Water leak...
10-16-2006, 23:15
Water leak...
We finally got some much needed rain here in central TX yesterday. I
just happened to be out in our bird getting things ready for our
upcomming trip and I noticed a wet spot on the capret on top of the
dash just in front of the co-pilot's seat. After opening up some
panels in the front overhead cabinets and removing the speaker above
the entry door I think I got the area where water was coming in pretty
well narrowed down. I thought it was where the awning rail was screwed
down. After it stopped raining and had dried out, I used a water
bottle to wet the area around the awning rail...no water insde...then
I noticed the plastic/fiberglass cowling at the front end of the rails
that run the length of the roof looked cracked in a couple places and
like the cowling might be lifting up a little. I wet that area and
presto....there was water inside again. If I get a chance today I am
going to pull that cowling off and clean off the old silicone and
re-seal everything.
Would it be ok to use an exterior silicone adhesive caulk from home
depot or should I use something more specialized for up on the roof? I
think part of the cover is on the steel part of the roof and part is
over the fiberglass cap. Also, since the covers are starting to crack,
I am worried that when I screw them back down they might crack further
or break...any ideas other than washers to help distribute the force?
I'm sure it would be expensive to replace them as they are painted. I
thought about applying some resin or something around the cracks then
redrilling the holes. The cracks are only around the screw holes.
Sorry for the long post...Would appreciate any tips.
John C.
98 Wanderlodge LX
10-17-2006, 00:38
Water leak...
John: I would use NP-1 chemical based caulking. We caulk condo corridors with
NP-1. It is available at most Ace hardware stores and paint stores. You will
need Zylol to clean up. It it paintable and comes in several colors. If the
screw holes are countersunk I would use washers.
If you use this product do not expect to remove the cap without damage in the
future, particularly if you apply the caulk under the cap before installation.
I guarantee it will stop the leak.
Leroy Eckert
1990 WB-40
Niceville, FL
Smoke N Mirrors
Sent: Tuesday, October 17, 2006 6:15 AM
Subject: [WanderlodgeForum] Water leak...
re-seal everything.
John C.
98 Wanderlodge LX
10-17-2006, 01:46
Water leak...
Hi John,
On my '99 LXi,the cowling or shroud you are speaking of is just a
trim to aerodynamically end the front of the rail. There is no
ssealant needed between the bottom edge of the shroud and the roof.
The only sealing needed is for the mounting screws on the shroud and
for the end of the rail/brackets under the shroud. The water flows
freely under mine and does not leak into the coach. Your model may
be different but looking at the pictures on the Vintage Birds
History page, they appeay similar. Obviously your test shows that
yours does leak so I would suspect something under the shroud.
Anyone have further insight? Personally, I would choose a special
purpose sealant as I'm not a fan of silicone caulk. Again, someone
with more knowledge can hopefully add to this for you.
Rich D. '99LXi43' CT
--- In WanderlodgeForum@yahoogroups.com, "John"
I
above
pretty
screwed
insde...then
rails
am
> re-seal everything.
roof? I
is
crack,
further
force?
painted. I
then
> John C.
> 98 Wanderlodge LX
10-17-2006, 02:12
Water leak...
John I would seal the individual mounting holes with Urethane or Buytal. If
the mounting holes in the fiberglass cap have small radiating stress cracks
you could use a self-leveling sealant like Dicor 501 lap sealant or Sikoflex
On 17/10/06, g_man1146 wrote:
> Hi John,
> "John"
> I
> above
> pretty
> screwed
> insde...then
> rails
> and
> am
> > re-seal everything.
> roof? I
> is
> crack,
> further
> force?
> painted. I
> then
> > John C.
> > 98 Wanderlodge LX
Rob, Sue & Merlin Robinson
94 WLWB
10-17-2006, 02:28
Water leak...
I dont know much about caulk but I was watching a neighbor work on
engines for John Force and he used Homedepot style clear silicon
sealent betwen the manifolds. If you chose a specility product keep
in mind RV sealants may cater to fiberglass SOB's and may not work on
our Steel SOB's. Some one posted that the side walls get up to
135Deg. in the sun, the roof may get hotter
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "g_man1146"
> Hi John,
yesterday.
> I
> above
> pretty
> screwed
> insde...then
> rails
> and
> am
> > re-seal everything.
home
> roof? I
> is
> crack,
> further
> force?
> painted. I
> then
> > John C.
> > 98 Wanderlodge LX
10-17-2006, 02:48
Water leak...
Hi Greg. Dicor 501 can be used on both fiberglass and metal surfaces. It is
primarily used to seal joints between rubber roofs and fiberglass/metal
surfaces.
> GregoryO'Connor
> 94ptRomolandCa
> "g_man1146"
> > Hi John,
> and
> "John"
> yesterday.
> > I
> the
> > above
> > pretty
> > screwed
> > insde...then
> > rails
> > and
> > am
> > > re-seal everything.
> home
> > roof? I
> > is
> > crack,
> > further
> > force?
> > painted. I
> > then
> > > John C.
> > > 98 Wanderlodge LX
94 WLWB
10-17-2006, 04:36
Water leak...
Rob,
Where do you buy Buytal? I did some internet searches
an the best I can come up with is ebay.
Thanks,
David B
'02 LXi, Smokey
Va
10-17-2006, 05:08
Water leak...
search on butyl sealant
some canajuns cantspel
Stephen 77fc35 have a great day rob
--- In WanderlodgeForum@yahoogroups.com, David Brady wrote:
> Rob,
> Thanks,
> David B
> '02 LXi, Smokey
> Va
Buytal. If
stress cracks
or Sikoflex
10-17-2006, 05:22
Water leak...
for the fasteners you can use small wellnuts or closed rivnuts and
machine screws
Stephen 77fc35
surfaces. It is
> surfaces.
> > GregoryO'Connor
> > 94ptRomolandCa
> > --- In
> > "g_man1146"
> > wrote:
> > > Hi John,
> > and
> > > --- In
> > "John"
> > yesterday.
> > > I
> > the
> > > above
> > > pretty
> > > screwed
> > > insde...then
> > > rails
> > > and
> > > am
> > > > re-seal everything.
> > home
> > > roof? I
> > > is
> > > crack,
> > > further
> > > force?
> > > painted. I
> > > then
> > > > John C.
> > > > 98 Wanderlodge LX
> 94 WLWB
10-17-2006, 11:30
Water leak...
NEVER never use silicone on the exterior of a motorhome. Period!! It
will shrink and pull away. The factories use all different kinds of
sealants. The caulk de jour appears to be Sikaflex 221. Fleetwood and
Newmar both use this product. It is a polyurethane. I buy mine at a
body shop supply house.
Bruce
1988 FC35
