Heater core install and system flush
10-24-2006, 16:07
The second propane furnace crapped out, lights but shuts down after
2-3 seconds. I believe it is the thermocoupler but there are 2 and
they are entirely different than the current style. Now I am down to a
single unit because they are old Dou-Therms and they haven't made
furnaces for 15+ years so I'm guessing the parts haven't been made for
a while.
I am installing the Proheat system in my rig and there are currently 2
heater cores, 1 under the rear queen and 1 under the front couch, not
counting the dash heater core. I am planning on adding at least 1
additional heater core and fans. I am planning on adding additional
fans to the current heater cores, the existing fans are automotive
fans and I think they will draw too many amps and drain the batteries
quickly. Someone suggested using old computer cooling fans I am
guessing because they have a low amp draw. Any suggestions on sources
for heater cores? Would a home baseboard heater work?
I also Recall someone mentioning using a sump pump to fill the heat
core coolant lines after a flush, anyone remember this... Randy?
Troy Tikalsky
1986 Newell 40'
10-24-2006, 20:13
Stephen- that link led me to a health club in England~
83 PT40
Livingston, Montana
10-25-2006, 00:05
Troy you may want to lookat this company
I bought 2 or their heaters and they work great and very low current draw
http://www.mcii.com
Stephen 77fc35
now a dealer for dometic service parts,SMI braking Products and kuuma
products(force10 waterheaters and stainless Barbeques)
--- In WanderlodgeForum@yahoogroups.com, "ttikalsky"
> a while.
> Troy Tikalsky
> 1986 Newell 40'
10-25-2006, 06:30
Ernie I reposted the link
http://www.mccii.com is the correct one
The company name is mobile climate control
Stephen 77fc35
> Ernie Ekberg
> 83 PT40
> Livingston, Montana
