Flying J
09-17-2006, 13:35
Flying J
I have used Flying J's in MO, IN, OH, PA, GA, TX, AZ, CA, NV, and
OK. Have always been real grateful that they provide so many services with the free dump station, free good tire air pressure, free fresh water, free overnight parking and pizza(not free). Fueled a couple times at the RV island. Takes about 45 minutes to take on 250 gal of diesel. Usually go thru the truck lanes for fuel and then swing around to the free services island if I need those services. Have had NO trouble with getting my 40' Bird and Jeep Grand Cherokee towed in or out of either the truck lanes or the RV islands. The Flying J's hit or miss on cleanliness at the fuel islands. Have had some diesel puddles to wade thru, have had some nice clean islands too. The nicest Flying J's are in IL, IN, OH and MO. Got fuel today in IN, paid $2.49/gal., Ohio wanted $2.64/gal. Jay Darst 85PT40 Springfield, IL just got back from Urbana, OH where the grand daddy of tractor pulling was held, The Enderle Pull-Offs. Interesting, the 6 time world champion pro-stock John Deere used a 3208 with 2 little turbos pushing air into 1 much larger turbo, it was fueled by alcohol. Looked a bit different than brother Dan's 3208, cause it had spark plugs among other things ;~} |
09-17-2006, 13:56
Flying J
the alky 3208 conversion is neat lets see Hohnstein stuff that in his
truck wow talk about power and grunt Stephen 77fc35 no sparkplugs or turbos just kitty no cat --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > I have used Flying J's in MO, IN, OH, PA, GA, TX, AZ, CA, NV, and > OK. > > Have always been real grateful that they provide so many services > with the free dump station, free good tire air pressure, free fresh > water, free overnight parking and pizza(not free). > > Fueled a couple times at the RV island. Takes about 45 minutes to > take on 250 gal of diesel. > > Usually go thru the truck lanes for fuel and then swing around to > the free services island if I need those services. Have had NO > trouble with getting my 40' Bird and Jeep Grand Cherokee towed in or > out of either the truck lanes or the RV islands. > > The Flying J's hit or miss on cleanliness at the fuel islands. Have > had some diesel puddles to wade thru, have had some nice clean > islands too. > > The nicest Flying J's are in IL, IN, OH and MO. > > Got fuel today in IN, paid $2.49/gal., Ohio wanted $2.64/gal. > > Jay Darst > 85PT40 > Springfield, IL just got back from Urbana, OH where the grand daddy > of tractor pulling was held, The Enderle Pull-Offs. Interesting, the > 6 time world champion pro-stock John Deere used a 3208 with 2 little > turbos pushing air into 1 much larger turbo, it was fueled by > alcohol. Looked a bit different than brother Dan's 3208, cause it > had spark plugs among other things ;~} > |
09-18-2006, 04:13
Flying J
Is there any reasonable solution to the BB's tendency to "gush" fuel
just before the tank is full? I try to estimate the amount of fuel to take on ... but the fuel gauge is hardly precise enough to get within 20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or so splashes out, it tends to cover everything - gloves or not. (I've learned to stand back!) Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 17, 2006, at 6:35 PM, Jay Darst wrote: > <snip> > Have > had some diesel puddles to wade thru, <snip> [Non-text portions of this message have been removed] |
09-18-2006, 04:29
Flying J
Somewhere in the archives or files on either this site or the FC forum is a
solution designed by someone that I believe uses PVC pipe to solve the problem. Kerry 82 Fc 35--Gusher Denver --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > Is there any reasonable solution to the BB's tendency to "gush" fuel > just before the tank is full? I try to estimate the amount of fuel to > take on ... but the fuel gauge is hardly precise enough to get within > 20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or > so splashes out, it tends to cover everything - gloves or not. (I've > learned to stand back!) > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > On Sep 17, 2006, at 6:35 PM, Jay Darst wrote: > > > <snip> > > Have > > had some diesel puddles to wade thru, <snip> > > > [Non-text portions of this message have been removed] > |
09-18-2006, 04:40
Flying J
Pete:
Check the archives for "fuel splash back" I remember someone having a solution to this problem, just not who. Well, they do say that the "memory" is first to go, right? Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 09:13 AM 9/18/2006 -0700, you wrote: >Is there any reasonable solution to the BB's tendency to "gush" fuel >just before the tank is full? I try to estimate the amount of fuel to >take on ... but the fuel gauge is hardly precise enough to get within >20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or >so splashes out, it tends to cover everything - gloves or not. (I've >learned to stand back!) > >Pete Masterson >aeonix1@... >'95 Bluebird Wanderlodge WBDA 42' >El Sobrante, CA > > > > >On Sep 17, 2006, at 6:35 PM, Jay Darst wrote: > > > <snip> > > Have > > had some diesel puddles to wade thru, <snip> > > > |
09-18-2006, 04:44
Flying J
Pete,
I think John Finn posted this solution. Wrap a terry towel around the fuel nozzle/filler neck. Works great. Leave the towel hanging behind the fuel door. I use a bungee cord to hold the fuel nozzle in the filler neck. It doubles as the terry towel hanger. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Pete Masterson wrote: >Is there any reasonable solution to the BB's tendency to "gush" fuel >just before the tank is full? I try to estimate the amount of fuel to >take on ... but the fuel gauge is hardly precise enough to get within >20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or >so splashes out, it tends to cover everything - gloves or not. (I've >learned to stand back!) > >Pete Masterson >aeonix1@... >'95 Bluebird Wanderlodge WBDA 42' >El Sobrante, CA > > > > >On Sep 17, 2006, at 6:35 PM, Jay Darst wrote: > > > >><snip> >> Have >>had some diesel puddles to wade thru, <snip> >> >> > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > > > > |
09-18-2006, 04:51
Flying J
Pete: On my 93pt-40 , when I want to top off the tank, I take both
fuel cap's off. You can fill it to the top of the filler tube if you want with no splash. You have to be careful and monitor the filling or you could run the tank over. The auto release on the pump dispenser handle usually won't work when you do this, just be sure and monitor it.Bob 93pt-40......Illinois |
09-18-2006, 05:48
Flying J
Billy Dawson, did a modification for the fuel blow back. I think he has an ad
on Vintage Birds. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
09-18-2006, 06:01
Flying J
I'll try that one for next time...
I've searched the archives (of both lists) for "fuel splash" and "fuel overflow" with no luck --- although I do remember that the topic was previously discussed many months ago (before I purchase my 'bird). Thanks. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 18, 2006, at 9:51 AM, Bob & Carol Howald` wrote: > Pete: On my 93pt-40 , when I want to top off the tank, I take both > fuel cap's off. You can fill it to the top of the filler tube if you > want with no splash. You have to be careful and monitor the filling or > you could run the tank over. The auto release on the pump dispenser > handle usually won't work when you do this, just be sure and monitor > it.Bob 93pt-40......Illinois [Non-text portions of this message have been removed] |
09-18-2006, 07:28
Flying J
That's the way I do it Curt, simple and effective, works every time,
even at Flying J's!! "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA //////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Pete, > I think John Finn posted this solution. Wrap a terry towel around the > fuel nozzle/filler neck. Works great. Leave the towel hanging behind the > fuel door. I use a bungee cord to hold the fuel nozzle in the filler > neck. It doubles as the terry towel hanger. > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > Pete Masterson wrote: > > >Is there any reasonable solution to the BB's tendency to "gush" fuel > >just before the tank is full? I try to estimate the amount of fuel to > >take on ... but the fuel gauge is hardly precise enough to get within > >20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or > >so splashes out, it tends to cover everything - gloves or not. (I've > >learned to stand back!) > > > >Pete Masterson > >aeonix1@... > >'95 Bluebird Wanderlodge WBDA 42' > >El Sobrante, CA > > > > > > > > > >On Sep 17, 2006, at 6:35 PM, Jay Darst wrote: > > > > > > > >><snip> > >> Have > >>had some diesel puddles to wade thru, <snip> > >> > >> > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > |
