Thanks Curt for the reply-- are these relays or thermal
09-24-2006, 12:45
Auto-Reset Circuit Breaker Information:
Compact circuit breakers with an auto-reset facility. Designed to withstand
overload but to trip quickly on short circuits, the circuit breaker latches
into an off state under fault conditions and automatically returns to the on
state after a set period of time. If the fault condition still exists, the
unit will immediately latch off again. This process of checking the circuit
will
continue until the fault is cleared.
Kevin McKeown
Yorba Linda, CA
1986 38' PT (maybe for sale in a month)
09-24-2006, 16:20
Are these thermal fuses, relays or what? Do you have to get them from
bb or can they be purchesed localy. Again what do you call them?
Thanks
Ed Gardels 89sp
Arlington, Texas
09-24-2006, 17:25
Ed,
You can buy them at your local auto parts store. If I understand what
you previously described, the "can" is simply called a 12VDC circuit
breaker (auto reset)...not a fuse which means they break the circuit and
no reset. They are rated at different AMPS as needed..
Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif.
> Thanks
> Ed Gardels 89sp
> Arlington, Texas
>Yahoo! Groups Links
