Fresh Water Tank Drain
10-04-2006, 05:01
I opened up the fresh water tank drain. Tank was full, has been draining
for 40 minutes and the tank is at half. Is this normally a slow process? Something that I should check for? -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. |
10-04-2006, 05:27
It's that slow on my 82 FC 35.
Kerry --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > I opened up the fresh water tank drain. Tank was full, has been draining > for 40 minutes and the tank is at half. Is this normally a slow process? > Something that I should check for? > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > |
10-04-2006, 06:33
Curt:
Mine takes a little over 1 hour to drain when full. Based upon recomendations of members I fill mine and use it regularly. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com Sent: Wednesday, October 04, 2006 12:01 PM Subject: [WanderlodgeForum] Fresh Water Tank Drain I opened up the fresh water tank drain. Tank was full, has been draining for 40 minutes and the tank is at half. Is this normally a slow process? Something that I should check for? -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
10-04-2006, 11:45
Leroy,
You mentioned other members reccomend using the tank regularly as opposed to running straight from the hose. Is this mainly to keep the tank water from getting stagnent? It sounds like a good idea to me as long as your pump can keep up. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Curt: > Mine takes a little over 1 hour to drain when full. Based upon recomendations of members I fill mine and use it regularly. > > Leroy Eckert > 1990 WB-40 > Niceville, FL > > > > > > ----- Original Message ----- > From: Curt Sprenger > To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com > Sent: Wednesday, October 04, 2006 12:01 PM > Subject: [WanderlodgeForum] Fresh Water Tank Drain > > > I opened up the fresh water tank drain. Tank was full, has been draining > for 40 minutes and the tank is at half. Is this normally a slow process? > Something that I should check for? > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > > > [Non-text portions of this message have been removed] > |
10-04-2006, 12:13
Gardner,
I do not remember the date, possibly two months ago, I left my pump on without water in the tank. I had drained it. Didn't do any harm but the belt fried for some reason. Thereafter, I was asked why I drained the tank, possible stagnation, I replied. The consensus was treated water holds well. Well water does not. Made sense to me so I have been filling the tank and using the pump. Water is replenished as needed. I cannot tell the difference in pressure. I do not hook up the hose unless needed. I do not have a gross weight problem either. Gross weight may be a consideration for your coach. Hope you have a good trip. Pop a top for me. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, October 04, 2006 6:45 PM Subject: [WanderlodgeForum] Re: Fresh Water Tank Drain Leroy, You mentioned other members reccomend using the tank regularly as opposed to running straight from the hose. Is this mainly to keep the tank water from getting stagnent? It sounds like a good idea to me as long as your pump can keep up. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Curt: > Mine takes a little over 1 hour to drain when full. Based upon recomendations of members I fill mine and use it regularly. > > Leroy Eckert > 1990 WB-40 > Niceville, FL > > > > > > ----- Original Message ----- > From: Curt Sprenger > To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com > Sent: Wednesday, October 04, 2006 12:01 PM > Subject: [WanderlodgeForum] Fresh Water Tank Drain > > > I opened up the fresh water tank drain. Tank was full, has been draining > for 40 minutes and the tank is at half. Is this normally a slow process? > Something that I should check for? > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
10-04-2006, 15:19
Took almost an hour to drain ours. Sounds about right.
Bob Lawrence 84 PT36 Tacoma, Wa. > I opened up the fresh water tank drain. Tank was full, has been draining > for 40 minutes and the tank is at half. Is this normally a slow process? > Something that I should check for? > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > |
10-05-2006, 01:08
Tank draining is a slow process on our FC coach. Reason for slow drain is
probably due to air having to travel back up the drain line periodically to break the vacuum in the tank. I've found that opening a hot and cold tap in the coach speeds up the process. I can hear a sucking sound when I do it so I think it is pulling air in backwards through the water pump. Regards, Eric 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > I opened up the fresh water tank drain. Tank was full, has been draining > for 40 minutes and the tank is at half. Is this normally a slow process? > Something that I should check for? > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > |
10-05-2006, 02:24
I know that the drain is not the largest valve to try to drain the tank, but if
you want to drain it quickly why not open the spigot outside in the basement compartment (Low Point drain) and drain the tank through that faucet? Actually you would be pumping it out using the water pump. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - WOO (http://www.wanderlodge.us) 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: Eric Johnson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, October 05, 2006 9:08 AM Subject: [WanderlodgeForum] Re: Fresh Water Tank Drain Tank draining is a slow process on our FC coach. Reason for slow drain is probably due to air having to travel back up the drain line periodically to break the vacuum in the tank. I've found that opening a hot and cold tap in the coach speeds up the process. I can hear a sucking sound when I do it so I think it is pulling air in backwards through the water pump. Regards, Eric 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger wrote: > > I opened up the fresh water tank drain. Tank was full, has been draining > for 40 minutes and the tank is at half. Is this normally a slow process? > Something that I should check for? > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > [Non-text portions of this message have been removed] |
10-21-2008, 06:55
My fresh water tank will not drain unless the pump is on, how do I
drain it otherwise? Chuck Harrison Akron, Ohio 90 SP36 |
10-21-2008, 10:22
Hi Chuck
I just open the drain to the ground & my tank will drain. I don't have to use my pump & if I did the water would go in to my black or gray tank Don Spithaler 89 SP 36' Butler, PA On Tue, Oct 21, 2008 at 2:55 PM, williamcharrison <"williamcharrison@yahoo.com"> wrote:
