oil drain plug success
11-02-2006, 07:21
Although the result was the same, I'm glad your issue was resolved easier
than mine was. Besides, it's a great excuse to buy another neat tool. You came out ahead!! Kevin Mc YL CA 86 38pt [Non-text portions of this message have been removed] |
11-02-2006, 09:20
Any time there is a need for a tool run, is always a good day. Just don't
tell the "boss". Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
11-02-2006, 11:41
This has been a better day.. the plug is out and oil has been changed.
On your advice, I went to town and bought a wire feed welder, and welded a short bolt inside the square. Then, using an impact wrench(as suggested by Tom Warner)the dang thing came right out! Y'all have saved my life again! Thanks to allllll... Rob Sargent 1985pt36 |
11-02-2006, 14:44
Hooray!!! Fresh oil and new tools...life is great!
Doug Engel, Gunnison, CO, '81FC35 --- In WanderlodgeForum@yahoogroups.com, "aokkoa2003" > > This has been a better day.. the plug is out and oil has been changed. > On your advice, I went to town and bought a wire feed welder, and > welded a short bolt inside the square. Then, using an impact wrench (as > suggested by Tom Warner)the dang thing came right out! > Y'all have saved my life again! > Thanks to allllll... > Rob Sargent > 1985pt36 > |
11-02-2006, 16:11
Now that you have a wire feed, life will never be the same. You will
look at every project with an new perspective and after everthing metal at home is repaired, you will then pick your neighbors trash fix, simple repairs and give em back. Welcome to the club. Greg --- In WanderlodgeForum@yahoogroups.com, "aokkoa2003" > > This has been a better day.. the plug is out and oil has been changed. > On your advice, I went to town and bought a wire feed welder, and > welded a short bolt inside the square. Then, using an impact wrench (as > suggested by Tom Warner)the dang thing came right out! > Y'all have saved my life again! > Thanks to allllll... > Rob Sargent > 1985pt36 > |
