Restricted Swinger
10-25-2006, 15:58
Restricted Swinger
On the '87 FC(probably '88's and '89's as well) the radiator
and after cooler swing open approximately 40* to a welded stop on the frame. The opening between the radiator and front sheet metal measure 14 inches full open. Not a place for big guys and quite restricted for smaller ones. Does anyone know why there is this limitation. No transmission cooling done at the radiator, it is at the ZF transmission. Thanks, Bob Janes, '87FC35 Greenville, SC |
10-25-2006, 21:11
Restricted Swinger
Bob On my 89 SP I would say it is the top & bottom radiator hose can't
open any further.It kinks my top one a lot as when it opens. I replaced my top this summer & it was only two years old. Do 89 SP 36' Butler, PA On the '87 FC(probably '88's and '89's as well) the radiator and after cooler swing open approximately 40* to a welded stop on the frame. The opening between the radiator and front sheet metal measure 14 inches full open. Not a place for big guys and quite restricted for smaller ones. Does anyone know why there is this limitation. No transmission cooling done at the radiator, it is at the ZF transmission. Thanks, Bob Janes, '87FC35 Greenville, SC [Non-text portions of this message have been removed] |
10-26-2006, 01:54
Restricted Swinger
Don, Yours would be a single pusher, I am not familiar with
how they open. Factory instructions as I understand call for draining some fluid and removing the top hose. Someone has replaced the top hose with flex which folds a tight turn in the closed position. Restriction is not hose length. Bob 87FC35 Greenville, SC --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > > Bob On my 89 SP I would say it is the top & bottom radiator hose can't > open any further.It kinks my top one a lot as when it opens. I replaced my > top this summer & it was only two years old. > Do > 89 SP 36' > Butler, PA > > On the '87 FC(probably '88's and '89's as well) the radiator > and after cooler swing open approximately 40* to a welded stop > on the frame. The opening between the radiator and front sheet > metal measure 14 inches full open. Not a place for big guys and > quite restricted for smaller ones. > > Does anyone know why there is this limitation. No transmission > cooling done at the radiator, it is at the ZF transmission. > Thanks, > Bob Janes, '87FC35 Greenville, SC > > > > > > > [Non-text portions of this message have been removed] > |
