$600 radiator
10-14-2006, 15:29
$600 radiator
Hi group,
I can't seem to find the thread that stated someone got a new radiator
for $600.
I am thinking about replacing mine and was wondering where I could get
a new one for this price. I know I saw it on one of these forums, so
thought I would ask here first.
Thanks.
Bob Lawrence
84 PT36
Tacoma, Wa.
10-15-2006, 01:56
$600 radiator
Hi Bob
You can give these guys a call. http://www.generalradiator.com/ I
have used them for 3 rads.
Allen Powell
88 PT40
-- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence"
> Hi group,
radiator
> for $600.
get
so
> Thanks.
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
10-15-2006, 05:17
$600 radiator
Neil, can you tell us the brand of motor you used? On my coach, the rebuild
kit for the Danfoss motor is no longer available. I'm sure other early PTs will
be needing that eventually.
83 PT40
Livingston, Montana
10-15-2006, 06:16
$600 radiator
A couple of years ago, the seal was leaking on my motor shaft. I bought the
last rebuild kit and it was a terrible job for Ralph, Bim and myself to get
that motor out without taking off the radiator. It can be done, but I think I
would trade the coach if i had to do it again.
83 PT40
Livingston, Montana
10-15-2006, 06:23
$600 radiator
The _core_ for my new radiator was around $800. The labor to remove
and replace the radiator was over $900. There are some charges for
putting the old 'ends' on the new core. If you're paying a radiator
service, expect charges above $2000 --- possibly way above. (Note
that my coach also has a charge-air radiator that had to be removed
and replaced at the same time even though it was not serviced.)
Depending on the size core needed for your coach, it may be less
expensive than mine. But unless you're doing a _lot_ of the work
yourself, it will most certainly cost much more than $600...
aeonix1@...
'95 Bluebird Wanderlodge WBDA 42'
El Sobrante, CA
On Oct 14, 2006, at 8:29 PM, Bob Lawrence wrote:
> Hi group,
> for $600.
> Thanks.
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
10-15-2006, 07:22
$600 radiator
Thanks, Allen,
I've sent them an email.
Bob
> Hi Bob
> Allen Powell
> 88 PT40
> > Hi group,
> radiator
> > for $600.
could
> get
forums,
> so
> > Thanks.
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
10-15-2006, 07:25
$600 radiator
Thanks, Pete.
Since we will be fulltiming in 11 months, thought about replacing
the rad, just cause it's over 22 years old. Where did you get the
core?
Bob Lawrence
84 PT36
Tacoma, Wa.
remove
for
radiator
removed
> Pete Masterson
> aeonix1@...
> El Sobrante, CA
> > Hi group,
radiator
> > for $600.
could get
forums, so
> > Thanks.
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
10-15-2006, 07:43
$600 radiator
I think it came from General Radiator (someone else mentioned them).
I contacted General Radiator and they gave me the name of a radiator
shop locally that uses their products. (I then checked out the
reputation of the local shop as well.) While labor and overhead rates
tend to be high in this part of California, it wasn't practical for
me to travel any distance for this work... so I went ahead and had
the radiator core replaced, the cooling system completely serviced,
and the chassis air serviced. (The previous owner had repaired and
upgraded it to Freon 134a.) With all the work that was done, the bill
came to nearly $4000.... but they had given me a pretty fair estimate
to start with and I was aware that this is one of the more expensive
things to upgrade. Besides, a new radiator is a better bet than to
risk a $20,000 engine rebuild.
The original radiator was heavily clogged with oily-dirt. I notice
that the oily fumes from the breather tube (also known as the
"slobber tube") are drawn under the edge of the coach and right back
into the fan when the coach is sitting at idle. On my "to do" list is
to rig up an extension to the breather tube so that it is routed away
from its current location. Unfortunately, I'm not too keen on routing
it to the rear bumper (to coat the front of my toad) so I'm still
pondering the possibilities ... probably I'll extend it under the
engine to the curb side...
aeonix1@...
El Sobrante, CA
On Oct 15, 2006, at 12:25 PM, Bob Lawrence wrote:
> Thanks, Pete.
> core?
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
> remove
> for
> radiator
> removed
>> Pete Masterson
>> aeonix1@...
>> El Sobrante, CA
>>> Hi group,
> radiator
>>> for $600.
> could get
> forums, so
>>> Thanks.
>>> Bob Lawrence
>>> 84 PT36
>>> Tacoma, Wa.
> Yahoo! Groups Links
10-15-2006, 08:21
$600 radiator
Hi Bob, I also have an 84 PT36 so I thought that I would share my sad
experience with the radiator on my rig. At about 140K miles the hydraulic
radiator fan motor broke at highway speed. That, of course freed that very
large propeller to fly into the radiator. By the time I was finished
repairing the damage the total was we above the $4000 level. The reason for
retelling this story is to relate that we (dealer and myself) were very
surprise to learn that BB had used a sleeve bearing type of hyd motor with
the manufacturer said was not of adequate capacity to handle the load of
that very large fan. At that point they said failure was inevitable. My
solution was to replace the motor with one using and roller (or ball, I
forget) bearing. You may want to consider my experience when you are in
there.
Regards,
Neil LeKander
Author “The RVer’s Ultimate Survival Guide”
author@...
Thanks, Pete.
core?
Bob Lawrence
84 PT36
Tacoma, Wa.
remove
for
radiator
removed
> Pete Masterson
> aeonix1@...
> El Sobrante, CA,_._,___
10-15-2006, 10:05
$600 radiator
Hi Ernie, I went into the rather large file on repairs and found that the
described work was done in 5-2002, at that time the hyd motor cost $983 and
the fan $323 and the rad core $1335 plus air frt shipping. The p/n listed
for the motor is 1260918 but there is no clue as to the manufacturer, sorry.
Needless to say there was a ton of labor involved in this effort, that’s why
I suggest that this is the time to consider the change.
Regards,
Neil LeKander
author@...
will
