Hint for series 60 owners
09-25-2006, 00:49
If you have a series 60 with the oil fill FLAP and are getting oil
splatter on the engine or rear of your coach, I have a fix for you.
After 3 years of wiping oil splatter, I finally found a fix for the
total cost of $3.95 (or less).
Go to your nearest swimming pool supplier and ask for a 1 1/4 inch
freeze plug (expansion plug).
This is a expandable rubber stopper/plug that you place in the fill
tube (leave the flap in place) and tighten the wing nut to expand it
and stop the oil from escaping.
Apparently the newer 60 series has a similar setup from DD, but I was
too cheap to buy the parts to retrofit my 60 series.
Paul
97wb43
09-25-2006, 02:14
Paul, is there a PCV valve some place?The splatter from the tube is
probably greater in a cold engine. I wonder if the plug will cause
the cold Crankcase pressure to lift the tube at the block ( if it is
setup that way) or put pressure somplace else. Like you describe My
8V92 has the plug and splatter there would be a pain.
GregoryO'Connor
94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "p_a_lazar"
was
> Paul
> 97wb43
09-25-2006, 04:03
Greg,
There isn't a PCV valve and the slobber tube is the breather and
should work better now with the plug.
I just returned from an 800 mile trip at speeds to 75MPH without any
problem with the plug and no oil escaped.
As I said in my original post, DD has changed to a plug for the exact
same reason.
09-25-2006, 15:44
Paul, I wish DD used a servicable PCV in place of slobber tubes. I
wonder if the pool plug could use a spot of JB weld at the top of the
thread to keep the center of the plug from falling into the engine.
Thanks for the tip. Some day I may join the over 40 crowd.
Tommy2Shoes, is it called '41 and Better' or '40 and over' ??
GregoryO'Connor
94ptRomoland
> Greg,
exact
> same reason.
is
cause
is
My
09-26-2006, 16:01
It's got to be 41 and better.
T2S McCarthy
'95 PT42
I
engine.
> GregoryO'Connor
> 94ptRomoland
> > Greg,
any
> exact
> > same reason.
tube
> is
> cause
it
> is
describe
> My
