update: Annoying Warning Buzzer
10-20-2006, 14:07
I appreciate the helpful comments.
This morning, after start up, all the buzzers and lights did their normal stuff ... and no more buzzer. I've talked this over with the other BBers at the Southwest Rally in Buellton and the combined consensus seems to be "these things happen sometimes." Not a very satisfying outcome ... but it may have been an electrical glitch that may or may not repeat. If it does, I'll check some of the ideas that have been mentioned. Thank you all.. Pete Masterson 95 Blue Bird WBDA 42 On the road at Buellton, CA with the Southwest BB |
10-21-2006, 01:11
Pete: When we left South Padre Island ,two years ago it was raining.
Our low air pressure buzzer came on and stayed on all the way to Ft.Worth. It rained the entire way (HARD RAIN) and knowing that the breaker for this was in the front load compartment we did not want to stop and open this in the rain so we kept going. The next morning we started the coach up and NO BUZZER. That was two years ago and it's never been a problem since. Gremlin's at play????? Bob 93pt40-Illinois |
10-21-2006, 10:18
stuff. I power washed some things before and hit the E-Boards by accident. When
all was done the things did NOT work no matter what. Waited 1 day and it all came back to normal. Moisture will cut E-stuff out, but usually will come back unless you actually created a Short, and that you would see by a spark. Juergen in PA 199 WLSP 36 Bob & Carol Howald` Pete: When we left South Padre Island ,two years ago it was raining. Our low air pressure buzzer came on and stayed on all the way to Ft.Worth. It rained the entire way (HARD RAIN) and knowing that the breaker for this was in the front load compartment we did not want to stop and open this in the rain so we kept going. The next morning we started the coach up and NO BUZZER. That was two years ago and it's never been a problem since. Gremlin's at play????? Bob 93pt40-Illinois --------------------------------- All-new Yahoo! Mail - Fire up a more powerful email and get things done faster. [Non-text portions of this message have been removed] |
