Plumbing woes
10-01-2006, 08:09
Plumbing woes
I have had persistent problems with my coach plumbing. The copper lines
have been patched so many times, and all the clamps have been tightened so many times- that it was time to replumb. I should have put up with the leaks. I used Pex tubing and fittings. The new Pex is a joy to work with. What was my nightmare was routing the new in the cramped spaces where the old was. And the closest supply house is 25 miles away. The copper lines and fittings have been removed and thankfully after only 3 trips to the supply house, I now have at least curbside plumbing that doesn't leak!!! Ernie-83PT40 in Montana- watching football now |
10-01-2006, 13:09
Plumbing woes
--- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg"
> > I have had persistent problems with my coach plumbing. The copper lines > have been patched so many times, and all the clamps have been > tightened so many times- that it was time to replumb. > I should have put up with the leaks. > I used Pex tubing and fittings. The new Pex is a joy to work with. What > was my nightmare was routing the new in the cramped spaces where the > old was. And the closest supply house is 25 miles away. The copper > lines and fittings have been removed and thankfully after only 3 trips > to the supply house, I now have at least curbside plumbing that doesn't > leak!!! > Ernie-83PT40 in Montana- watching football now Ernie, What kind of material is "PEX" tubing made from? Are the fittings compression type, glue, or something else like an "O" ring seal? What sizes does it come in, and what are the pressure ratings, working and static. I have been in the piping trade for more years than I want to remember and "PEX" is a new one on me. Sounds interesting, although copper is great for most installations it can be a bear to work with in the confined spaces we have in our "Birds". Larry Holland 82FC35SB 3208T Canandaigua, N.Y. > |
10-01-2006, 14:49
Plumbing woes
Pex tubing is uded in most new RV's. It is plastic and can be used for
both hot and cold. The tubing has a memory. In the Rv factories they have a special mandrel that stretches the tubing and then it is slipped onto the fittings and a plastic crimp sleeve is installed. The tubing is always trying to return to it"s original size and thus you get a good seal. For those of us without the fancy tools there are a number of ways that Pex can be utilized. Some home supply stores will rent the crimper. Or you can get special compression fittings for the Pex. Ernie: Which method and brand did you use? Bruce 1988 FC35 |
10-01-2006, 17:21
Plumbing woes
pex is cross linked polyethelen tubing comes 3/8,1/2,3/4,1 inch are
most used consumer sizes variety of fittings some are user friendly some are not usually clapmed witha crimper and ring works great and even better for raidiant heating in homes http://www.ppfahome.org/pex/faqpex.html stephen 77fc35 with pex no copper --- In WanderlodgeForum@yahoogroups.com, "Larry holland" > > --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > > > > I have had persistent problems with my coach plumbing. The copper > lines > > have been patched so many times, and all the clamps have been > > tightened so many times- that it was time to replumb. > > I should have put up with the leaks. > > I used Pex tubing and fittings. The new Pex is a joy to work with. > What > > was my nightmare was routing the new in the cramped spaces where the > > old was. And the closest supply house is 25 miles away. The copper > > lines and fittings have been removed and thankfully after only 3 > trips > > to the supply house, I now have at least curbside plumbing that > doesn't > > leak!!! > > Ernie-83PT40 in Montana- watching football now > > Ernie, What kind of material is "PEX" tubing made from? Are the > fittings compression type, glue, or something else like an "O" ring > seal? What sizes does it come in, and what are the pressure ratings, > working and static. I have been in the piping trade for more years > than I want to remember and "PEX" is a new one on me. Sounds > interesting, although copper is great for most installations it can be > a bear to work with in the confined spaces we have in our "Birds". > Larry Holland > 82FC35SB 3208T > Canandaigua, N.Y. > > > |
10-01-2006, 20:23
Plumbing woes
I used the 1/2 inch ratchet crimper my son had. He said it cost 150 bucks-
glad he had it or I would have put up with the leaks. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
10-01-2006, 20:25
Plumbing woes
here in Montana, lots of the high end homes have radiant heat with pex and
copper. It must be really expensive to have it installed. Ernie Ekberg 83 PT40 Livingston, Montana-pex- no leaks [Non-text portions of this message have been removed] |
10-02-2006, 04:06
Plumbing woes
My neighbor who lives across the street from our Mammoth Lakes house is the
plumber that did that episode of This Old House and the radiant heating using PEX tubing. He loves the stuff, and can't understand why anybody wouldn't use it. He's working on the contract for heating the new runway at Mammoth Lakes Airport, using PEX plumbing and radiant heat. Pretty neat stuff....pretty neat how all that radiant heating stuff works both inside and outside. If you get a chance to see that episode of Bob Vila's This Old House, it's worth the watch. Kevin McKeown Yorba Linda, CA (Also Mammoth Lakes, I guess) 1986 38' PT [Non-text portions of this message have been removed] |
10-02-2006, 04:35
Plumbing woes
PEX is "Cross-linked polyethylene". I first heard of it a few years
ago on the PBS show "This Old House" where it was used for radiant hot water heating systems. Subsequently TOH used PEX for retrofitting plumbing and other difficult plumbing situations where the flexibility was a real advantage. I suspect that the relatively limited applications for PEX (on This Old House) has something to do with the cost vs. other materials. However, as copper has really gone up in price recently, I'm sure PEX will see more use in the future. See <http://www.ppfahome.org/pex/faqpex.html> for details about the product. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Oct 1, 2006, at 6:09 PM, Larry holland wrote: > > > Ernie, What kind of material is "PEX" tubing made from? Are the > fittings compression type, glue, or something else like an "O" ring > seal? What sizes does it come in, and what are the pressure ratings, > working and static. I have been in the piping trade for more years > than I want to remember and "PEX" is a new one on me. Sounds > interesting, although copper is great for most installations it can be > a bear to work with in the confined spaces we have in our "Birds". > Larry Holland > 82FC35SB 3208T > Canandaigua, N.Y. >> [Non-text portions of this message have been removed] |
10-02-2006, 05:14
Plumbing woes
Ernie,
Was this crimpier the kind that expanded the end of the PEX tubing and then the other side forced on a sleeve over the tubing and connector? I assume that you used 1/2" PEX, correct? Jimmy -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of erniecarpet@... Sent: Monday, October 02, 2006 7:24 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Plumbing woes I used the 1/2 inch ratchet crimper my son had. He said it cost 150 bucks- glad he had it or I would have put up with the leaks. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
10-02-2006, 05:40
Plumbing woes
Pete, I used PEX when I replumbed the Bear's Den. I did research and the
characteristics I liked were that it was easier to replumb because of the flexibility, it took fewer fittings and it is pretty much impervious to bursting. It handles both hot and cold water. The crimp fittings are also supposed to handle the leaking problems. Secondarily, the size is standard plumbing size rather than the copper used in my Bird. And since it is inside you don't have to worry about ultraviolet or sun damage. It is easy to alter or repair if you want to in the future. I found lots of pluses with no real minuses. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - WOO (http://www.wanderlodge.us) 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Monday, October 02, 2006 12:35 PM Subject: Re: [WanderlodgeForum] Re: Plumbing woes PEX is "Cross-linked polyethylene". I first heard of it a few years ago on the PBS show "This Old House" where it was used for radiant hot water heating systems. Subsequently TOH used PEX for retrofitting plumbing and other difficult plumbing situations where the flexibility was a real advantage. I suspect that the relatively limited applications for PEX (on This Old House) has something to do with the cost vs. other materials. However, as copper has really gone up in price recently, I'm sure PEX will see more use in the future. See <http://www.ppfahome.org/pex/faqpex.html> for details about the product. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Oct 1, 2006, at 6:09 PM, Larry holland wrote: > > > Ernie, What kind of material is "PEX" tubing made from? Are the > fittings compression type, glue, or something else like an "O" ring > seal? What sizes does it come in, and what are the pressure ratings, > working and static. I have been in the piping trade for more years > than I want to remember and "PEX" is a new one on me. Sounds > interesting, although copper is great for most installations it can be > a bear to work with in the confined spaces we have in our "Birds". > Larry Holland > 82FC35SB 3208T > Canandaigua, N.Y. >> [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
