Which Water Heater to Buy???84FC
10-27-2006, 07:32
If it wasn't for all the corrosion, the water heater in my bus would
be leaking for sure. After a quick trip around the WWW, I've found Atwood, Seaward, Force 10, and Raritan with 110V/heat exchanger water heaters. Anyone have anything good (or bad) to say about any of these? Are there others? I haven't done any measuring yet, so maybe some will get crossed off the list early. Advice appreciated. David Hollis 84 FC35 Springfield,IL |
10-27-2006, 09:30
David- i believe West Marine has the exact "plug and play" configuration that
we need. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
10-28-2006, 01:25
David several of us have put a Force Ten in as a replacement and have been
very happy with them. Stephen Birtles has them. On 27/10/06, dthollis1961 > > If it wasn't for all the corrosion, the water heater in my bus would > be leaking for sure. After a quick trip around the WWW, I've found > Atwood, Seaward, Force 10, and Raritan with 110V/heat exchanger water > heaters. Anyone have anything good (or bad) to say about any of > these? Are there others? I haven't done any measuring yet, so maybe > some will get crossed off the list early. Advice appreciated. > > David Hollis 84 FC35 Springfield,IL > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
10-28-2006, 03:53
I replaced my water heater about 5 yrs ago with the Seaward 11 gallon.
Almost an exact fit to the original Atwood. So far, no problems. Heats up in about 20 minutes or so with the genset running. Since I put it in, I have done nothing to it but use it. I bought directly from the manufacturer near my house in Whittier, CA, and picked it up at will call. The price was in line with the other brands, maybe $50 or so cheaper from the factory. Good marine-grade quality.... Kevin McKeown Yorba Linda, CA 1986 38' T [Non-text portions of this message have been removed] |
10-29-2006, 12:24
The exact replacement is made by Raritan and sold thru West Marine.
The fittings are almost in the same place as the old heater and take a little addition off fittings to make them line up. I just replaced ours on our 1980 FC 35, the tank had a pinhole leak just above the hot water outlet. The Raritan part# is 171212, the West Marine part# is 256912. I had to trim the plastic mounting rim on the bottom of the new heater as it goes all the way around. I set both heaters next to each other and tranferred the fittings to make sure they ended up in the same place as the old unit. It was a bit of a struggle but it did fit and works great. Lucas Willemse 1980 FC 35 Los Angeles |
10-29-2006, 14:34
Thanks for all the helpful replies. I should have said that the
present heater is a "cube" shaped heater. The 78FC I had had the round Raritan looking heater. What I'd like to know is why the Raritan is about twice the price of the Force 10 or Seaward. David Hollis 84FC35 Springfield,IL...Lining up winter inside projects --- In WanderlodgeForum@yahoogroups.com, "Lucas Willemse" > > The exact replacement is made by Raritan and sold thru West Marine. > The fittings are almost in the same place as the old heater and take a > little addition off fittings to make them line up. I just replaced > ours on our 1980 FC 35, the tank had a pinhole leak just above the hot > water outlet. The Raritan part# is 171212, the West Marine part# is > 256912. > > I had to trim the plastic mounting rim on the bottom of the new heater > as it goes all the way around. I set both heaters next to each other > and tranferred the fittings to make sure they ended up in the same > place as the old unit. It was a bit of a struggle but it did fit and > works great. > > Lucas Willemse > 1980 FC 35 > Los Angeles > |
10-31-2006, 04:05
> > The exact replacement is made by Raritan and sold thru West Marine. > The fittings are almost in the same place as the old heater and take a > little addition off fittings to make them line up. I just replaced > ours on our 1980 FC 35, the tank had a pinhole leak just above the hot > water outlet. The Raritan part# is 171212, the West Marine part# is > 256912. > > I had to trim the plastic mounting rim on the bottom of the new heater > as it goes all the way around. I set both heaters next to each other > and tranferred the fittings to make sure they ended up in the same > place as the old unit. It was a bit of a struggle but it did fit and > works great. > > Lucas Willemse > 1980 FC 35 > Los Angeles > The above information is wrong when I came home and checked my records, the correct heater is A Raritan 171211, West Marine 296386 $579.99. I should have looked it up first. Lucas Willemse 1980 FC 35 Los Angeles |
11-01-2006, 02:35
Hi David,
I replaced our old water heater with an Atwood heater and found out the following in the process: 1. Had to raise the elevation of the drivers side bed 3/4" to fit the new heater in. 2. The Atwood has a high temperature protection switch that trips at about 185 ºF. If you circulate engine coolant through it while you go down the road, you will find out later that the electrical heat isn't working. It is a REAL PAIN to reset the switch as it is located down between the electrical leads into the heater and is not easy to reach. For this reason, I don't circulate jacket water through it. I discussed this with Atwood tech support and they offered no info on a fix for this problem. 3. Heater has plenty of capacity and we rarely run out of hot water even after two showers. All things considered, it sounds like there are better choices out there than the Atwood. Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" > > If it wasn't for all the corrosion, the water heater in my bus would > be leaking for sure. After a quick trip around the WWW, I've found > Atwood, Seaward, Force 10, and Raritan with 110V/heat exchanger water > heaters. Anyone have anything good (or bad) to say about any of > these? Are there others? I haven't done any measuring yet, so maybe > some will get crossed off the list early. Advice appreciated. > > David Hollis 84 FC35 Springfield,IL > |
11-01-2006, 02:57
Dave give the Force 10 a serious look. When I talked to the Force 10 folks
they told me they took the basic Sealand and tried to make it better. They actually admitted they copied the Sealand. When I bought my Force Ten (11 or 12 gallon not sure) the differences I could see were that the piping is larger and it had a SS casing rather than a painted one. The price was cheaper too. A couple of us including Randy Dupree have installed them and they work well. Water heats up electrically in 15 min. Check them out at http://www.force10.com/company.html On 01/11/06, Eric Johnson > > Hi David, > I replaced our old water heater with an Atwood heater and found out the > following in the > process: > > 1. Had to raise the elevation of the drivers side bed 3/4" to fit the new > heater in. > 2. The Atwood has a high temperature protection switch that trips at about > 185 ºF. If you > circulate engine coolant through it while you go down the road, you will > find out later that > the electrical heat isn't working. It is a REAL PAIN to reset the switch > as it is located down > between the electrical leads into the heater and is not easy to reach. For > this reason, I > don't circulate jacket water through it. I discussed this with Atwood tech > support and they > offered no info on a fix for this problem. > 3. Heater has plenty of capacity and we rarely run out of hot water even > after two > showers. > > All things considered, it sounds like there are better choices out there > than the Atwood. > > Eric in San Antonio > 84FC35SBWL2 > > --- In WanderlodgeForum@yahoogroups.com > "dthollis1961" > > > > If it wasn't for all the corrosion, the water heater in my bus would > > be leaking for sure. After a quick trip around the WWW, I've found > > Atwood, Seaward, Force 10, and Raritan with 110V/heat exchanger water > > heaters. Anyone have anything good (or bad) to say about any of > > these? Are there others? I haven't done any measuring yet, so maybe > > some will get crossed off the list early. Advice appreciated. > > > > David Hollis 84 FC35 Springfield,IL > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
