Fwd: Re: Jeep Wrangler
09-26-2006, 21:09
Bruce I have towed a Wrangler 2000 since new. My manual says to put the
transfer case in neutral after backing up to make sure it is out of four
wheel drive. Then put the tranny in a forward gear & it doesn't say which one.
I
usually use 5th gear. I've towed over 30,000 miles with it.
Don
89 SP 36'
Butler, Pa
To anyone towing a Jeep Wrangler 5 speed.
I will be towing a 98 Jeep Wrangler 5 speed and need to know if the
transmission should be in neutral or in gear - if so which gear? The transfer
case
will be in neutral. Seems to be a little confusion about the Wrangler and I
don't have an owners manual for information.
My Grand Cherokee says transfer case in neutral, transmission in park - but
it's an automatic.
Any help would be appreciated.
Thanks -
Bruce A
86PT38
MF, Oregon
09-27-2006, 06:20
Bruce,
Since the transfer case is in neutral, the gears in the tranny
shouldn't spin unless there is some friction caused by the fluid in
the transfer case that might spin the tailshaft. So putting the
tranny in any gear should stop that.
to put the
of four
say which one. I
> Don
> 89 SP 36'
> Butler, Pa
The transfer case
Wrangler and I
park - but
> it's an automatic.
> Thanks -
> Bruce A
> 86PT38
> MF, Oregon
09-27-2006, 06:20
Bruce,
to put the
of four
say which one. I
> Don
> 89 SP 36'
> Butler, Pa
The transfer case
Wrangler and I
park - but
> it's an automatic.
> Thanks -
> Bruce A
> 86PT38
> MF, Oregon
