Air Step Problem?
11-06-2006, 14:16
Air Step Problem?
When I park my 88 FC35 I always turn off both master electrical
switches. I switch the step to be locked in. It stays in for a day or less then when I return to the unit the step is out. Is that normal or do I have a leak somewhere? Bruce 1988 FC35 |
11-06-2006, 14:32
Air Step Problem?
When the air pressure drops off, the step comes out. That's normal.
Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Nov 6, 2006, at 6:16 PM, birdshill123 wrote: > When I park my 88 FC35 I always turn off both master electrical > switches. I switch the step to be locked in. It stays in for a day or > less then when I return to the unit the step is out. Is that normal or > do I have a leak somewhere? > > Bruce 1988 FC35 [Non-text portions of this message have been removed] |
11-06-2006, 17:55
Air Step Problem?
Bruce, As the tanks leak down the step detects and uses its last chance
to swing open and lock into position. A forum member parked his new to him 91SP inches from a curb and came out a day later to find that the step extended and then the air bags deflated, resting the bus on the extended step. This is why it is important to park with your steer wheels set straight. If not, models like the 94Pt will rest down on the tires and damage the body. GregO'Copnnor 94ptRomoland --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > When I park my 88 FC35 I always turn off both master electrical > switches. I switch the step to be locked in. It stays in for a day or > less then when I return to the unit the step is out. Is that normal or > do I have a leak somewhere? > > Bruce 1988 FC35 > |
11-06-2006, 18:08
Air Step Problem?
Unless I'm missing something on my Bird, it seems odd that there is no way to
secure the step in the completely out position once the air pressure drops off. It droops to about a 2/3 out position, which is not very convenient. Any fixes? Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > When the air pressure drops off, the step comes out. That's normal. > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > On Nov 6, 2006, at 6:16 PM, birdshill123 wrote: > > > When I park my 88 FC35 I always turn off both master electrical > > switches. I switch the step to be locked in. It stays in for a day or > > less then when I return to the unit the step is out. Is that normal or > > do I have a leak somewhere? > > > > Bruce 1988 FC35 > > > > [Non-text portions of this message have been removed] > |
11-06-2006, 23:03
Air Step Problem?
> > When I park my 88 FC35 I always turn off both master electrical > switches. I switch the step to be locked in. It stays in for a day or > less then when I return to the unit the step is out. Is that normal or > do I have a leak somewhere? > > Bruce 1988 FC35 > I have a 1980 FC33 under the step there is a latch that is sping loaded and it catches on the step frame to hold it open after the air bleeds down mark 1980 FC33 |
11-07-2006, 01:47
Air Step Problem?
Bruce,
My 87FC35's step reacts the same way. I had assumed that was "normal". Maybe not. Don 87FC35 Jensen Beach FL [Non-text portions of this message have been removed] |
11-07-2006, 02:28
Air Step Problem?
I believe the step design is to open once the air pressure at the pressure
switch drops below 90 psi. RWW 91 WLWB Cedar Rapids, IA -----Original Message----- From: "w3ww" To: WanderlodgeForum@yahoogroups.com Sent: 11/7/06 7:47 AM Subject: Re: [WanderlodgeForum] Re: Air Step Problem? Bruce, My 87FC35's step reacts the same way. I had assumed that was "normal". Maybe not. Don 87FC35 Jensen Beach FL [Non-text portions of this message have been removed] |
11-07-2006, 03:12
Air Step Problem?
If you use air to keep the step out,,,, there is a leak in the ram or
valve. The ram on my 94pt is not servicable. GregoryO'Connor 94ptRomolandCa--- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Unless I'm missing something on my Bird, it seems odd that there is no way to secure the > step in the completely out position once the air pressure drops off. It droops to about a > 2/3 out position, which is not very convenient. Any fixes? > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > > > When the air pressure drops off, the step comes out. That's normal. > > > > Pete Masterson > > aeonix1@ > > '95 Bluebird Wanderlodge WBDA 42' > > El Sobrante, CA > > > > > > > > > > On Nov 6, 2006, at 6:16 PM, birdshill123 wrote: > > > > > When I park my 88 FC35 I always turn off both master electrical > > > switches. I switch the step to be locked in. It stays in for a day or > > > less then when I return to the unit the step is out. Is that normal or > > > do I have a leak somewhere? > > > > > > Bruce 1988 FC35 > > > > > > > > [Non-text portions of this message have been removed] > > > |
11-07-2006, 10:57
Air Step Problem?
Mark,
Mine too. Mine never moves by itself, air or not. Only when I tell it to. Stephen 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sweeperman210 Sent: Tuesday, November 07, 2006 6:03 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Air Step Problem? --- In WanderlodgeForum@ yahoogroups.com, "birdshill123" > > When I park my 88 FC35 I always turn off both master electrical > switches. I switch the step to be locked in. It stays in for a day or > less then when I return to the unit the step is out. Is that normal or > do I have a leak somewhere? > > Bruce 1988 FC35 > I have a 1980 FC33 under the step there is a latch that is sping loaded and it catches on the step frame to hold it open after the air bleeds down mark 1980 FC33 [Non-text portions of this message have been removed] |
11-07-2006, 11:27
Air Step Problem?
Somethings not right with your step. Mine extends to a fully locked
position as the air bleeds off. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Nov 6, 2006, at 10:08 PM, davidkerryedwards wrote: > Unless I'm missing something on my Bird, it seems odd that there is > no way to secure the > step in the completely out position once the air pressure drops > off. It droops to about a > 2/3 out position, which is not very convenient. Any fixes? [Non-text portions of this message have been removed] |
