Allison Capacity
10-13-2006, 13:48
Allison Capacity
I am servicing the trans in my 90PT, and can't seem to find the
amount of fluid it takes. Also need the filter no., the decal that was on it went the way of the wind. Thanks, Steve Gureasko 90 WB40 Jus Chillin Ponchatoula, La. |
10-13-2006, 15:17
Allison Capacity
I had the same question, but found the answer within. Just dump the drain
pan into one gallon jugs to measure how many quarts came out, then put that many quarts back in. dandarst86fc35rbhuntleyil. >From: "patticake592000" <sgureasko@...> >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Allison Capacity >Date: Sat, 14 Oct 2006 01:48:58 -0000 > > I am servicing the trans in my 90PT, and can't seem to find the >amount of fluid it takes. > Also need the filter no., the decal that was on it went the way of >the wind. Thanks, > Steve Gureasko > 90 WB40 Jus Chillin > Ponchatoula, La. > > |
10-13-2006, 15:33
Allison Capacity
Why not simply ask a Allison Dealer?
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@...> wrote: > > I am servicing the trans in my 90PT, and can't seem to find the > amount of fluid it takes. > Also need the filter no., the decal that was on it went the way of > the wind. Thanks, > Steve Gureasko > 90 WB40 Jus Chillin > Ponchatoula, La. > |
10-14-2006, 01:48
Allison Capacity
Dan: You can buy a large container that has the quanity markings on
the side in qts, and gallons. It's made of plastic and you can see thru to the mark's. It's a good way to change the transmission fluid. You can change it three time's and get a different amount each time. It will depend on how long the coach has been sitting, if your changing the filter, how much fluid has drained down from the converter etc. Iam a believer in using this method to change the transmission fluid. Bob 93pt40 Illinois..... |
10-14-2006, 01:53
Allison Capacity
Steve: If your using FLEET GUARD filter's the # for the transmission
if HF-6243..............Engine oil is # LF-3333 Bob 93pt Illinois |
10-14-2006, 04:45
Allison Capacity
Steve,
Call Chad Blesso (916) 417-2439. He's an Allison Technician and a friend, and could tell you. Ron No. Ca. 85PT36 --- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@...> wrote: > > I am servicing the trans in my 90PT, and can't seem to find the > amount of fluid it takes. > Also need the filter no., the decal that was on it went the way of > the wind. Thanks, > Steve Gureasko > 90 WB40 Jus Chillin > Ponchatoula, La. > |
