More questions from Doug and Lee (really only Doug, Lee is making me a sandwich)
11-14-2006, 06:09
OK, somebody should have told me not to take on waxing this beast on an empty
stomach. I need a sandwich (and a beer...or 3). Now for the questions of the day: 1) My thermometer keeps going into "blink" mode. If I fiddle with a contact breaker under the drivers side sofa, (there are 2 that look the same, the one I manually break contact with is the one closest to the rear of the bus) I can get it to quit, but then it goes back to blinking after a while...any ideas? And what is this breaker I'm monkeying with anyway??? 2) Fridge is new, and fired up on LP just fine, but turned itself off overnight. "No FL" (no flow??) I just restarted it and no it's working again...anyone??? Time for some lunch...Doug |
11-14-2006, 06:46
Doug. I don't know the year or model of your coach but I'll take a
shot at the refer. On the Dometic's, I have a rm7030. when it reach's the temperature that's it's been set to by the thermostat it will turn the gas off and stay's off until the thermostat tell's it to cool down again. If your in a cool climate you'll see this happen a lot. In a warm climate it won't be as frequent. Could be nothing's wrong with the refer, just working as advertised. It will do the same thing on electric also....Bob 93pt---Illinois. Ps. It's cool here now and I leave the refer on all the time, when I feel the cooling coil's they will be cold most of the time but the refer is still holding 35 degrees which I set. I use a remote thermometer to monitor the inside temperature, keeps from opening the door. |
11-14-2006, 11:11
Doug
Our thermomater in front and clock/thermomater in the kitchen blinks to, as you said you can fiddle with it and it stops for awhile but goes back to blinking. I gave up on it because it dosn't bother me,lots more important thing to look at but it drives my wife nuts! Jeff & Michelle August 1980FC35RB Plymouth Wi. --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" wrote: > > OK, somebody should have told me not to take on waxing this beast on an empty stomach. I > need a sandwich (and a beer...or 3). > Now for the questions of the day: > 1) My thermometer keeps going into "blink" mode. If I fiddle with a contact breaker under the > drivers side sofa, (there are 2 that look the same, the one I manually break contact with is the > one closest to the rear of the bus) I can get it to quit, but then it goes back to blinking after a > while...any ideas? And what is this breaker I'm monkeying with anyway??? > 2) Fridge is new, and fired up on LP just fine, but turned itself off overnight. "No FL" (no > flow??) I just restarted it and no it's working again...anyone??? > Time for some lunch...Doug > |
11-14-2006, 12:03
Jeff,
Thanks for the input. I am going to monitor the behavior to see what triggers the bilnking. I think it may be a power surge situation. I"ll psot my findings. --- Jeff August > Doug > Our thermomater in front and clock/thermomater in > the kitchen blinks > to, as you said you can fiddle with it and it stops > for awhile but > goes back to blinking. I gave up on it because it > dosn't bother > me,lots more important thing to look at but it > drives my wife nuts! > Jeff & Michelle August > 1980FC35RB > Plymouth Wi. > > > --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" > > wrote: > > > > OK, somebody should have told me not to take on > waxing this beast > on an empty stomach. I > > need a sandwich (and a beer...or 3). > > Now for the questions of the day: > > 1) My thermometer keeps going into "blink" mode. > If I fiddle with a > contact breaker under the > > drivers side sofa, (there are 2 that look the > same, the one I > manually break contact with is the > > one closest to the rear of the bus) I can get it > to quit, but then > it goes back to blinking after a > > while...any ideas? And what is this breaker I'm > monkeying with > anyway??? > > 2) Fridge is new, and fired up on LP just fine, > but turned itself > off overnight. "No FL" (no > > flow??) I just restarted it and no it's working > again...anyone??? > > Time for some lunch...Doug > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" ________________________________________________________________________________\ ____ Sponsored Link Get a free Motorola Razr! Today Only! Choose Cingular, Sprint, Verizon, Alltel, or T-Mobile. http://www.letstalk.com/inlink.htm?to=592913 |
