AQUA HOT
10-25-2006, 11:40
AQUA HOT
Ok, so I thought I had everything working. Doesn't look good for the
Rally. Checked the Aqua Hot today and at first it would come on for 30 seconds then turn off. Then after 20 attempts it ran for 15 minutes then stopped. Started over again and it ran again for 10 minutes and quit again. each time it quits the light comes on when I try to restart it but it won't start for 20 minutes or so..Doesn't appear to be anything wrong with the fuel...... Can anyone HELP?? Donald Brown, Palmetto, Florida BMC37' |
10-25-2006, 11:44
AQUA HOT
When is the last time you changed the fuel filter? If not recent
start there. Also the unit is supposed to be serviced yearly. I believe they change out the burner. You can still go and you use your electric hot water heater and electric heaters. Hopefully its a filter change. In addition, are you sure your water is cold? If the hot water heater is working and turned on, the aquahot may not light because the water is hot. You can check the lines to see if they are hot. Hope this helps. We would love to go to RIV but can't. Al, Kathy, Alfred & Daniel Johnson '96 BMC B100 Mandeville,Louisiana --- In WanderlodgeForum@yahoogroups.com, "rvdependent" > > Ok, so I thought I had everything working. Doesn't look good for the > Rally. Checked the Aqua Hot today and at first it would come on for 30 > seconds then turn off. Then after 20 attempts it ran for 15 minutes > then stopped. Started over again and it ran again for 10 minutes and > quit again. each time it quits the light comes on when I try to > restart it but it won't start for 20 minutes or so..Doesn't appear to > be anything wrong with the fuel...... Can anyone HELP?? > > Donald Brown, Palmetto, Florida BMC37' > |
10-25-2006, 13:34
AQUA HOT
Mr. Brown,
I just fixed a diesel leak in our "new to us" Aqua Hot. I ended up calling Vehicle systems about our problem and they were extremely helpful. Also, their web site is pretty good and you can download all the owners, troubleshooting, and shop manuals for their units. They told me my model wasn't made anymore, but also told me which manual to download that was practically the same. Their web site is http://www.hydro-hot.com/ They also emailed me a word document that goes over the anual maintenance... I will forward that to you via email. Hopefully that will at least get you going in the right direction... I would also think that if your unit runs for 15 to 20 mins it might be shutting off because it has finished heating the water...when I refired mine after the repairs it only ran for about 15 mins. The water was very hot after it shut off. Hope that helps, John C 98 LX --- In WanderlodgeForum@yahoogroups.com, "Al" > > When is the last time you changed the fuel filter? If not recent > start there. Also the unit is supposed to be serviced yearly. I > believe they change out the burner. You can still go and you use > your electric hot water heater and electric heaters. Hopefully its a > filter change. > > In addition, are you sure your water is cold? If the hot water > heater is working and turned on, the aquahot may not light because > the water is hot. You can check the lines to see if they are hot. > > Hope this helps. > > We would love to go to RIV but can't. > Al, Kathy, Alfred & Daniel Johnson > '96 BMC B100 > Mandeville,Louisiana > > --- In WanderlodgeForum@yahoogroups.com, "rvdependent" > > > > > Ok, so I thought I had everything working. Doesn't look good for > the > > Rally. Checked the Aqua Hot today and at first it would come on > for 30 > > seconds then turn off. Then after 20 attempts it ran for 15 > minutes > > then stopped. Started over again and it ran again for 10 minutes > and > > quit again. each time it quits the light comes on when I try to > > restart it but it won't start for 20 minutes or so..Doesn't appear > to > > be anything wrong with the fuel...... Can anyone HELP?? > > > > Donald Brown, Palmetto, Florida BMC37' > > > |
10-25-2006, 15:09
AQUA HOT
Donald:
Are you going to attend RATS? I do not have an Aqua Hot but a Wabasto diesel fired retrofit. My system works as follows. Turn the system on, set the desired thermostat temp and the burner fires until the interior temp reaches the selected temp. The burner goes out but the circulation pump keeps circulating the hot water. When the water cools, the burner cycles again, and again. Question? When your cycle is completed are you receiving heat in the bus from the system? It takes mine about 10 minutes to run me out of the bus on a very cool day. As the interior temp decreases the cycle is repeated. Leroy Eckert 1990 WB-40 Niceville, FL Steve Birtles talked me into the retrofit--best thing I ever did to the bus--OEM Primus ----- Original Message ----- From: John To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, October 25, 2006 8:34 PM Subject: [WanderlodgeForum] Re: AQUA HOT Mr. Brown, I just fixed a diesel leak in our "new to us" Aqua Hot. I ended up calling Vehicle systems about our problem and they were extremely helpful. Also, their web site is pretty good and you can download all the owners, troubleshooting, and shop manuals for their units. They told me my model wasn't made anymore, but also told me which manual to download that was practically the same. Their web site is http://www.hydro-hot.com/ They also emailed me a word document that goes over the anual maintenance... I will forward that to you via email. Hopefully that will at least get you going in the right direction... I would also think that if your unit runs for 15 to 20 mins it might be shutting off because it has finished heating the water...when I refired mine after the repairs it only ran for about 15 mins. The water was very hot after it shut off. Hope that helps, John C 98 LX --- In WanderlodgeForum@yahoogroups.com, "Al" > > When is the last time you changed the fuel filter? If not recent > start there. Also the unit is supposed to be serviced yearly. I > believe they change out the burner. You can still go and you use > your electric hot water heater and electric heaters. Hopefully its a > filter change. > > In addition, are you sure your water is cold? If the hot water > heater is working and turned on, the aquahot may not light because > the water is hot. You can check the lines to see if they are hot. > > Hope this helps. > > We would love to go to RIV but can't. > Al, Kathy, Alfred & Daniel Johnson > '96 BMC B100 > Mandeville,Louisiana > > --- In WanderlodgeForum@yahoogroups.com, "rvdependent" > > > > > Ok, so I thought I had everything working. Doesn't look good for > the > > Rally. Checked the Aqua Hot today and at first it would come on > for 30 > > seconds then turn off. Then after 20 attempts it ran for 15 > minutes > > then stopped. Started over again and it ran again for 10 minutes > and > > quit again. each time it quits the light comes on when I try to > > restart it but it won't start for 20 minutes or so..Doesn't appear > to > > be anything wrong with the fuel...... Can anyone HELP?? > > > > Donald Brown, Palmetto, Florida BMC37' > > > [Non-text portions of this message have been removed] |
10-25-2006, 15:34
AQUA HOT
Donald:
I grew up in Palm River/Brandon area. It is a rare day when the snow man commeth. You may not have a problem. First, I would turn on the a/c to its coldest temp and cool the bus down. At midnight or later I would set the hydronic heating system to its highest level and see if it runs you out of the bus. If is does not produce heat you may have a problem. Pumps, boiler, air lock, etc. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, October 25, 2006 10:09 PM Subject: Re: [WanderlodgeForum] Re: AQUA HOT Donald: Are you going to attend RATS? I do not have an Aqua Hot but a Wabasto diesel fired retrofit. My system works as follows. Turn the system on, set the desired thermostat temp and the burner fires until the interior temp reaches the selected temp. The burner goes out but the circulation pump keeps circulating the hot water. When the water cools, the burner cycles again, and again. Question? When your cycle is completed are you receiving heat in the bus from the system? It takes mine about 10 minutes to run me out of the bus on a very cool day. As the interior temp decreases the cycle is repeated. Leroy Eckert 1990 WB-40 Niceville, FL Steve Birtles talked me into the retrofit--best thing I ever did to the bus--OEM Primus ----- Original Message ----- From: John To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, October 25, 2006 8:34 PM Subject: [WanderlodgeForum] Re: AQUA HOT Mr. Brown, I just fixed a diesel leak in our "new to us" Aqua Hot. I ended up calling Vehicle systems about our problem and they were extremely helpful. Also, their web site is pretty good and you can download all the owners, troubleshooting, and shop manuals for their units. They told me my model wasn't made anymore, but also told me which manual to download that was practically the same. Their web site is http://www.hydro-hot.com/ They also emailed me a word document that goes over the anual maintenance... I will forward that to you via email. Hopefully that will at least get you going in the right direction... I would also think that if your unit runs for 15 to 20 mins it might be shutting off because it has finished heating the water...when I refired mine after the repairs it only ran for about 15 mins. The water was very hot after it shut off. Hope that helps, John C 98 LX --- In WanderlodgeForum@yahoogroups.com, "Al" > > When is the last time you changed the fuel filter? If not recent > start there. Also the unit is supposed to be serviced yearly. I > believe they change out the burner. You can still go and you use > your electric hot water heater and electric heaters. Hopefully its a > filter change. > > In addition, are you sure your water is cold? If the hot water > heater is working and turned on, the aquahot may not light because > the water is hot. You can check the lines to see if they are hot. > > Hope this helps. > > We would love to go to RIV but can't. > Al, Kathy, Alfred & Daniel Johnson > '96 BMC B100 > Mandeville,Louisiana > > --- In WanderlodgeForum@yahoogroups.com, "rvdependent" > > > > > Ok, so I thought I had everything working. Doesn't look good for > the > > Rally. Checked the Aqua Hot today and at first it would come on > for 30 > > seconds then turn off. Then after 20 attempts it ran for 15 > minutes > > then stopped. Started over again and it ran again for 10 minutes > and > > quit again. each time it quits the light comes on when I try to > > restart it but it won't start for 20 minutes or so..Doesn't appear > to > > be anything wrong with the fuel...... Can anyone HELP?? > > > > Donald Brown, Palmetto, Florida BMC37' > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
02-07-2010, 01:49
AQUA HOT
Hi Everyone,
The Aqua Hot on my 2003 coach is giving me problems. When I turn the switch to the on posiion on the dash the Aqua Hot fires up and stays on for about 15 seconds, then shuts down. Any ideas where I might start to troubleshoot? Randy Merrill 2003 LX Ocala, FL |
02-07-2010, 02:49
AQUA HOT
The sensors are not seeing the flame and going to shut down. The burner
needs to be serviced and also checked for heat cracks. Time to change the knozzel and fuel filter. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 01:49 PM 2/7/2010 +0000, you wrote: >Hi Everyone, > >The Aqua Hot on my 2003 coach is giving me problems. When I turn the >switch to the on posiion on the dash the Aqua Hot fires up and stays on >for about 15 seconds, then shuts down. Any ideas where I might start to >troubleshoot? > >Randy Merrill >2003 LX >Ocala, FL > > > |
02-08-2010, 10:39
AQUA HOT
Randy, sorry to hear about the A/H problems, you are just starting the process,
hope you have the manuals, if not; you can down load them at the A/H web sight. It could be a number of problems. If you have the time and tools and know how just follow the trouble shooting flow chart and you will get to the problem. These units have all sorts of interlocks, low voltage, high voltage, low coolant, high temp are just a few. Some oddities' that I have experienced are, 1- if your unit has a reset on the high limit thermostat, as the old ones do, it could be open and the fuel pump solenoid valve will not let any fuel to the nozzle. 2- If the dash switch is old it may not be giving the unit a good initial signal and the controller shuts it down. 3- if the control unit has a problem it won't let the unit run, in my case, everything is fine and works, but the controller won't let the igniter spark, so I took the controller and through it in the freezer for a couple of hours and it fired right up (shrinks up the circuit board and makes a connection). Good luck Marty Gregg 95 BMC 37 Kennewick WA |
02-08-2010, 14:47
AQUA HOT
As mentioned above the problem could be lots of places. When the problem your
having happened to me it turned out the problem was the flame sensor (thermocouple) just in front of the nozzle was loose. The symptoms I had is the system would start up, run for a few seconds then shut down. The sensor looks like bent finger that is just in front of the nozzle. At the same time you take the burner off, take Ralph's advise and change the nozzle and the fuel filter, if you haven't done it already. If you haven't taken the AquaHot burner out to service the nozzle it is a lot more intimidating to think about than to actually do it. The AquaHot manuals are excellent. The best manuals of any equipment on my bus. They tell you everything except the clearance between the nozzle and the flame sensor. It's about 3/8". Good luck and Happy trails, Eric Perplies 96 PT=42 |
02-21-2010, 01:26
AQUA HOT
Got my Aqua Hot working again. It was a fuel nozzle that needed to be replaced.
Thanks to everyone that gave helpful hints and advice. The manual is great and really helps in troubleshooting. Randy Merrill 2003 LX Ocala, FL |
