Propane heaters question 82 PT40
10-15-2006, 09:48
Kevin, open up your outside refer panel. All the gas valve controls are
located there. Keep us posted. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
10-15-2006, 12:14
I have an 82 PT 40 that none of the propane heaters will operate. When
I turn up the thermostat up I can hear the electronic igniters and the fans blow only cold air. This is the case for all heaters so I assume there may be a master gas value or something somewhere that needs to be turned on. All my other gas appliances do operate normal. BTW, this is a great site, and I learn something new about my bird everyday, Thanks for your help, Kevin Ford 82 PT 40, Richmond TX |
10-15-2006, 20:34
Thanks Erine! I will check these values....
Kevin Ford 82 PT40 Richmond, TX --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Kevin, open up your outside refer panel. All the gas valve controls are > located there. Keep us posted. > > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] > |
10-16-2006, 00:03
I am having the same problem with my 86 pt 40 looking to a solution.
----- Original Message ---- From: Kevin Ford To: WanderlodgeForum@yahoogroups.com Sent: Sunday, October 15, 2006 8:14:37 PM Subject: [WanderlodgeForum] Propane heaters question 82 PT40 I have an 82 PT 40 that none of the propane heaters will operate. When I turn up the thermostat up I can hear the electronic igniters and the fans blow only cold air. This is the case for all heaters so I assume there may be a master gas value or something somewhere that needs to be turned on. All my other gas appliances do operate normal. BTW, this is a great site, and I learn something new about my bird everyday, Thanks for your help, Kevin Ford 82 PT 40, Richmond TX [Non-text portions of this message have been removed] |
10-16-2006, 03:37
Kevin, Fred, and I'm sure many others......
With cold weather coming, it's very timely for this topic to arise again! The Suburban propane heaters each have individual propane valves in the lines going into the heaters, right on the side of the heaters. You will have to open the heater vents or other heater front or side access doors to see them. Make sure they are on, as well as the master propane valve outside. Also, make sure the master gas alarm in the coach is on or propane will not flow. You may then have to cycle the heater thermostats several times to get the air out of the lines after long periods of no use. The Suburban heaters last a very long time, but they do need cleaning every now and then. If they don't light after checking to make sure all the valves are open and gas alarm is on, then it is very common to have the igniters, burners and air inlets build up dirt over time, even from lack of use. First place to check is the electronic igniter which will build up with soot. You can remove the sight glass on the front of the heaters and brush the igniter with an old toothbrush. Replace the sight glass and try lighting again. You should probably see a slightly stronger spark from the igniter when attempting to light after that. If that doesn't get them working, then you will have to do a little more cleaning. Seems like Ralph or Jeff did a good write-up on this topic last year about this same time. Maybe he can re-post it or we can find it in the archives. Also check the air inlets/exhaust ports from the outside to make sure that mud daubers or other critters have not gotten into them and cut down the flow of intake or exhaust air, thereby preventing proper ignition. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX P.S. Fred - I can verify the back two worked when your coach left Texas, because I had used them in sub-freezing weather in January (or February?) last year! Typically we only ever used the center one and it kept the whole coach comfortable. Of course, that was in Texas! ;-) --- In WanderlodgeForum@yahoogroups.com, fred brown wrote: > > I am having the same problem with my 86 pt 40 looking to a solution. > > > ----- Original Message ---- > From: Kevin Ford > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, October 15, 2006 8:14:37 PM > Subject: [WanderlodgeForum] Propane heaters question 82 PT40 > > I have an 82 PT 40 that none of the propane heaters will operate. When > I turn up the thermostat up I can hear the electronic igniters and the > fans blow only cold air. This is the case for all heaters so I assume > there may be a master gas value or something somewhere that needs to be > turned on. All my other gas appliances do operate normal. > > BTW, this is a great site, and I learn something new about my bird > everyday, > > Thanks for your help, > Kevin Ford > 82 PT 40, Richmond TX > > > > > [Non-text portions of this message have been removed] > |
10-16-2006, 04:23
Mike thanks i will give them a good cleaning, this is the first time to use the
furnace ,this spring in FL. not necessary. ps: i have had a couple of request for info on the bus thanks to you for your help ----- Original Message ---- From: mbulriss <mbulriss@...> To: WanderlodgeForum@yahoogroups.com Sent: Monday, October 16, 2006 11:37:14 AM Subject: [WanderlodgeForum] Re: Propane heaters question 82 PT40 Kevin, Fred, and I'm sure many others...... With cold weather coming, it's very timely for this topic to arise again! The Suburban propane heaters each have individual propane valves in the lines going into the heaters, right on the side of the heaters. You will have to open the heater vents or other heater front or side access doors to see them. Make sure they are on, as well as the master propane valve outside. Also, make sure the master gas alarm in the coach is on or propane will not flow. You may then have to cycle the heater thermostats several times to get the air out of the lines after long periods of no use. The Suburban heaters last a very long time, but they do need cleaning every now and then. If they don't light after checking to make sure all the valves are open and gas alarm is on, then it is very common to have the igniters, burners and air inlets build up dirt over time, even from lack of use. First place to check is the electronic igniter which will build up with soot. You can remove the sight glass on the front of the heaters and brush the igniter with an old toothbrush. Replace the sight glass and try lighting again. You should probably see a slightly stronger spark from the igniter when attempting to light after that. If that doesn't get them working, then you will have to do a little more cleaning. Seems like Ralph or Jeff did a good write-up on this topic last year about this same time. Maybe he can re-post it or we can find it in the archives. Also check the air inlets/exhaust ports from the outside to make sure that mud daubers or other critters have not gotten into them and cut down the flow of intake or exhaust air, thereby preventing proper ignition. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX P.S. Fred - I can verify the back two worked when your coach left Texas, because I had used them in sub-freezing weather in January (or February?) last year! Typically we only ever used the center one and it kept the whole coach comfortable. Of course, that was in Texas! ;-) --- In WanderlodgeForum@ yahoogroups. com, fred brown wrote: > > I am having the same problem with my 86 pt 40 looking to a solution. > > > ----- Original Message ---- > From: Kevin Ford > To: WanderlodgeForum@ yahoogroups. com > Sent: Sunday, October 15, 2006 8:14:37 PM > Subject: [WanderlodgeForum] Propane heaters question 82 PT40 > > I have an 82 PT 40 that none of the propane heaters will operate. When > I turn up the thermostat up I can hear the electronic igniters and the > fans blow only cold air. This is the case for all heaters so I assume > there may be a master gas value or something somewhere that needs to be > turned on. All my other gas appliances do operate normal. > > BTW, this is a great site, and I learn something new about my bird > everyday, > > Thanks for your help, > Kevin Ford > 82 PT 40, Richmond TX > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
10-16-2006, 05:52
Thanks MIke. This is a "Great" trouble shooting write-up!!
Kevin --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Kevin, Fred, and I'm sure many others...... > > With cold weather coming, it's very timely for this topic to arise again! > > The Suburban propane heaters each have individual propane valves in > the lines going into the heaters, right on the side of the heaters. > You will have to open the heater vents or other heater front or side > access doors to see them. Make sure they are on, as well as the > master propane valve outside. Also, make sure the master gas alarm in > the coach is on or propane will not flow. You may then have to cycle > the heater thermostats several times to get the air out of the lines > after long periods of no use. > > The Suburban heaters last a very long time, but they do need cleaning > every now and then. If they don't light after checking to make sure > all the valves are open and gas alarm is on, then it is very common to > have the igniters, burners and air inlets build up dirt over time, > even from lack of use. First place to check is the electronic igniter > which will build up with soot. You can remove the sight glass on the > front of the heaters and brush the igniter with an old toothbrush. > Replace the sight glass and try lighting again. You should probably > see a slightly stronger spark from the igniter when attempting to > light after that. If that doesn't get them working, then you will > have to do a little more cleaning. Seems like Ralph or Jeff did a > good write-up on this topic last year about this same time. Maybe he > can re-post it or we can find it in the archives. > > Also check the air inlets/exhaust ports from the outside to make sure > that mud daubers or other critters have not gotten into them and cut > down the flow of intake or exhaust air, thereby preventing proper > ignition. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > P.S. Fred - I can verify the back two worked when your coach left > Texas, because I had used them in sub-freezing weather in January (or > February?) last year! Typically we only ever used the center one and > it kept the whole coach comfortable. Of course, that was in Texas! ;-) > > > > > --- In WanderlodgeForum@yahoogroups.com, fred brown > wrote: > > > > I am having the same problem with my 86 pt 40 looking to a solution. > > > > > > ----- Original Message ---- > > From: Kevin Ford > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, October 15, 2006 8:14:37 PM > > Subject: [WanderlodgeForum] Propane heaters question 82 PT40 > > > > I have an 82 PT 40 that none of the propane heaters will operate. When > > I turn up the thermostat up I can hear the electronic igniters and the > > fans blow only cold air. This is the case for all heaters so I assume > > there may be a master gas value or something somewhere that needs to be > > turned on. All my other gas appliances do operate normal. > > > > BTW, this is a great site, and I learn something new about my bird > > everyday, > > > > Thanks for your help, > > Kevin Ford > > 82 PT 40, Richmond TX > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
