EL Test Panel
10-03-2006, 04:07
EL Test Panel
The EL Test Panel that Stephen Birtles made up and sent to me proved the
upper dash inverter is bad. I used jumpers and hooked up a new inverter...the upper dash works great. THANKS STEPHEN! *Greg O'Connor*, please send me your Romoland mailing address. I'll mail the EL Test Panel to you. I believe Leroy Eckert is to get the panel after you. -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. |
10-03-2006, 08:09
EL Test Panel
Curt, Glad you got it going. I was able to make my upper panel working also,
broken wire at the upper rheostat and one of the inverters. My radio panel does not work. I expect a panel problem. That little test panel will help me confirm. Questions Please: How many inverters power your upper panel? Is your upper panel two six foot pieces? Does the upper rheostat operate only the upper panel. If you do not know please do not take the time to figure it out. As long as my inverters work I'll leave them alone. Still trying to determine how many of those elusive blue squares are in my bus.(only found 4 wired together on the upper rheostat) I refuse to tear out the TV and A/C ducts to trace the 110 side of those inverters. Thanks, Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com Sent: Tuesday, October 03, 2006 11:07 AM Subject: [WanderlodgeForum] EL Test Panel The EL Test Panel that Stephen Birtles made up and sent to me proved the upper dash inverter is bad. I used jumpers and hooked up a new inverter...the upper dash works great. THANKS STEPHEN! *Greg O'Connor*, please send me your Romoland mailing address. I'll mail the EL Test Panel to you. I believe Leroy Eckert is to get the panel after you. -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
10-03-2006, 10:28
EL Test Panel
Leroy,
Upper panel consists of two 3' pieces, one inverter (if the new inverter goes bad I'll install two), rheostat operates the upper panels, lower dash also has a rheostat. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Leroy Eckert wrote: >Curt, Glad you got it going. I was able to make my upper panel working also, broken wire at the upper rheostat and one of the inverters. My radio panel does not work. I expect a panel problem. That little test panel will help me confirm. > >Questions Please: >How many inverters power your upper panel? Is your upper panel two six foot pieces? Does the upper rheostat operate only the upper panel. >If you do not know please do not take the time to figure it out. As long as my inverters work I'll leave them alone. > >Still trying to determine how many of those elusive blue squares are in my bus.(only found 4 wired together on the upper rheostat) I refuse to tear out the TV and A/C ducts to trace the 110 side of those inverters. > >Thanks, > >Leroy Eckert >1990 WB-40 >Niceville, FL > > > > ----- Original Message ----- > From: Curt Sprenger > To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com > Sent: Tuesday, October 03, 2006 11:07 AM > Subject: [WanderlodgeForum] EL Test Panel > > > The EL Test Panel that Stephen Birtles made up and sent to me proved the > upper dash inverter is bad. I used jumpers and hooked up a new > inverter...the upper dash works great. > > THANKS STEPHEN! > > *Greg O'Connor*, please send me your Romoland mailing address. I'll mail > the EL Test Panel to you. I believe Leroy Eckert is to get the panel > after you. > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > > > |
10-03-2006, 11:40
EL Test Panel
Curt The one inverters in the top dash is that one of Stephens. My
original one had two of the blue cubes Don 89 SP 36' Butler, PA Leroy, Upper panel consists of two 3' pieces, one inverter (if the new inverter goes bad I'll install two), rheostat operates the upper panels, lower dash also has a rheostat. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Leroy Eckert wrote: >Curt, Glad you got it going. I was able to make my upper panel working also, broken wire at the upper rheostat and one of the inverters. My radio panel does not work. I expect a panel problem. That little test panel will help me confirm. > >Questions Please: >How many inverters power your upper panel? Is your upper panel two six foot pieces? Does the upper rheostat operate only the upper panel. >If you do not know please do not take the time to figure it out. As long as my inverters work I'll leave them alone. > >Still trying to determine how many of those elusive blue squares are in my bus.(only found 4 wired together on the upper rheostat) I refuse to tear out the TV and A/C ducts to trace the 110 side of those inverters. > >Thanks, [Non-text portions of this message have been removed] |
10-03-2006, 12:12
EL Test Panel
Thanks Curt
I'm going try running my top with one of his. Don 89 Sp 36' Butler, PA Don, Don't know. New one that works I got from Stephen. I question if two inverters are needed. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. _dspithaler@..._ (mailto:dspithaler@...) wrote: [Non-text portions of this message have been removed] |
10-03-2006, 12:18
EL Test Panel
Sorry, I meant two 3' pieces. Hummm, there's something happening here, what it
is ain't exactly clear! Thanks for the info. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, October 03, 2006 5:28 PM Subject: Re: [WanderlodgeForum] EL Test Panel Leroy, Upper panel consists of two 3' pieces, one inverter (if the new inverter goes bad I'll install two), rheostat operates the upper panels, lower dash also has a rheostat. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Leroy Eckert wrote: >Curt, Glad you got it going. I was able to make my upper panel working also, broken wire at the upper rheostat and one of the inverters. My radio panel does not work. I expect a panel problem. That little test panel will help me confirm. > >Questions Please: >How many inverters power your upper panel? Is your upper panel two six foot pieces? Does the upper rheostat operate only the upper panel. >If you do not know please do not take the time to figure it out. As long as my inverters work I'll leave them alone. > >Still trying to determine how many of those elusive blue squares are in my bus.(only found 4 wired together on the upper rheostat) I refuse to tear out the TV and A/C ducts to trace the 110 side of those inverters. > >Thanks, > >Leroy Eckert >1990 WB-40 >Niceville, FL > > > > ----- Original Message ----- > From: Curt Sprenger > To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com > Sent: Tuesday, October 03, 2006 11:07 AM > Subject: [WanderlodgeForum] EL Test Panel > > > The EL Test Panel that Stephen Birtles made up and sent to me proved the > upper dash inverter is bad. I used jumpers and hooked up a new > inverter...the upper dash works great. > > THANKS STEPHEN! > > *Greg O'Connor*, please send me your Romoland mailing address. I'll mail > the EL Test Panel to you. I believe Leroy Eckert is to get the panel > after you. > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > > > [Non-text portions of this message have been removed] |
10-03-2006, 14:18
EL Test Panel
Leroy: Great CSNY quote! I saw them this summer.
Bruce |
10-03-2006, 15:51
EL Test Panel
Don,
Don't know. New one that works I got from Stephen. I question if two inverters are needed. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. dspithaler@... wrote: >Curt The one inverters in the top dash is that one of Stephens. My >original one had two of the blue cubes >Don >89 SP 36' >Butler, PA > > >Leroy, >Upper panel consists of two 3' pieces, one inverter (if the new inverter >goes bad I'll install two), rheostat operates the upper panels, lower >dash also has a rheostat. > >Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > >Leroy Eckert wrote: > > > >>Curt, Glad you got it going. I was able to make my upper panel working >> >> >also, broken wire at the upper rheostat and one of the inverters. My radio panel >does not work. I expect a panel problem. That little test panel will help me >confirm. > > >>Questions Please: >>How many inverters power your upper panel? Is your upper panel two six foot >> >> >pieces? Does the upper rheostat operate only the upper panel. > > >>If you do not know please do not take the time to figure it out. As long as >> >> >my inverters work I'll leave them alone. > > >>Still trying to determine how many of those elusive blue squares are in my >> >> >bus.(only found 4 wired together on the upper rheostat) I refuse to tear out >the TV and A/C ducts to trace the 110 side of those inverters. > > >>Thanks, >> >> > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > > > |
10-03-2006, 15:54
EL Test Panel
it was Buffalo Springfield with Stephen Stills and Neil Young
Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Leroy: Great CSNY quote! I saw them this summer. > > Bruce > |
10-04-2006, 01:05
EL Test Panel
Anyone have a black light and ???? LOL
Thanks, Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Stephen Birtles To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, October 03, 2006 10:54 PM Subject: [WanderlodgeForum] Re: EL Test Panel it was Buffalo Springfield with Stephen Stills and Neil Young Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Leroy: Great CSNY quote! I saw them this summer. > > Bruce > [Non-text portions of this message have been removed] |
