed] > >> > > > > > > > > > > > > > > |
09-08-2006, 17:21
3-G Productions 2970 Blystone Ste 104 Dallas TX 75220 888/269-4084
Tom Warner Vernon Center,NY 1985 PT 40 At 11:14 PM 9/8/2006, you wrote: >Describe what the unit looks like, name(s), number(s), etc. Send me a >digital picture, 2, or 3. When I overhauled the jeep I wanted the cruise >control to work. I recall someone in Texas that would rebuild the unit. >I did not use his facility as I located a never used identical unit, free. > >Our previous 1974 Bird had a vacuum cruise control unit. It looked like >the one on the Jeep. To get it to work I replaced ALL the vacuum lines, >the bellows, removed the electrical connections, twisted the contact >blades slightly (to tightened them in their sockets) and plugging them >back in, unit worked perfect. > >If your unit has a constant vacuum leak, the unit my need the attention >stated above, rebuilding, or replacing. > >Send me information. If the unit is what I'm thinking it is, I'll do my >best to locate that outfit in Texas. > >Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > >cfsomers@... wrote: > > > I am new to all the details on the bluebirds, but my cruise stopped > > working out of the blue going down the road. what is this vacumm generator > > and is it's sole purpose to run the cruise? > > > > Chuck S > > 81FC35SB > > Florida > > > > > I think someone wrote earlier that the device will 'leak' if there is > > > a vacuum leak in the cruise control system. This makes sense. My next > > > test will be to remove the input vacuum line from the cruise control, > > > plug it and see if it stops the air leak. > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > >> > > >> Kerry, > > >> > > >> > > >> > > >> My 81 does the same thing. After shutting off the engine, it will > > > make a air > > >> leak sound for a little while, that changes when the lines are > > > moved. It has > > >> been awhile since I have looked at it, but if memory serves- I have > > > the same > > >> device, with a leaking sound coming from a empty port as well. I > > will be > > >> monitoring this post for a repair and or replacement for the device. > > > Let me > > >> > > >> > > >> > > >> > > >> Stephen H > > >> > > >> 81 FC-33SB > > >> > > >> Plant City, FL > > >> > > >> > > >> > > >> > > >> > > >> _____ > > >> > > >> From: WanderlodgeForum@yahoogroups.com > > > > >> [mailto:WanderlodgeForum@yahoogroups.com > > > > davidkerryedwards > > >> Sent: Friday, September 08, 2006 2:55 PM > > >> To: WanderlodgeForum@yahoogroups.com > > > > >> Subject: [WanderlodgeForum] air leak/vacuum generator leak > > >> > > >> > > >> > > >> I investiagted my air leak a little more. It does appear to be the > > >> vacuum generator mounted on the bottom of an air manifold behind the > > >> bumper. Air is coming out of the one of the fittings that has never > > >> had a hose on it. When I plug that fitting, the air must backfeed > > >> thru the cruise control vacuum system because it blows the hose off > > >> the vacuum canister on the engine. Do I need to replace the vacuum > > >> generator (if that is what it is)? If so, where would I purchase a > > >> replacement? > > >> > > >> Kerry Edwards > > >> 82 FC 35 > > >> Denver > > >> > > >> > > >> > > >> > > >> > > >> [Non-text portions of this message have been removed] > > >> > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > |
09-09-2006, 03:02
Hey Kerry & Stephen,
My 82 does the same thing. When plugged up, presents other problems so I've just left it alone. Alex Smith 82FC35 Tallahassee Stephen H <share@...> wrote: Kerry, My 81 does the same thing. After shutting off the engine, it will make a air leak sound for a little while, that changes when the lines are moved. It has been awhile since I have looked at it, but if memory serves- I have the same device, with a leaking sound coming from a empty port as well. I will be monitoring this post for a repair and or replacement for the device. Let me Stephen H 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Friday, September 08, 2006 2:55 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] air leak/vacuum generator leak I investiagted my air leak a little more. It does appear to be the vacuum generator mounted on the bottom of an air manifold behind the bumper. Air is coming out of the one of the fittings that has never had a hose on it. When I plug that fitting, the air must backfeed thru the cruise control vacuum system because it blows the hose off the vacuum canister on the engine. Do I need to replace the vacuum generator (if that is what it is)? If so, where would I purchase a replacement? Kerry Edwards 82 FC 35 Denver [Non-text portions of this message have been removed] --------------------------------- Do you Yahoo!? Everyone is raving about the all-new Yahoo! Mail. [Non-text portions of this message have been removed] |
09-09-2006, 05:18
Even though my cruise control vacuum sphere was not holding vacuum
very well, I decided the problem was the vacuum generator since even plugging the vaccum hose to the cruise control did not stop the air leak. It has no part numbers or name on it. I dissasembled it. It has a press fitted cover on the bottom which holds a rubber membrane, a spring, and a plastic needle valve that goes up into the body. It is an extremely simple device. I'm thinking that the needle valve must have been sticking. I damaged the rubber membrane under the cap when I removed it so I can't just reassemble it. I may just fabricate a replacement membrane (perhaps from a nitrile glove) and reassemble it. The reason I think the needle valve was sticking was that I could blow in the pressure side and it would leak prior to dissasembly. If I push the needle valve manually into the body, it holds air. I'll call Blueburd on Monday to see if they can direct me to a mfg. I'll also check out the source Tom posted. I noticed they rebuild the cruise control components. Do they also supply the vacuum generator? I looked on the air system diagrams and could not see the part. I also could not find it in the Bluebird parts book I have. There is a second line (vacuum?) attached to the generator in addition to the one that goes to the cruise control sphere. Does anyone know the purpose of the second hose? I'm thinking I could just plug the fitting and get by without the vacuum generator until I get a replacement if that second line does not operate a crucial component. Kerry 82 FC 35 Denver |
09-09-2006, 07:46
There are two vacuum (?) hoses coming off the generator. One goes to
the cruise, the other to ???. The air system schematics that came with my coach don't show any of that circuit as far as I can see. Perhaps the second hose is a return line to catch the compressed air after it produces a vacuum? I'm guessing it's sole pupose is for the cruise control, replacing the electric vacuum pump that was the source of vacuum in earlier years. You should be able to tell if yours is working by testing the input vacuum line into the vacuum canister on the top left of the engine. If you have enough vacuum there, that's not your problem. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, cfsomers@... wrote: > > I am new to all the details on the bluebirds, but my cruise stopped > working out of the blue going down the road. what is this vacumm generator > and is it's sole purpose to run the cruise? > > Chuck S > 81FC35SB > Florida > > > > I think someone wrote earlier that the device will 'leak' if there is > > a vacuum leak in the cruise control system. This makes sense. My next > > test will be to remove the input vacuum line from the cruise control, > > plug it and see if it stops the air leak. > > > > Kerry > > 82 FC 35 > > Denver > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> wrote: > >> > >> Kerry, > >> > >> > >> > >> My 81 does the same thing. After shutting off the engine, it will > > make a air > >> leak sound for a little while, that changes when the lines are > > moved. It has > >> been awhile since I have looked at it, but if memory serves- I have > > the same > >> device, with a leaking sound coming from a empty port as well. I will be > >> monitoring this post for a repair and or replacement for the device. > > Let me > >> > >> > >> > >> > >> Stephen H > >> > >> 81 FC-33SB > >> > >> Plant City, FL > >> > >> > >> > >> > >> > >> _____ > >> > >> From: WanderlodgeForum@yahoogroups.com > >> [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards > >> Sent: Friday, September 08, 2006 2:55 PM > >> To: WanderlodgeForum@yahoogroups.com > >> Subject: [WanderlodgeForum] air leak/vacuum generator leak > >> > >> > >> > >> I investiagted my air leak a little more. It does appear to be the > >> vacuum generator mounted on the bottom of an air manifold behind the > >> bumper. Air is coming out of the one of the fittings that has never > >> had a hose on it. When I plug that fitting, the air must backfeed > >> thru the cruise control vacuum system because it blows the hose off > >> the vacuum canister on the engine. Do I need to replace the vacuum > >> generator (if that is what it is)? If so, where would I purchase a > >> replacement? > >> > >> Kerry Edwards > >> 82 FC 35 > >> Denver > >> > >> > >> > >> > >> > >> [Non-text portions of this message have been removed] > >> > > > > > > > > > > > > > |
