driver's vent air cylinder
11-08-2006, 09:33
I have been doing some "wiring" work on my Bird, 1988 FC35. What fun. I
needed to access the wiring behind the driver's vent. I removed the
grille and the panel for the air vent. Couldnt get the plastic air hose
off so removed the Clippard cylinder. It is just hanging right now. It
looks like somneone has been in there before. I started up the bird and
operated the cylinder to see that it worked OK. It did but at the rod
end of the cylinder there is a small factory hole in the cylinder body.
When the rod is extended a small amount of air leaks at that hole. Is
this normal? It is fine when not extended. I havent hooked everything
back up to see if maybe it is because the cylinder is extended too far
exposing that hole. Maybe if it was attached to the vent door the
cylinder would not fully extend?? Thanks
Bruce
11-08-2006, 10:32
You speak the bitter truth, "some one has been here before". I hope you don't
run into the dreaded side cutter user. My vent cylinders don't leak at either
end of travel, but I haven't checked them out of frame. I am working with a
couple of new cylinders for another project and they do not leak at the stroke
limits.
MH
Sent: Wednesday, November 08, 2006 3:33 PM
Subject: [WanderlodgeForum] driver's vent air cylinder
Bruce
11-08-2006, 10:59
Bruce, the hole is to release air when the cylinder is actuated,
necessary as otherwise it would be compressing air against the
piston stroke. The point of concern for air leakage would be prior
to the piston reaching that hole. It may never get to the point it is
now under normal operation. My guess??
Bob Janes, Greenville, SC
fun. I
hose
It
rod
body.
Is
everything
far
> Bruce
11-08-2006, 11:28
Bruce,
Call Clippard and ask them.about hole and leaking. I believe you will
need a new cylinder. You can order one while you are on the phone.
Try this to remove the air hose. Push in on the piece that the hose goes
into and remove the hose.
Good luck.
Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif.
>Bruce
>Yahoo! Groups Links
11-08-2006, 14:59
Some air cylinders only push out or pull in. they are called single
acting cylinders. the vent is needed for the release of air from the
noncharged side of the piston as it is pushed or pulled. The only
time it will pass air is during a movement . static release of air
is a sign of a damaged piston seal. The entire stainless cylinder
interior wall surface is uninterrupted (full distance of stroke)and
it is more likely that the rubber seal is damaged.
Moisture in the cylinder freezes and the ice chews up the piston
seal. Or dirt gets past the rod wiperseal and buggers up the piston
seal. Or you meet the requirements for Clippard's planned
obsolescence. The Clippards I worked on are more or less non
servicable. Clippard . com has a good enduser web order store and the
prices are less than MSR.
Some of the airline fittings have a plastic collar near the bace of
the fitting. pushing the collar toward the fitting releases the air
line.
GregoryO'Connor
94ptRomolandCa
fun. I
hose
It
rod
body.
Is
everything
far
> Bruce
