SMI Brake Control
09-08-2006, 11:39
SMI Brake Control
Finished up the SMI SmartBox Brake Control install/test today. All
testing so far indicates the units in the toad and the coach are working
as advertised. The real test will be a longer run going down a much less
crowded highway where I have the opportunity to fiddle with it.
I'm towing just over 5,000 pounds. Those that have the SMI unit
installed, what number on the dial are you finding works best?
I appreciate everyones input helping me get this completed!
An older copy of the install procedure was in the box received from SMI.
SMI was very helpful in clarifying for the upgraded unit. A couple small
parts were missing and SMI provided the parts to me without hesitation.
Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif.
09-09-2006, 03:33
SMI Brake Control
Where did you guys mount the Display Module?
