EL Inverter Testing
09-24-2006, 08:53
EL Inverter Testing
There is 12VDC going to the upper dash EL inverter (only one inverter).
Using a clamp-on meter, clamping round one inverter wire at a time, should I get ACV reading from at least one of the wires? I tried this and no ACV reading on the meter. Could the rheostat cause a no load condition to the inverter, and in turn cause the inverter to go bad? -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. |
09-24-2006, 09:41
EL Inverter Testing
Curt: Where did you buy that clamp on meter? That's what I need, May save me
a lot of time. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com Sent: Sunday, September 24, 2006 3:53 PM Subject: [WanderlodgeForum] EL Inverter Testing There is 12VDC going to the upper dash EL inverter (only one inverter). Using a clamp-on meter, clamping round one inverter wire at a time, should I get ACV reading from at least one of the wires? I tried this and no ACV reading on the meter. Could the rheostat cause a no load condition to the inverter, and in turn cause the inverter to go bad? -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
09-24-2006, 10:05
EL Inverter Testing
Leroy,
I bought the clamp-on meter at Harbor Freight, Item 42369, $17.99. Clamp around only one wire, not multiples. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Leroy Eckert wrote: >Curt: Where did you buy that clamp on meter? That's what I need, May save me a lot of time. > >Leroy Eckert >1990 WB-40 >Niceville, FL > > > > |
