Block Heaters
10-07-2006, 16:21
Block Heaters
I turned on the block heaters yesterday and tripped a circuit breaker. It
was a "solid" short tripping each time I turned the left heater on. The
wiring on our bird is run through a piece of hose. Pulling back the hose
showed that the wire insulation was brittle and missing in places. Each
heater has a connector so the power cords can be replaced independently of
the heaters. Holt Cat had the power cords so I spent the afternoon
replacing the power cords, installing a contactor so I could use a switch
with a safety cover to prevent the heaters from accidentally getting turned
on. If you plan to be in cold weather it might be worth a look at your
power cords. We will be in Nebraska or Wyoming at Christmas depending on
where our son is working.
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of eddiemoranii
Sent: Saturday, October 07, 2006 9:10 AM
Subject: [WanderlodgeForum] Re: Bluebird Support
>Now I am really excited about getting up to KY. (paying for it) and
picking up "Southern Comfort"!! It sounds like my neighbor wants
one now too. He says he knows alot about motorhomes and is already
envious.
Eddie Moran
--- In WanderlodgeForum@
yahoogroups.com, "Stephen Birtles"
> Bluebird does support older birds to the best of their ability and
> also the availabilty of parts
> Thats why Bennie Collier and Earl Davis and Jim Eldridge to name a
few
> are employed at Bluebird
> Call up Earl and ask him which birds he supports and he will tell
you
> all to the best of his ability
> Call up Bennie and ask him about the whatsits or thingamagig on
1975
> wanderlodge and you will get an answer.
> These answers may not be the one you want but an answer none the
less
> and most of the time it is the correct answer
> Blue Bird does support older vehicles as do other manufacturers
with
> knowledge of employees not because they have too
> We as owners have the good fortune of being able to source new and
> rebuilt parts from other sources when not available from
Wanderlodge
> Try that with with your 1990 ford and you end up at a scrapyard
with a
> set of wrenches pulling the used greasy rusty parts yourself
> Learn to live with it and adapt to the changes
> Stephen 77fc35
10-07-2006, 22:15
Block Heaters
Chuck, that is on my agenda for today- getting ready for the cold. Supposed
to get in teens this coming week, but warming up to 60s.
83 PT40
Livingston, Montana
12-18-2007, 02:40
Block Heaters
http://www.zerostart.com/
Stephen 77fc35
dupreeproducts.com
