40 weight oil
11-16-2006, 01:14
40 weight oil
i am going to change the oil, and my owners manual tells me to use
10w40 weight. as seen below im being advised to use straight 40. what weight should i use? 40 grade Cx-II oil? thanks, robert 85 pt40 6v92 Detroits have no glow plugs and "off the shelf" no starting assist. They are ENTIRELY dependant on engine compression to start. They also require (not recommend, REQUIRE) straight weight strength required by the injector followers - you WILL destroy cams if you run a 15W40 in them, |
11-16-2006, 02:18
40 weight oil
I'm also changing oil tomorrow. I've been using 15-40 Rotello. Please advise.
Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL 8V92 ----- Original Message ----- From: chapelhill2901 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 16, 2006 7:14 AM Subject: [WanderlodgeForum] 40 weight oil i am going to change the oil, and my owners manual tells me to use 10w40 weight. as seen below im being advised to use straight 40. what weight should i use? 40 grade Cx-II oil? thanks, robert 85 pt40 6v92 Detroits have no glow plugs and "off the shelf" no starting assist. They are ENTIRELY dependant on engine compression to start. They also require (not recommend, REQUIRE) straight weight strength required by the injector followers - you WILL destroy cams if you run a 15W40 in them, [Non-text portions of this message have been removed] |
11-16-2006, 02:43
40 weight oil
Leroy every DD person I have checked with told me to use only 40W oil with a
rating of CH2. Two brands which fit the bill and have a low ash content are Rotella and Delo 100. I believe Curt Sprenger has a link to the Petroleum Page that explains it all. Curt I've misplaced or lost my link to that page so if you could repost it I'd appreciate it. On 16/11/06, Leroy Eckert > > I'm also changing oil tomorrow. I've been using 15-40 Rotello. Please > advise. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > 8V92 > > ----- Original Message ----- > From: chapelhill2901 > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, November 16, 2006 7:14 AM > Subject: [WanderlodgeForum] 40 weight oil > > i am going to change the oil, and my owners manual tells me to use > 10w40 weight. as seen below im being advised to use straight 40. what > weight should i use? 40 grade Cx-II oil? > > thanks, robert > 85 pt40 6v92 > > Detroits have no glow plugs and "off the shelf" no starting assist. > They are ENTIRELY dependant on engine compression to start. They > also require (not recommend, REQUIRE) straight weight strength required > by the injector followers - you WILL destroy cams > if you run a 15W40 in them, > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
11-16-2006, 02:45
40 weight oil
Detroit recommends only straight 40W oil.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "chapelhill2901" > > i am going to change the oil, and my owners manual tells me to use > 10w40 weight. as seen below im being advised to use straight 40. what > weight should i use? 40 grade Cx-II oil? > > thanks, robert > 85 pt40 6v92 > > > Detroits have no glow plugs and "off the shelf" no starting assist. > They are ENTIRELY dependant on engine compression to start. They > also require (not recommend, REQUIRE) straight weight strength required > by the injector followers - you WILL destroy cams > if you run a 15W40 in them, > |
11-16-2006, 02:58
40 weight oil
Thanks Rob, I'll follow up on that link.
Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Rob Robinson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 16, 2006 8:43 AM Subject: Re: [WanderlodgeForum] 40 weight oil Leroy every DD person I have checked with told me to use only 40W oil with a rating of CH2. Two brands which fit the bill and have a low ash content are Rotella and Delo 100. I believe Curt Sprenger has a link to the Petroleum Page that explains it all. Curt I've misplaced or lost my link to that page so if you could repost it I'd appreciate it. On 16/11/06, Leroy Eckert > > I'm also changing oil tomorrow. I've been using 15-40 Rotello. Please > advise. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > 8V92 > > ----- Original Message ----- > From: chapelhill2901 > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, November 16, 2006 7:14 AM > Subject: [WanderlodgeForum] 40 weight oil > > i am going to change the oil, and my owners manual tells me to use > 10w40 weight. as seen below im being advised to use straight 40. what > weight should i use? 40 grade Cx-II oil? > > thanks, robert > 85 pt40 6v92 > > Detroits have no glow plugs and "off the shelf" no starting assist. > They are ENTIRELY dependant on engine compression to start. They > also require (not recommend, REQUIRE) straight weight strength required > by the injector followers - you WILL destroy cams > if you run a 15W40 in them, > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
11-16-2006, 03:03
40 weight oil
The literature I have for my 91WL says straight 40 weight oil for the DD.
RWW 91WLWB Cedar Rapids, IA -----Original Message----- From: "Leroy Eckert" To: WanderlodgeForum@yahoogroups.com Sent: 11/16/06 8:18 AM Subject: Re: [WanderlodgeForum] 40 weight oil I'm also changing oil tomorrow. I've been using 15-40 Rotello. Please advise. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL 8V92 ----- Original Message ----- From: chapelhill2901 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 16, 2006 7:14 AM Subject: [WanderlodgeForum] 40 weight oil i am going to change the oil, and my owners manual tells me to use 10w40 weight. as seen below im being advised to use straight 40. what weight should i use? 40 grade Cx-II oil? thanks, robert 85 pt40 6v92 Detroits have no glow plugs and "off the shelf" no starting assist. They are ENTIRELY dependant on engine compression to start. They also require (not recommend, REQUIRE) straight weight strength required by the injector followers - you WILL destroy cams if you run a 15W40 in them, [Non-text portions of this message have been removed] |
11-16-2006, 04:04
40 weight oil
I've been using synthetic 15-40 oil in detroit's for 14 years now. I
would NEVER go back. I know a number of owner's that have made the switch and all are pleased. A number of plus's to it, reduced oil consumption, reduced smoke, plus the big advantage of extra engine protection. I;ve talked to the Detroit tech's that go to the fmca rally's and all agree there are big plus's to using the synthetic's. They also agree that if you use a multi-weight oil, it MUST be a synthetic. Work's for me...Bob 93pt Illinois |
11-16-2006, 05:19
40 weight oil
Me also. Use syn. diesel marine because the PO used it.Did oil analisys at
Blackstone was excelent wearing engine?I worry about it after reading these post from alot of tec's that should know but have not gone to the straight weight.Marvin SkaggsBuffalo, Ky. 427161984 PT40--- On Thu 11/16, Bob & Carol Howald` < rhowald@... > wrote:From: Bob & Carol Howald` [mailto: rhowald@...]To: WanderlodgeForum@...: Thu, 16 Nov 2006 16:04:47 -0000Subject: [WanderlodgeForum] Re: 40 weight oil I've been using synthetic 15-40 oil in detroit's for 14 years now. I would NEVER go back. I know a number of owner's that have made the switch and all are pleased. A number of plus's to it, reduced oil consumption, reduced smoke, plus the big advantage of extra engine protection. I;ve talked to the Detroit tech's that go to the fmca rally's and all agree there are big plus's to using the synthetic's. They also agree that if you use a multi-weight oil, it MUST be a synthetic. Work's for me...Bob 93pt Illinois _______________________________________________ Join Excite! - http://www.excite.com The most personalized portal on the Web! [Non-text portions of this message have been removed] |
11-16-2006, 05:26
40 weight oil
Hi DD engine owners,
That's 40 weight CF-2 rating. Craig 91PT40 DD-8V92 WPB,FL --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Leroy every DD person I have checked with told me to use only 40W oil with a > rating of CH2. Two brands which fit the bill and have a low ash content are > Rotella and Delo 100. I believe Curt Sprenger has a link to the Petroleum > Page that explains it all. Curt I've misplaced or lost my link to that page > so if you could repost it I'd appreciate it. > > On 16/11/06, Leroy Eckert > > > > I'm also changing oil tomorrow. I've been using 15-40 Rotello. Please > > advise. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > 8V92 > > > > ----- Original Message ----- > > From: chapelhill2901 > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, November 16, 2006 7:14 AM > > Subject: [WanderlodgeForum] 40 weight oil > > > > i am going to change the oil, and my owners manual tells me to use > > 10w40 weight. as seen below im being advised to use straight 40. what > > weight should i use? 40 grade Cx-II oil? > > > > thanks, robert > > 85 pt40 6v92 > > > > Detroits have no glow plugs and "off the shelf" no starting assist. > > They are ENTIRELY dependant on engine compression to start. They > > also require (not recommend, REQUIRE) straight weight strength required > > by the injector followers - you WILL destroy cams > > if you run a 15W40 in them, > > > > [Non-text portions of this message have been removed] > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
11-16-2006, 09:28
40 weight oil
Leroy,
I changed my oil to 40 weight Rotella just before the RIV/RATS Ralley. I could not find it at any of the discount stores had to go to the Shell Distributor to purchase it. Howard Truitt Camilla, Ga. 86 PT40, 8V92 "Under The Waterfall" [Non-text portions of this message have been removed] |
