Update on ZF trouble 87FC35
09-13-2006, 08:55
Alan, this is a long shot-- Steve Gureasko, 90WLWB had trouble with his coach
not going into gear. Does your coach have a manual shifter or a touchpad? He had to replace his touch pad, as there was a burnt part of that. Just another idea. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
09-13-2006, 09:33
Alan, if you can access the backside of your touch pad--- maybe- and just
maybe- a wire might have come off. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
09-13-2006, 12:30
Well, after many hours this is where I currently am.
1. I have zero volts going to my ZF ECU. 2. The coach won't start. Now I'm pretty sure that's because without voltage to my ECU, the coach doesn't know if it's in gear or not. (I can jump my starter solenoid and it starts.) 3. I talked to Dan at ZF in Chicago and he was quite helpful. He told me how to check voltage on the ZF. BUT he didn't know where the ZF gets it's power off the coach. 4. I am getting volts out of my 75amp ignition relay with the key turned on. There are bunches of ZF wires behind the grill in the steering column access panel. There are also two silver boxes with what are apparently ZF wires going in and out of them. The boxes are about 4" x 4" x 1". However, I know these aren't the ZF ECU. It is located underneath the push-button gear selectors by the driver. I don't know if they have anything to do with power. Questions (If anyone knows): 1. Where/how does the ZF get power from the coach? 2. Does the power go through the filtered power source under the couch? 3. What would keep me from getting any power to the ECU? Tomorrow I'm ordering a full set of electronic drawings, but in the mean time my neighbors would appreciate it if I can get the coach moved from the street. ![]() Thanks, Alan Johnson 972.769.2526 87FC35 |
09-13-2006, 13:25
One more thought. I re-looked at the "fix" on the web site for a
low-voltage problem. I don't think i've ever found that 12 volt relay for the ZF. I found the 75amp one, but this appears to be another one. ZF wire #19 is nearly impossible to trace. best i can tell, it goes under the coach and off into oblivion. ...But my common sense tells me I'm missing that relay and it's probably someplace accessible, I just don't know which one it is. ANY IDEAS ON WHERE THIS RELAY IS?? I'm betting at least 50/50 this is still my problem. Ernie, mine has the push-button gear selector. Bill, your suggestion about checking the barrel connectors was good too. I had a problem there too. I'm not sure how these problems are related, but probably somehow. I had a melted pin in one of the connectors. It was the 12v supply to the ignition switch. I'm suspecting it had been going bad with corrosion, and somehow all my "trouble shooting" was the end of it. I corrected that problem. Thank, Alan --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > Well, after many hours this is where I currently am. > > 1. I have zero volts going to my ZF ECU. > 2. The coach won't start. Now I'm pretty sure that's because > without voltage to my ECU, the coach doesn't know if it's in gear or > not. (I can jump my starter solenoid and it starts.) > 3. I talked to Dan at ZF in Chicago and he was quite helpful. He > told me how to check voltage on the ZF. BUT he didn't know where the > ZF gets it's power off the coach. > 4. I am getting volts out of my 75amp ignition relay with the key > turned on. > > There are bunches of ZF wires behind the grill in the steering > column access panel. There are also two silver boxes with what are > apparently ZF wires going in and out of them. The boxes are about > 4" x 4" x 1". However, I know these aren't the ZF ECU. It is > located underneath the push-button gear selectors by the driver. I > don't know if they have anything to do with power. > > Questions (If anyone knows): > 1. Where/how does the ZF get power from the coach? > 2. Does the power go through the filtered power source under the > couch? > 3. What would keep me from getting any power to the ECU? > > Tomorrow I'm ordering a full set of electronic drawings, but in the > mean time my neighbors would appreciate it if I can get the coach > moved from the street. ![]() > > Thanks, > Alan Johnson > 972.769.2526 > 87FC35 > |
09-13-2006, 13:42
Alan: I am looking at the wiring diagram for the FC with a ZF, drawng
#1255157. They show the power source as the starter relay. This relay has 4 terminals. One is an 8 ga. red and connects to the starter solenoid, one is black 8 ga. and also connects to the starter solenoid, one goes to ground. The 4th wire is red and goes to a terminal block and connects to #4. I dont know where this block is located but I suspect close to the shifter. There should be 3 terminal blocks. One with 11 terminals (this is the one you want), one with 4 and another with 8. Another owner with a ZF told me of having a problem similar to yours. He found a realy behind the shifter that was faulty. Good Luck Bruce |
09-13-2006, 14:08
Hi Alan,
Do you have the ZF Operating instruction Book?? It is a small Blue book about 6" x 8" . There is a procedure to manually shift a lever on the Trans into forward or reverse. This may help get the bus off of the road. I have not had the opportunity to try this, nor do I have this experience . You may want to check the neutral switch under the push button panel. I believe there is a manual switch or linkage there. The ZF may be looking for the Neutral button to engage. I also think that 12v modification Bosh 30 amp. relay, is at the base of the left side carpeted panel far forward, just hanging by the wires. There are two side by side Bosch 30 amp relays mounted forward of your left foot, these are the headlight relays. The two relays accessed from the front panel, forward of the throttle & brake pedals, these are the driving light relays. I do not know about those silver boxes. They could be turn signal/hazard light junction boxes. Lots of wires in there. Hope this helps, Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > One more thought. I re-looked at the "fix" on the web site for a > low-voltage problem. I don't think i've ever found that 12 volt > relay for the ZF. I found the 75amp one, but this appears to be > another one. ZF wire #19 is nearly impossible to trace. best i can > tell, it goes under the coach and off into oblivion. ...But my > common sense tells me I'm missing that relay and it's probably > someplace accessible, I just don't know which one it is. ANY IDEAS > ON WHERE THIS RELAY IS?? I'm betting at least 50/50 this is still > my problem. > > Ernie, mine has the push-button gear selector. > > Bill, your suggestion about checking the barrel connectors was good > too. I had a problem there too. I'm not sure how these problems > are related, but probably somehow. I had a melted pin in one of the > connectors. It was the 12v supply to the ignition switch. I'm > suspecting it had been going bad with corrosion, and somehow all > my "trouble shooting" was the end of it. I corrected that problem. > > Thank, > Alan > > > --- In WanderlodgeForum@yahoogroups.com, "Alan" > wrote: > > > > Well, after many hours this is where I currently am. > > > > 1. I have zero volts going to my ZF ECU. > > 2. The coach won't start. Now I'm pretty sure that's because > > without voltage to my ECU, the coach doesn't know if it's in gear > or > > not. (I can jump my starter solenoid and it starts.) > > 3. I talked to Dan at ZF in Chicago and he was quite helpful. He > > told me how to check voltage on the ZF. BUT he didn't know where > the > > ZF gets it's power off the coach. > > 4. I am getting volts out of my 75amp ignition relay with the key > > turned on. > > > > There are bunches of ZF wires behind the grill in the steering > > column access panel. There are also two silver boxes with what > are > > apparently ZF wires going in and out of them. The boxes are about > > 4" x 4" x 1". However, I know these aren't the ZF ECU. It is > > located underneath the push-button gear selectors by the driver. I > > don't know if they have anything to do with power. > > > > Questions (If anyone knows): > > 1. Where/how does the ZF get power from the coach? > > 2. Does the power go through the filtered power source under the > > couch? > > 3. What would keep me from getting any power to the ECU? > > > > Tomorrow I'm ordering a full set of electronic drawings, but in > the > > mean time my neighbors would appreciate it if I can get the coach > > moved from the street. ![]() > > > > Thanks, > > Alan Johnson > > 972.769.2526 > > 87FC35 > > > |
09-13-2006, 16:08
Why find it. find a good hot lug and use a ignition wire to open a
new relay to power the ECU. find out the amp limit and fuse it. Make a note on #19 of the change you made. You may have to power the relay that cuts off the starter solenoid as we now know that the starter solenoid wont power at all without power to the ecu. I know it sounds like ducttape and bailing wire advice but if you replace the relay supplying the power you may only be repairing a result and not a cause. It just sounds to me that fixing your failure will not correct the problem. I dont like to reengineere things. In my field of expertiese, I use a hammer. When that hammer wont complete the task, I get a bigger one. I think you need the expert advice of JohnF, TomW, CurtS JeffM and the other electrical members. This ZF power thing is gonna get some one hurt. It would be great to do an upgrade to a bus and keep it from developing the "ZF'up" Gregory O'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > One more thought. I re-looked at the "fix" on the web site for a > low-voltage problem. I don't think i've ever found that 12 volt > relay for the ZF. I found the 75amp one, but this appears to be > another one. ZF wire #19 is nearly impossible to trace. best i can > tell, it goes under the coach and off into oblivion. ...But my > common sense tells me I'm missing that relay and it's probably > someplace accessible, I just don't know which one it is. ANY IDEAS > ON WHERE THIS RELAY IS?? I'm betting at least 50/50 this is still > my problem. > > Ernie, mine has the push-button gear selector. > > Bill, your suggestion about checking the barrel connectors was good > too. I had a problem there too. I'm not sure how these problems > are related, but probably somehow. I had a melted pin in one of the > connectors. It was the 12v supply to the ignition switch. I'm > suspecting it had been going bad with corrosion, and somehow all > my "trouble shooting" was the end of it. I corrected that problem. > > Thank, > Alan > > > --- In WanderlodgeForum@yahoogroups.com, "Alan" > wrote: > > > > Well, after many hours this is where I currently am. > > > > 1. I have zero volts going to my ZF ECU. > > 2. The coach won't start. Now I'm pretty sure that's because > > without voltage to my ECU, the coach doesn't know if it's in gear > or > > not. (I can jump my starter solenoid and it starts.) > > 3. I talked to Dan at ZF in Chicago and he was quite helpful. He > > told me how to check voltage on the ZF. BUT he didn't know where > the > > ZF gets it's power off the coach. > > 4. I am getting volts out of my 75amp ignition relay with the key > > turned on. > > > > There are bunches of ZF wires behind the grill in the steering > > column access panel. There are also two silver boxes with what > are > > apparently ZF wires going in and out of them. The boxes are about > > 4" x 4" x 1". However, I know these aren't the ZF ECU. It is > > located underneath the push-button gear selectors by the driver. I > > don't know if they have anything to do with power. > > > > Questions (If anyone knows): > > 1. Where/how does the ZF get power from the coach? > > 2. Does the power go through the filtered power source under the > > couch? > > 3. What would keep me from getting any power to the ECU? > > > > Tomorrow I'm ordering a full set of electronic drawings, but in > the > > mean time my neighbors would appreciate it if I can get the coach > > moved from the street. ![]() > > > > Thanks, > > Alan Johnson > > 972.769.2526 > > 87FC35 > > > |
09-13-2006, 16:17
Alan,
A diesel engine doesn't need a lot to keep running. There is an upright fuel shut-off solenoid at the front of the engine near center. A little smaller than a drink can. This get 12 v from the ignition switch and allows the engine to have fuel. The fuel pump at the tank gets 12V when the oil pressure switch on the 3208 has oil pressure. There is an internal an internal pump within the injector pump as well and may be to pull the fuel from the tank. This is a mechanical pump. With 12V on the solenoid, bump the starter, it should start. NOW, not for the faint at heart. This is not safe at all and you can be killed doing this so you are at risk in more ways than the coach rolling over you. ****UNDERSTAND COMPLETELY THE RISK, PROCEED WITH CAUTION****** There is a lever on the ZF that will get the coach to move in just such a situation. It is a short lever on the transmission. This has the function of Forward, Neutral, Reverse. Forward 20* down Neutral center Reverse 20* up The engine and torque converter has to be running. Someone in coach with parking brake, not foot brake on (must be ready to keep the coach from moving.) Another person goes under the coach and moves the lever to go forward or reverse then return to center (neutral). Personally this scares the hell out of me to consider doing this but if you have to get it moved this will do it. Understannd also this coach is very heavy and can crush you. Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > Well, after many hours this is where I currently am. > > 1. I have zero volts going to my ZF ECU. > 2. The coach won't start. Now I'm pretty sure that's because > without voltage to my ECU, the coach doesn't know if it's in gear or > not. (I can jump my starter solenoid and it starts.) > 3. I talked to Dan at ZF in Chicago and he was quite helpful. He > told me how to check voltage on the ZF. BUT he didn't know where the > ZF gets it's power off the coach. > 4. I am getting volts out of my 75amp ignition relay with the key > turned on. > > There are bunches of ZF wires behind the grill in the steering > column access panel. There are also two silver boxes with what are > apparently ZF wires going in and out of them. The boxes are about > 4" x 4" x 1". However, I know these aren't the ZF ECU. It is > located underneath the push-button gear selectors by the driver. I > don't know if they have anything to do with power. > > Questions (If anyone knows): > 1. Where/how does the ZF get power from the coach? > 2. Does the power go through the filtered power source under the > couch? > 3. What would keep me from getting any power to the ECU? > > Tomorrow I'm ordering a full set of electronic drawings, but in the > mean time my neighbors would appreciate it if I can get the coach > moved from the street. ![]() > > Thanks, > Alan Johnson > 972.769.2526 > 87FC35 > |
09-13-2006, 16:26
Gregg you are absolutely correct in the hurt part but I am afraid of
"hurting" the ECU and advised Alan of that tonight. I understand that a replacement is on the order of $6000...OUCH!. Thats totally insane. If I had the schematics for the 1987 (I have a few of them but not the ones Alan needs) that includes the wiring from the dash to the ECU then I would troubleshoot the problem and correct it rather then running new wires and bosch relays. I have advised Alan to order the set of schematics for his specific coach from Earl Davis, about $85 and postage. In fact anyone on this forum that does not have the full set of factory drawings for his specific coach should buy them. They are an invaluable aid to keeping your coaches running. As Alan found out he has at least one burned pin in one of the barrel connectors that he had to wire around. I dont like to do that preferring instead to replace the connector or the pins and keeping everything original if possible. But as we know there are times when a change is necessary for example installing Bosch 30 amp relays to repower the headlights so they get full voltage. Also I would encourage anyone that has a FC model to do the same with the circuits for the A/C fans and the heat fans. That will get a lot of the heavy current items out of the dash and eliminate the big voltage drops. When I do that I also install relay sockets with pigtails so in the future just have to unplug a bad relay and put in a new one. I have been buying the Bosch 30 Amp relays for about $1/each and the sockets for I believe $1.05 or so. I think Ernies idea is a good one to check the push button transmission selector to see if there is any corrosion in it. I believe the transmission shifting problem and the starting problem are related. Tom Warner Vernon Center,NY 1985 PT 40 At 12:08 AM 9/14/2006, you wrote: >Why find it. find a good hot lug and use a ignition wire to open a >new relay to power the ECU. find out the amp limit and fuse it. Make >a note on #19 of the change you made. You may have to power the >relay that cuts off the starter solenoid as we now know that the >starter solenoid wont power at all without power to the ecu. I know >it sounds like ducttape and bailing wire advice but if you replace >the relay supplying the power you may only be repairing a result and >not a cause. It just sounds to me that fixing your failure will not >correct the problem. > >I dont like to reengineere things. In my field of expertiese, I use a >hammer. When that hammer wont complete the task, I get a bigger >one. I think you need the expert advice of JohnF, TomW, CurtS JeffM >and the other electrical members. This ZF power thing is gonna get >some one hurt. It would be great to do an upgrade to a bus and keep >it from developing the "ZF'up" > >Gregory O'Connor >94ptRomolandCa > > >--- In WanderlodgeForum@yahoogroups.com, "Alan" >wrote: > > > > One more thought. I re-looked at the "fix" on the web site for a > > low-voltage problem. I don't think i've ever found that 12 volt > > relay for the ZF. I found the 75amp one, but this appears to be > > another one. ZF wire #19 is nearly impossible to trace. best i >can > > tell, it goes under the coach and off into oblivion. ...But my > > common sense tells me I'm missing that relay and it's probably > > someplace accessible, I just don't know which one it is. ANY IDEAS > > ON WHERE THIS RELAY IS?? I'm betting at least 50/50 this is still > > my problem. > > > > Ernie, mine has the push-button gear selector. > > > > Bill, your suggestion about checking the barrel connectors was good > > too. I had a problem there too. I'm not sure how these problems > > are related, but probably somehow. I had a melted pin in one of >the > > connectors. It was the 12v supply to the ignition switch. I'm > > suspecting it had been going bad with corrosion, and somehow all > > my "trouble shooting" was the end of it. I corrected that problem. > > > > Thank, > > Alan > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Alan" > > wrote: > > > > > > Well, after many hours this is where I currently am. > > > > > > 1. I have zero volts going to my ZF ECU. > > > 2. The coach won't start. Now I'm pretty sure that's because > > > without voltage to my ECU, the coach doesn't know if it's in gear > > or > > > not. (I can jump my starter solenoid and it starts.) > > > 3. I talked to Dan at ZF in Chicago and he was quite helpful. He > > > told me how to check voltage on the ZF. BUT he didn't know where > > the > > > ZF gets it's power off the coach. > > > 4. I am getting volts out of my 75amp ignition relay with the key > > > turned on. > > > > > > There are bunches of ZF wires behind the grill in the steering > > > column access panel. There are also two silver boxes with what > > are > > > apparently ZF wires going in and out of them. The boxes are >about > > > 4" x 4" x 1". However, I know these aren't the ZF ECU. It is > > > located underneath the push-button gear selectors by the driver. >I > > > don't know if they have anything to do with power. > > > > > > Questions (If anyone knows): > > > 1. Where/how does the ZF get power from the coach? > > > 2. Does the power go through the filtered power source under the > > > couch? > > > 3. What would keep me from getting any power to the ECU? > > > > > > Tomorrow I'm ordering a full set of electronic drawings, but in > > the > > > mean time my neighbors would appreciate it if I can get the coach > > > moved from the street. ![]() > > > > > > Thanks, > > > Alan Johnson > > > 972.769.2526 > > > 87FC35 > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > |
09-14-2006, 03:21
Tom, I do remember someone taking a ZF'ed board to a TV shop to make
repairs with ZF factory schematics in hand. The delicate nature of the electronics is the reason I would 'Glass Fuse' the input power. Circuit Breakers I think work off of heat (post from a Canadian Tulip farmer). The more expensive breaker may allow too much amp-draw and too much damage to generate the heat to trip. The cheap glass are by design delicate and the hope is they are 'just as sensitive' if not 'more sensitive' than the component they protect. If a component on the transmission side of the ecu goes bad and draws a request of too much amps, will that draw pass and damage the ecu??? CurtS and I replaced all the wires in my taillight loom. the wires were black within the jacket and it looked burnt. what causes this??? I wonder what the input power wire to an in-operation zf-ecu looks like? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Gregg you are absolutely correct in the hurt part but I am afraid of > "hurting" the ECU and advised Alan of that tonight. I understand that > a replacement is on the order of $6000...OUCH!. Thats totally insane. > > If I had the schematics for the 1987 (I have a few of them but not > the ones Alan needs) that includes the wiring from the dash to the > ECU then I would troubleshoot the problem and correct it rather then > running new wires and bosch relays. I have advised Alan to order the > set of schematics for his specific coach from Earl Davis, about $85 > and postage. In fact anyone on this forum that does not have the full > set of factory drawings for his specific coach should buy them. They > are an invaluable aid to keeping your coaches running. > > As Alan found out he has at least one burned pin in one of the barrel > connectors that he had to wire around. I dont like to do that > preferring instead to replace the connector or the pins and keeping > everything original if possible. But as we know there are times when > a change is necessary for example installing Bosch 30 amp relays to > repower the headlights so they get full voltage. > > Also I would encourage anyone that has a FC model to do the same with > the circuits for the A/C fans and the heat fans. That will get a lot > of the heavy current items out of the dash and eliminate the big > voltage drops. When I do that I also install relay sockets with > pigtails so in the future just have to unplug a bad relay and put in > a new one. I have been buying the Bosch 30 Amp relays for about > $1/each and the sockets for I believe $1.05 or so. > > I think Ernies idea is a good one to check the push button > transmission selector to see if there is any corrosion in it. I > believe the transmission shifting problem and the starting problem are related. > > Tom Warner > Vernon Center,NY > 1985 PT 40 > > At 12:08 AM 9/14/2006, you wrote: > >Why find it. find a good hot lug and use a ignition wire to open a > >new relay to power the ECU. find out the amp limit and fuse it. Make > >a note on #19 of the change you made. You may have to power the > >relay that cuts off the starter solenoid as we now know that the > >starter solenoid wont power at all without power to the ecu. I know > >it sounds like ducttape and bailing wire advice but if you replace > >the relay supplying the power you may only be repairing a result and > >not a cause. It just sounds to me that fixing your failure will not > >correct the problem. > > > >I dont like to reengineere things. In my field of expertiese, I use a > >hammer. When that hammer wont complete the task, I get a bigger > >one. I think you need the expert advice of JohnF, TomW, CurtS JeffM > >and the other electrical members. This ZF power thing is gonna get > >some one hurt. It would be great to do an upgrade to a bus and keep > >it from developing the "ZF'up" > > > >Gregory O'Connor > >94ptRomolandCa > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Alan" > >wrote: > > > > > > One more thought. I re-looked at the "fix" on the web site for a > > > low-voltage problem. I don't think i've ever found that 12 volt > > > relay for the ZF. I found the 75amp one, but this appears to be > > > another one. ZF wire #19 is nearly impossible to trace. best i > >can > > > tell, it goes under the coach and off into oblivion. ...But my > > > common sense tells me I'm missing that relay and it's probably > > > someplace accessible, I just don't know which one it is. ANY IDEAS > > > ON WHERE THIS RELAY IS?? I'm betting at least 50/50 this is still > > > my problem. > > > > > > Ernie, mine has the push-button gear selector. > > > > > > Bill, your suggestion about checking the barrel connectors was good > > > too. I had a problem there too. I'm not sure how these problems > > > are related, but probably somehow. I had a melted pin in one of > >the > > > connectors. It was the 12v supply to the ignition switch. I'm > > > suspecting it had been going bad with corrosion, and somehow all > > > my "trouble shooting" was the end of it. I corrected that problem. > > > > > > Thank, > > > Alan > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Alan" > > > wrote: > > > > > > > > Well, after many hours this is where I currently am. > > > > > > > > 1. I have zero volts going to my ZF ECU. > > > > 2. The coach won't start. Now I'm pretty sure that's because > > > > without voltage to my ECU, the coach doesn't know if it's in gear > > > or > > > > not. (I can jump my starter solenoid and it starts.) > > > > 3. I talked to Dan at ZF in Chicago and he was quite helpful. He > > > > told me how to check voltage on the ZF. BUT he didn't know where > > > the > > > > ZF gets it's power off the coach. > > > > 4. I am getting volts out of my 75amp ignition relay with the key > > > > turned on. > > > > > > > > There are bunches of ZF wires behind the grill in the steering > > > > column access panel. There are also two silver boxes with what > > > are > > > > apparently ZF wires going in and out of them. The boxes are > >about > > > > 4" x 4" x 1". However, I know these aren't the ZF ECU. It is > > > > located underneath the push-button gear selectors by the driver. > >I > > > > don't know if they have anything to do with power. > > > > > > > > Questions (If anyone knows): > > > > 1. Where/how does the ZF get power from the coach? > > > > 2. Does the power go through the filtered power source under the > > > > couch? > > > > 3. What would keep me from getting any power to the ECU? > > > > > > > > Tomorrow I'm ordering a full set of electronic drawings, but in > > > the > > > > mean time my neighbors would appreciate it if I can get the coach > > > > moved from the street. ![]() > > > > > > > > Thanks, > > > > Alan Johnson > > > > 972.769.2526 > > > > 87FC35 > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > |
