Air Step
04-24-2005, 05:41
Air Step
We returned home after over three months on the road.
The Bird performed nearly perfectly, thanks to all who helped us
in our first year of ownership.
We did not read the forum during that time,
Surprized to see that it self destructed.
But we will never give up on the Bird or asking questions.
We have a Clippard dealer near our home that has seals for the air
step cylinder.
But we are confused about the air control switch.
Who is the manufacturer?? Is there a gasket and seal kit available??
We think a solinoid is hanging up intermittently.
Thanks Again,
Bill 88 FC Michigan
04-24-2005, 05:49
Air Step
original was made by ARO now owned by parker-hannifin all parts still
available .Best bet is to remove solenoid and take it to the "Parker
Hannifin Store " and let them match it up
Stephen 77fc35
http://www.capeinnovation.com
--- In WanderlodgeForum@yahoogroups.com, "pattypape"
> step cylinder.
> Thanks Again,
> Bill 88 FC Michigan
04-24-2005, 05:50
Air Step
Hannifin Store " in most major cities and let them match it up
Stephen 77fc35
> step cylinder.
> Thanks Again,
> Bill 88 FC Michigan
04-24-2005, 08:30
Air Step
Bill,
I had trouble with mine and had a local industrial repair company
overhaul the air cylinder. Took about an hour and they charged me 40
bucks. When that didn't fix it, I got a replacement air valve from
Randy DuPree at DuPree products in Florida.
The air valve didn't look like the original, but was easy to
install and now the steps work perfectly. I did get the wires hooked
up backwards, but that was easy to tell I'd made a mistake when I
opened the door and the steps retracted. LOL After switching the
wires around, it worked fine.
George Witt
81 FC 35
Lincoln, Nebraska
> step cylinder.
> Thanks Again,
> Bill 88 FC Michigan
04-24-2005, 12:28
Air Step
Bill,
I will be curious to see your solution, as I have an 88 with a similar
intermitant step
problem .
One thing Ralph suggested was to remove the airlines by the step and shoot them
full
of a silicon lubricant. I did this once, and it did seem to help, but I did it
in sub zero
weather, and need to take another shot at it as i was so cold...i didnt do a
great job.
Another recomendation was to clip the wires that run to a weight sensor
directly
beneath the door and above the step. I guess this was an unnecessary saftey
feature
that can go bad and effect step opperations. Its intent was to keep the step
from
opening or closing when weight is on it.???
anyway ..please keep me informed as too your solution, as I wouldnt doubt our
same
vintage coaches have the same problem.....I will let you know if I get mine
working as
well.
ps I have dealt with a few other issues on my 88 that ii would be happy to
discuss..
1.overheating generator
2.oil leeks
3.throttle spring slippage
4. throtte position sensor....(controling transmisions ability to shift out of
park)
5..and many more.
thanks
mark walk
88fc
so caL
--- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote:
> Bill,
> George Witt
> 81 FC 35
> Lincoln, Nebraska
> > step cylinder.
> > Thanks Again,
> > Bill 88 FC Michigan
04-24-2005, 23:46
Air Step
i have the air valves in stock .randy@... owner
http://www.dupreeproducts.com
Sent: Sunday, April 24, 2005 4:30 PM
Subject: [WanderlodgeForum] Re: Air Step
Bill,
George Witt
81 FC 35
Lincoln, Nebraska
> step cylinder.
> Thanks Again,
> Bill 88 FC Michigan
Yahoo! Groups Links
a.. To visit your group on the web, go to:
11-16-2005, 20:40
Air Step
The cylinder is ok- it sounds more like the valve. I can put my finger on the
exhaust part and feel air coming out. Ernie- if an oring will fix it- thats
my kinda fix
11-17-2005, 00:59
Air Step
Ernie:
The control valve could be passing air through the exhaust muffler, meaning
the spool is not seating fully or shifting fully. Of course an o-ring on
the spool or chamber could be bad too. Lots of stuff down there that can
leak. Another leaking point is the small cylinder that locks the step in
the out position. The cylinder rod gets bent and causes wear on the gland
nut and seals.
Safe travels,
01-03-2006, 06:56
Air Step
Clear DayJeff Miller, do you or anyone else know if the info on air step at the
Vintage Bird "Fixes" Site about I.R. "Alpha Valve" being interchangeable with
Clippar Valve on "older" Birds (including my 88FC) is correct? At the time
price was listed as $88.00 plus fittings.
Air leak is on end facing curb. Thanks for any insight you may be able to
offer, John Barry 88FC
01-03-2006, 14:40
Air Step
I have the valves, I'll email you.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "The Whistleworks"
step at the Vintage Bird "Fixes" Site about I.R. "Alpha Valve" being
interchangeable with Clippar Valve on "older" Birds (including my
88FC) is correct? At the time price was listed as $88.00 plus
fittings.
be able to offer, John Barry 88FC
