air brake reservoir petcocks
04-23-2005, 14:34
Folks,
Although I've had my air brakes and air dryer serviced several times by BlueBird, I've never personally climbed under the coach to drain the reservoirs. Can some tell me where the drain petcocks are located on an LXi? TIA, David Brady '02 LXi "Smokey" Virginia, for now... |
04-23-2005, 15:57
Hi David,
You'll find one on each air tank. At the frame level, 3 toward the rear (forward of the transmission) and, if I remember correctly, one forward. Don't forget the 12VDC compressor tank in the bay area. There is a drain valve on each one. FWIW, I've never had more than a light mist from any of the main or aux. tanks as a well maintained air dryer pretty much keeps all the moisture out. The small, bay tank for the 12VDC collects more because there is no air dryer for that one. That one, on my coach, is located next to the 120Vac compressor but is not connected to it. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "david brady" wrote: > > Folks, > > Although I've had my air brakes and air dryer > serviced several times by BlueBird, I've never > personally climbed under the coach to drain the > reservoirs. Can some tell me where the drain > petcocks are located on an LXi? > > TIA, > David Brady > '02 LXi "Smokey" > Virginia, for now... |
