Annoying Warning Buzzer
10-19-2006, 15:01
We're on our way to the Southwest rally in Buellton. Today we drove down to
Morro Bay. Most of the way it was pretty uneventful -- toad tracking well (first time on the road with it) and the SMI breaking system seems ok, but a little sensitive (I've adjusted it to come on much less frequently.) However, about 60 miles north of Morro Bay, a warning buzzer came on -- but no warning light. We stopped and checked everything. Oil pressure OK, no water in fuel, air is up, temperatures are all OK. NO WARNING LIGHTS are on. Buzzer keeps right on buzzing... Nothing I checked or changed had any effect on the buzzer (short of taking a hammer to it -- which I was seriously considering if I could get to it). I've heard this same buzzer each time I start up ... a couple of buzzers sound until the air is "up" (and several warning lights cycle at start up) then all the lights go out ... and now this one buzzer remains. Thank God it goes off when the ignition is cut... Any ideas? (I'll be asking for help at Buellton!!) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Morro Bay, CA |
10-19-2006, 15:22
Make sure your jacks are all in the travel position. If one has
dropped a little as you go down the road, the sensor may go on and off. Al, Kathy, Alfred & Daniel Johnson '96 BMC B100 Mandeville, Louisiana Heading to Houston, Tx this weekend. --- In WanderlodgeForum@yahoogroups.com, "Aeonix Publishing Group" > > We're on our way to the Southwest rally in Buellton. Today we drove down to Morro Bay. > Most of the way it was pretty uneventful -- toad tracking well (first time on the road with > it) and the SMI breaking system seems ok, but a little sensitive (I've adjusted it to come on > much less frequently.) > > However, about 60 miles north of Morro Bay, a warning buzzer came on -- but no warning > light. > > We stopped and checked everything. Oil pressure OK, no water in fuel, air is up, > temperatures are all OK. NO WARNING LIGHTS are on. Buzzer keeps right on buzzing... > > Nothing I checked or changed had any effect on the buzzer (short of taking a hammer to it > -- which I was seriously considering if I could get to it). > > I've heard this same buzzer each time I start up ... a couple of buzzers sound until the air > is "up" (and several warning lights cycle at start up) then all the lights go out ... and now > this one buzzer remains. Thank God it goes off when the ignition is cut... > > Any ideas? (I'll be asking for help at Buellton!!) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Morro Bay, CA > |
10-19-2006, 16:57
If you have a wire schematic for your bus you could disable each
warning buzzer relay until that one goes out then you will know what it buzzes for. I wonder if it goes off if you disconnect the toad electrical and SMI system???? Tim and I will be in Buellton Noon Friday, look forward to seeing you guys there GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Aeonix Publishing Group" > > We're on our way to the Southwest rally in Buellton. Today we drove down to Morro Bay. > Most of the way it was pretty uneventful -- toad tracking well (first time on the road with > it) and the SMI breaking system seems ok, but a little sensitive (I've adjusted it to come on > much less frequently.) > > However, about 60 miles north of Morro Bay, a warning buzzer came on -- but no warning > light. > > We stopped and checked everything. Oil pressure OK, no water in fuel, air is up, > temperatures are all OK. NO WARNING LIGHTS are on. Buzzer keeps right on buzzing... > > Nothing I checked or changed had any effect on the buzzer (short of taking a hammer to it > -- which I was seriously considering if I could get to it). > > I've heard this same buzzer each time I start up ... a couple of buzzers sound until the air > is "up" (and several warning lights cycle at start up) then all the lights go out ... and now > this one buzzer remains. Thank God it goes off when the ignition is cut... > > Any ideas? (I'll be asking for help at Buellton!!) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Morro Bay, CA > |
10-20-2006, 03:13
Just a thought, you are on your way to the Southwest Rally and a
mysterious warning buzzer is going off!!!!!That coach has some major abilities Greg --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > If you have a wire schematic for your bus you could disable each > warning buzzer relay until that one goes out then you will know what > it buzzes for. I wonder if it goes off if you disconnect the toad > electrical and SMI system???? > > Tim and I will be in Buellton Noon Friday, look forward to seeing you > guys there > GregoryO'Connor > 94ptRomolandCa > > > --- In WanderlodgeForum@yahoogroups.com, "Aeonix Publishing Group" > > > > > We're on our way to the Southwest rally in Buellton. Today we drove > down to Morro Bay. > > Most of the way it was pretty uneventful -- toad tracking well > (first time on the road with > > it) and the SMI breaking system seems ok, but a little sensitive > (I've adjusted it to come on > > much less frequently.) > > > > However, about 60 miles north of Morro Bay, a warning buzzer came > on -- but no warning > > light. > > > > We stopped and checked everything. Oil pressure OK, no water in > fuel, air is up, > > temperatures are all OK. NO WARNING LIGHTS are on. Buzzer keeps > right on buzzing... > > > > Nothing I checked or changed had any effect on the buzzer (short of > taking a hammer to it > > -- which I was seriously considering if I could get to it). > > > > I've heard this same buzzer each time I start up ... a couple of > buzzers sound until the air > > is "up" (and several warning lights cycle at start up) then all the > lights go out ... and now > > this one buzzer remains. Thank God it goes off when the ignition is > cut... > > > > Any ideas? (I'll be asking for help at Buellton!!) > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > aeonix1@ > > On the road at Morro Bay, CA > > > |
10-20-2006, 03:30
Indeed, I'm becomming more and more impressed with the abilities of this coach
as I gain experience with it. Tried unhooking the SMI (It plugs into the cigarette lighter) -- not it. I've looked over the wiring diagram trying to figure out which fuse and/or relay is involved. I'll try pulling fuses/relays this morning before I leave Moro Bay. (It's less than 2 hours to Buellton). The buzzers listed include - Stop Engine Buzzer (fuse also covers Tran Temp/Step Lgt) - Low Air Buzzer (but that fuse also includes "Upr Dash Ignition" and "Quick Start" At this point, I'm pretty sure that it's the Stop Engine Buzzer -- but like I said, there's no warning lights and all the gauges read in the normal range. At the time the buzzer came on, oil pressure was at the low end of the normal range, reading about 40 psi. Later on, the oil pressure was reading a more typical 60-70 psi -- yet the buzzer continued to sound. (There is adequate oil in the engine.) --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" wrote: > > Just a thought, you are on your way to the Southwest Rally and a > mysterious warning buzzer is going off!!!!!That coach has some major > abilities > Greg > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > If you have a wire schematic for your bus you could disable each > > warning buzzer relay until that one goes out then you will know > what > > it buzzes for. I wonder if it goes off if you disconnect the toad > > electrical and SMI system???? > > > > Tim and I will be in Buellton Noon Friday, look forward to seeing > you > > guys there > > GregoryO'Connor > > 94ptRomolandCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Aeonix Publishing Group" > > > > > > > > We're on our way to the Southwest rally in Buellton. Today we > drove > > down to Morro Bay. > > > Most of the way it was pretty uneventful -- toad tracking well > > (first time on the road with > > > it) and the SMI breaking system seems ok, but a little sensitive > > (I've adjusted it to come on > > > much less frequently.) > > > > > > However, about 60 miles north of Morro Bay, a warning buzzer came > > on -- but no warning > > > light. > > > > > > We stopped and checked everything. Oil pressure OK, no water in > > fuel, air is up, > > > temperatures are all OK. NO WARNING LIGHTS are on. Buzzer keeps > > right on buzzing... > > > > > > Nothing I checked or changed had any effect on the buzzer (short > of > > taking a hammer to it > > > -- which I was seriously considering if I could get to it). > > > > > > I've heard this same buzzer each time I start up ... a couple of > > buzzers sound until the air > > > is "up" (and several warning lights cycle at start up) then all > the > > lights go out ... and now > > > this one buzzer remains. Thank God it goes off when the ignition > is > > cut... > > > > > > Any ideas? (I'll be asking for help at Buellton!!) > > > > > > Pete Masterson > > > '95 Blue Bird Wanderlodge WBDA 42 > > > aeonix1@ > > > On the road at Morro Bay, CA > > > > > > |
10-20-2006, 04:29
A couple of thoughts come to mind:
With key switch on, engine not running, press and hold the check engine switch and count the flashing lights, this will be the DDEC codes. There will be two codes displayed, low water level and low oil because the engine is not running, anything other than that might well give you a clue. The jacks have all ready been mentioned, this will cause a buzzer. On the air side, just a stab, do you have the bulk oil fill system? is it turned on? if left on this will cause a buzzer as well. Just some thoughts Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma At 03:30 PM 10/20/2006 +0000, you wrote: >Indeed, I'm becomming more and more impressed with the abilities of this >coach as I gain >experience with it. > >Tried unhooking the SMI (It plugs into the cigarette lighter) -- not it. > >I've looked over the wiring diagram trying to figure out which fuse and/or >relay is involved. >I'll try pulling fuses/relays this morning before I leave Moro Bay. (It's >less than 2 hours to >Buellton). > >The buzzers listed include >- Stop Engine Buzzer (fuse also covers Tran Temp/Step Lgt) >- Low Air Buzzer (but that fuse also includes "Upr Dash Ignition" and >"Quick Start" > >At this point, I'm pretty sure that it's the Stop Engine Buzzer -- but >like I said, there's no >warning lights and all the gauges read in the normal range. At the time >the buzzer came >on, oil pressure was at the low end of the normal range, reading about 40 >psi. Later on, >the oil pressure was reading a more typical 60-70 psi -- yet the buzzer >continued to >sound. (There is adequate oil in the engine.) > > |
