tank vents 90SP36
10-27-2006, 03:20
tank vents 90SP36
This may sound funny but there is a noticeable gurgle from the
kitchen sink drain when I empty the sink. I checked the vent on the top right center of the coach and ran a plumbing snake down it. I felt an obstruction and from the dirt on the end of the snake I surmised it was the remnants of a wasps nest. I continued to feed the snake down the vent but never did touch water and the gurgle is still there. Any ideas? Chuck Harrison Akron, Ohio 90 SP36 |
10-27-2006, 04:30
tank vents 90SP36
Chuck,
My sinks have 1 1/2" pipes near the trap that are about 1 foot long and are vertically mounted. On top is a valve spring loaded closed. I do not know why they are there unless the valve provides an emergency gas escape in the event the main vent is plugged. If that valve is open it might cause the noise you described. Just a swag. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: williamcharrison To: WanderlodgeForum@yahoogroups.com Sent: Friday, October 27, 2006 10:20 AM Subject: [WanderlodgeForum] tank vents 90SP36 This may sound funny but there is a noticeable gurgle from the kitchen sink drain when I empty the sink. I checked the vent on the top right center of the coach and ran a plumbing snake down it. I felt an obstruction and from the dirt on the end of the snake I surmised it was the remnants of a wasps nest. I continued to feed the snake down the vent but never did touch water and the gurgle is still there. Any ideas? Chuck Harrison Akron, Ohio 90 SP36 [Non-text portions of this message have been removed] |
10-27-2006, 04:36
tank vents 90SP36
---CHUCK:
Kitchen sink goes to black tank and vent pipe goes 90 degrees up behind pullout pantry drawer.. take out bottom pull out drawer and check it out. maybe u got a clock where it goes 90 degrees. LOL Hank Hannigan 90SP36 80FC31 for sale in VEGAS for three more days..$27,000 In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > This may sound funny but there is a noticeable gurgle from the > kitchen sink drain when I empty the sink. I checked the vent on the > top right center of the coach and ran a plumbing snake down it. > I felt an obstruction and from the dirt on the end of the snake > I surmised it was the remnants of a wasps nest. I continued to feed > the snake down the vent but never did touch water and the gurgle is > still there. Any ideas? > > Chuck Harrison > Akron, Ohio > 90 SP36 > |
