Inverter function 90SP36
09-28-2006, 06:01
I'm not sure which inverter you have, but with my PACS 1500, it needs a
slight initial current draw to begin working. I believe my Blue Book or the
PACS
manual suggest briefly using the electric curtains (which is 110v) which
will energize the inverter system, then push the reset button, and all works
fine after that. Also, the inverter typically won't work if the battery
voltage
goes below either 10.5 or 11 volts.
Give the curtain trick a try, and see it that works. It does with mine.
Kevin McKeown
Yorba Linda, CA
1986 38' PT
09-28-2006, 08:22
I When I turn on my inverter and press the reset button I get no
110v output until I start the engine. I can then shut off the engine
and the inverter continues to put out 110.
Any ideas?
Chuck Harrison
Akron, Ohio
90SP36
09-28-2006, 11:00
--- TRY THE ELECTRIC CURTAIN AFTE HITTING THE RESET BUTTON
Regards,
Hank H
90SP36
In WanderlodgeForum@yahoogroups.com, "williamcharrison"
> Any ideas?
> Chuck Harrison
> Akron, Ohio
> 90SP36
06-30-2008, 02:00
The inverter on my coach will not kick in unless I start
the engine momentarily (I have previously reset it). After
starting the engine I can turn it off and the inverter stays on.
Chuck Harrison
Akron, Ohio
90 SP36
06-30-2008, 04:14
Chuck,
Inverters also require more current to start than when running. Most of the better ones have a circuit that prevents the inverter from running the batteries two low. If the resting terminal voltage of the batteries is OK connect a voltmeter across the input to the inverter and watch it as you turn the inverter on. If you see a significant drop in voltage you probably have a poor connection between the inverter and the battery and this is causing the inverter to shutdown. The alternator is providing just enough extra oomph to get past the starting current. If you have separate starting batteries and the house batteries are old check the terminal voltage when the inverter is turned on. If you see a drop at the terminals it is time for new batteries if all the connections are in good condition. If you have a infrared heat sensor point it at the battery terminals. If they are warmer that the surrounding batteryyou have a poor battery connection.
- Chuck Wheeler-
FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of williamcharrison
Sent: Monday, June 30, 2008 9:01 AM
Subject: [WanderlodgeForum] Inverter function 90SP36
Chuck Harrison
Akron, Ohio
90 SP36
06-30-2008, 07:19
ChuckW, that is a great diagnostic. When I read ChuckH's question, I
could not even think of a link.
You dont have to have smarts, just smart friends.
GregoryO'Connor
94pt
--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler"
> Chuck,
Most of
running the
batteries is OK
as you
you probably
this is
just enough
separate
terminal
terminals
condition.
terminals. If
> they are warmer that the surrounding battery you have a poor
battery
> connection.
> - Chuck Wheeler-
> _____
williamcharrison
> Chuck Harrison
> Akron, Ohio
> 90 SP36
06-30-2008, 08:03
In addition to the Chuck W. tip , Some of these inverters also need
a load to get started, So turn someting "ON" then fire up the
Inverter.
Bill 88 FC Michigan
I
> GregoryO'Connor
> 94pt
> > Chuck,
> Most of
> running the
> batteries is OK
> as you
> you probably
> this is
> just enough
> separate
> terminal
> terminals
> condition.
> terminals. If
> battery
> > connection.
> > - Chuck Wheeler-
> > _____
> williamcharrison
> > Chuck Harrison
> > Akron, Ohio
> > 90 SP36
06-30-2008, 13:00
Thanks Greg! I learned early with our bird that I seemed to overlook the simple solutions sure that the problem had to be something beyond my capabilities. Most of the time they really are simple.
- Chuck Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gregory OConnor
Sent: Monday, June 30, 2008 2:19 PM
Subject: [WanderlodgeForum] Re: Inverter function 90SP36
GregoryO'Connor
94pt
--- In "WanderlodgeForum%40yahoogroups.com", "Chuck Wheeler"
.> wrote:
> Chuck,
Most of
running the
batteries is OK
as you
you probably
this is
just enough
separate
terminal
terminals
condition.
terminals. If
battery
> connection.
> - Chuck Wheeler-
> _____
> From: "WanderlodgeForum%40yahoogroups.com"
> [mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of
williamcharrison
> Chuck Harrison
> Akron, Ohio
> 90 SP36
06-30-2008, 13:47
Chuck
I do like Bill said. I turn my inverter on then I use the switch to operate the drapes & that will fire my inverter up. i always have to do it that way & you probability have the same inverter as me.
Don Spithaler
89 SP 36'
Butler, PA
Inverter.
Bill 88 FC Michigan
--- In "WanderlodgeForum%40yahoogroups.com", "Gregory OConnor"
I
> GregoryO'Connor
> 94pt
> > Chuck,
> Most of
> running the
> batteries is OK
> as you
> you probably
> this is
> just enough
> separate
> terminal
> terminals
> condition.
> terminals. If
> battery
> > connection.
> > - Chuck Wheeler-
> > _____
> williamcharrison
> > Chuck Harrison
> > Akron, Ohio
> > 90 SP36
07-01-2008, 03:30
I hit the drapes switch just like DON does.
Regards,
Hank
90SP36
--- In WanderlodgeForum@yahoogroups.com, "Donald Spithaler"
> Chuck
switch to
to do it
> Don Spithaler
> 89 SP 36'
> Butler, PA
need
> > Inverter.
> > Bill 88 FC Michigan
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Gregory OConnor"
question,
> > I
> > > GregoryO'Connor
> > > 94pt
> > "Chuck Wheeler"
> > > wrote:
> > > > Chuck,
running.
> > > Most of
> > > running the
> > > batteries is OK
watch it
> > > as you
> > > you probably
> > > this is
> > > just enough
> > > separate
> > > terminal
> > > terminals
good
> > > condition.
> > > terminals. If
> > > battery
> > > > connection.
> > > > - Chuck Wheeler-
> > > > _____
> > > > From: WanderlodgeForum@yahoogroups.com 40yahoogroups.com>
> > > > [mailto:WanderlodgeForum@yahoogroups.com 40yahoogroups.com>]
> > On Behalf Of
> > > williamcharrison
> > > > To: WanderlodgeForum@yahoogroups.com 40yahoogroups.com>
on.
> > > > Chuck Harrison
> > > > Akron, Ohio
> > > > 90 SP36
