Chassis lube reminder
09-25-2006, 00:55
While getting my coach lubed the other day, I asked the tech if he
jacked up the front end to lube the king pins, and he responded, "if you want us to do so", which I did and they didn't mind doing it. MOST lube places do not routinely jack the front end to take the weight off the wheels which is the ONLY correct way to lube the king pins. Luckily the king pins can go a LONG time with very little or no grease or we would all be in deep trouble. If you lube you own, you need to remeber to do this as well. Although you think grease is going into the zerk, little or none can be pressed in with that much weight blocking it. Paul 97wb43 |
09-25-2006, 06:30
Thanks Paul, I always heard that was the proper procedure to lube those king
pins. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
09-27-2006, 06:11
FWIW, in the groups file section, there is a folder labeled "BB King
Pin Lube Information" for a 1983 Wanderlodge. Scan0002.jpg has a note that advises NOT to lift the front end of the vehicle when greasing the king pins. Tim Hannink Fulltiming in Paradis, LA 1981 FC-33SB --- In WanderlodgeForum@yahoogroups.com, "p_a_lazar" wrote: > > While getting my coach lubed the other day, I asked the tech if he > jacked up the front end to lube the king pins, and he responded, "if > you want us to do so", which I did and they didn't mind doing it. > > MOST lube places do not routinely jack the front end to take the > weight off the wheels which is the ONLY correct way to lube the king > pins. Luckily the king pins can go a LONG time with very little or no > grease or we would all be in deep trouble. > > If you lube you own, you need to remeber to do this as well. Although > you think grease is going into the zerk, little or none can be pressed > in with that much weight blocking it. > > Paul > 97wb43 > |
