Fuel blow back
10-14-2006, 10:03
Fuel blow back
Thats great news, Wallace- send us the link so we can order one.
Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
10-14-2006, 11:35
Fuel blow back
As with most of you, I have been drenched in diesel for years while fueling BB.
I finally found a solution!!! Eureka!!! West Marine, and probably other boating stores sells a collar which fits around the spout of the nozzle that ABSOLUTELY blocks blow back. I did it today for the first time; NOT A DROP SPILLED. This is used primarily aroung marinas because of fed. regs against spilling any fuel in water. It was less than $10 and you just put it in a baggie and keep it in the fuel door or wherever winds your clock. This is better than rags or towels because it has crystals that capture any overflow. Please do not send me any gifts or prizes for this valuable information; your dry clothes are thanks enough for me. Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] |
10-14-2006, 13:41
Fuel blow back
Do you have a link to this product?
Please do not send me any gifts or prizes for this valuable information; your dry clothes are thanks enough for me. I did several searches at west marine and did not find it. Dan --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > As with most of you, I have been drenched in diesel for years while fueling BB. I finally found a solution!!! Eureka!!! > > West Marine, and probably other boating stores sells a collar which fits around the spout of the nozzle that ABSOLUTELY blocks blow back. I did it today for the first time; NOT A DROP SPILLED. > > This is used primarily aroung marinas because of fed. regs against spilling any fuel in water. It was less than $10 and you just put it in a baggie and keep it in the fuel door or wherever winds your clock. > > This is better than rags or towels because it has crystals that capture any overflow. > > Please do not send me any gifts or prizes for this valuable information; your dry clothes are thanks enough for me. > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > > [Non-text portions of this message have been removed] > |
10-14-2006, 14:31
Fuel blow back
http://www.westmarine.com
search FuelKleen absorbing collar Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WB41 |
10-14-2006, 14:43
Fuel blow back
FuelKleen Splash Absorbing Collar
Manufacturer - CENTEK INDUSTRIES MFG Park # 8-FK-1-R West Marine Number 3683166 Price: $6.99 each "Splash" was the search term that worked, all the obvious ones - fuel, fill, spill, etc.... couldn't locate it. Good luck, TJ Hannink Goldibox - 1987 Vanagon Camper, Wolfsburg Edition 1981 Bluebird Wanderlodge, FC-33SB Full-timing in Paradis, Louisiana http://groups.yahoo.com/group/wolfsburg_campers http://groups.yahoo.com/group/FC_wanderlodge ----- Original Message ---- From: Dan Weaver To: WanderlodgeForum@yahoogroups.com Sent: Saturday, October 14, 2006 8:41:05 PM Subject: [WanderlodgeForum] Re: Fuel blow back Do you have a link to this product? Please do not send me any gifts or prizes for this valuable information; your dry clothes are thanks enough for me. I did several searches at west marine and did not find it. Dan --- In WanderlodgeForum@ yahoogroups. com, Wallace Craig > > As with most of you, I have been drenched in diesel for years while fueling BB. I finally found a solution!!! Eureka!!! > > West Marine, and probably other boating stores sells a collar which fits around the spout of the nozzle that ABSOLUTELY blocks blow back. I did it today for the first time; NOT A DROP SPILLED. > > This is used primarily aroung marinas because of fed. regs against spilling any fuel in water. It was less than $10 and you just put it in a baggie and keep it in the fuel door or wherever winds your clock. > > This is better than rags or towels because it has crystals that capture any overflow. > > Please do not send me any gifts or prizes for this valuable information; your dry clothes are thanks enough for me. > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
10-14-2006, 15:49
Fuel blow back
Is this the product that worked for you?
http://tinyurl.com/uakjh (tiny url for long url below) http://www.westmarine.com/webapp/wcs/sto...earchView? catalogId=10001&Ntx=mode% 2Bmatchallpartial&keyword=FuelKleen+Splash+Absorbing+Collar&Ntt=FuelK leen+Splash+Absorbing+Collar &N=0&storeId=10001&Ntk=All_2&ddkey=SiteSearch Dan --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > As with most of you, I have been drenched in diesel for years while fueling BB. I finally found a solution!!! Eureka!!! > > West Marine, and probably other boating stores sells a collar which fits around the spout of the nozzle that ABSOLUTELY blocks blow back. I did it today for the first time; NOT A DROP SPILLED. > > This is used primarily aroung marinas because of fed. regs against spilling any fuel in water. It was less than $10 and you just put it in a baggie and keep it in the fuel door or wherever winds your clock. > > This is better than rags or towels because it has crystals that capture any overflow. > > Please do not send me any gifts or prizes for this valuable information; your dry clothes are thanks enough for me. > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > > [Non-text portions of this message have been removed] > |
10-15-2006, 02:39
Fuel blow back
http://www.mycelx.com/products/marine/fuelkleen.asp
Ron No. California 85PT36 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Thats great news, Wallace- send us the link so we can order one. > > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] > |
