Coach Potable Water Pump
11-18-2006, 11:23
Has anyone tried the Flojet variable speed water pump? They advertise higher
flow rates and less noise. We have a Shurflo that pump that is noisey and has sprung a leak so I'm tempted to try the Flojet. Eric in San Antonio 84FC35SBWL2 |
11-18-2006, 12:10
One thing to keep in mind Eric is that high flow usually means you run out
of water sooner. On 18/11/06, Eric Johnson > > Has anyone tried the Flojet variable speed water pump? They advertise > higher flow rates and > less noise. We have a Shurflo that pump that is noisey and has sprung a > leak so I'm tempted > to try the Flojet. > > Eric in San Antonio > 84FC35SBWL2 > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
11-18-2006, 16:02
Eric,
I replaced my factory water pump with a Jabsco model#31755. It provides 4.5 gallons per minute(GPM) and has a 12amp/12volt draw. I like it because its quiet, variable speed, variable flow, constant pressure(about 40 psi) and I could remove the accumulator tank. The accumulator tank can have its issues, such as trying to get the proper air pressure on the bladder side. The new pump has worked flawlessly for 3 years now. There are pumps with higher GPM and pressure, I haven't needed anything larger than the 4.5GPM, 40PSI. I think my house runs about 60psi, so the pump is really close to provideing the same pressure as home. It definitely provides more flow(GPM) than shore water does. I like it alot. My borther has the next bigger pump. Its a Shurflo Smart Sensor 5.7, 65psi. He likes it I think. Maybe he'll comment here, he's real bashful or doesn't talk much or sumthin.. ;~} Anyway, yea, make the change Jay Darst 85PT40 Springfield, IL where the lows are 29 degrees and the highs are in the 40's, kinda sucks for this time of year... --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" wrote: > > Has anyone tried the Flojet variable speed water pump? They advertise higher flow rates and > less noise. We have a Shurflo that pump that is noisey and has sprung a leak so I'm tempted > to try the Flojet. > > Eric in San Antonio > 84FC35SBWL2 > |
11-19-2006, 11:00
Thumbs up on the Shurflo Smart Sensor 5.7. Good pressure in the shower, no
accumulator tank, and overload/overheat shut down and automatic reset. Shop price and be sure to check at www dot rvpartsoutlet dot com. I do not have an economic or any other interest in it, but I probly wish I did. dandarst86fc35rbhuntleyil. >From: "Jay Darst" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Coach Potable Water Pump >Date: Sun, 19 Nov 2006 04:02:30 -0000 > >Eric, > >I replaced my factory water pump with a Jabsco model#31755. It >provides 4.5 gallons per minute(GPM) and has a 12amp/12volt draw. > >I like it because its quiet, variable speed, variable flow, constant >pressure(about 40 psi) and I could remove the accumulator tank. The >accumulator tank can have its issues, such as trying to get the >proper air pressure on the bladder side. > >The new pump has worked flawlessly for 3 years now. There are pumps >with higher GPM and pressure, I haven't needed anything larger than >the 4.5GPM, 40PSI. > >I think my house runs about 60psi, so the pump is really close to >provideing the same pressure as home. It definitely provides more >flow(GPM) than shore water does. > >I like it alot. My borther has the next bigger pump. Its a Shurflo >Smart Sensor 5.7, 65psi. He likes it I think. Maybe he'll comment >here, he's real bashful or doesn't talk much or sumthin.. ;~} > >Anyway, yea, make the change > >Jay Darst >85PT40 >Springfield, IL where the lows are 29 degrees and the highs are in >the 40's, kinda sucks for this time of year... > >--- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" >wrote: > > > > Has anyone tried the Flojet variable speed water pump? They >advertise higher flow rates and > > less noise. We have a Shurflo that pump that is noisey and has >sprung a leak so I'm tempted > > to try the Flojet. > > > > Eric in San Antonio > > 84FC35SBWL2 > > > > > _________________________________________________________________ Fixing up the home? Live Search can help http://imagine-windowslive.com/search/ki...en-US\ &source=hmemailtaglinenov06&FORM=WLMTAG |
11-19-2006, 11:01
accumulator tank, and overload/overheat shut down and automatic reset. Shop price and be sure to check at www dot rvpartsoutlet dot com. I do not have an economic or any other interest in it, but I probly wish I did. dandarst86fc35rbhuntleyil. >From: "Jay Darst" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Coach Potable Water Pump >Date: Sun, 19 Nov 2006 04:02:30 -0000 > >Eric, > >I replaced my factory water pump with a Jabsco model#31755. It >provides 4.5 gallons per minute(GPM) and has a 12amp/12volt draw. > >I like it because its quiet, variable speed, variable flow, constant >pressure(about 40 psi) and I could remove the accumulator tank. The >accumulator tank can have its issues, such as trying to get the >proper air pressure on the bladder side. > >The new pump has worked flawlessly for 3 years now. There are pumps >with higher GPM and pressure, I haven't needed anything larger than >the 4.5GPM, 40PSI. > >I think my house runs about 60psi, so the pump is really close to >provideing the same pressure as home. It definitely provides more >flow(GPM) than shore water does. > >I like it alot. My borther has the next bigger pump. Its a Shurflo >Smart Sensor 5.7, 65psi. He likes it I think. Maybe he'll comment >here, he's real bashful or doesn't talk much or sumthin.. ;~} > >Anyway, yea, make the change > >Jay Darst >85PT40 >Springfield, IL where the lows are 29 degrees and the highs are in >the 40's, kinda sucks for this time of year... > >--- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" >wrote: > > > > Has anyone tried the Flojet variable speed water pump? They >advertise higher flow rates and > > less noise. We have a Shurflo that pump that is noisey and has >sprung a leak so I'm tempted > > to try the Flojet. > > > > Eric in San Antonio > > 84FC35SBWL2 > > > > > _________________________________________________________________ Talk now to your Hotmail contacts with Windows Live Messenger. http://clk.atdmt.com/MSN/go/msnnkwme0020...t.liv\ e.com/messenger/overview |
11-19-2006, 11:19
Hi Jay,
My FloJet accumulator tank just threw in the towel. In addition, in my short time with my coach I've gone through 2 Shurflo diaphragm water pumps; time to look for alternatives, which leads me to your serendipitous post. Is there anything I need to know about adapting the Jabsco 31755 to my bus, or is it simply remove the rats nest of parallel Shurflo's and the accumulator tank along with all the associated plumbing and drop in one single elegant device, the Jabsco? Thanks David Brady '02 LXi, Smoke Va, "but not for long" Jay Darst wrote: > Eric, > > I replaced my factory water pump with a Jabsco model#31755. It > provides 4.5 gallons per minute(GPM) and has a 12amp/12volt draw. > > I like it because its quiet, variable speed, variable flow, constant > pressure(about 40 psi) and I could remove the accumulator tank. The > accumulator tank can have its issues, such as trying to get the > proper air pressure on the bladder side. > > The new pump has worked flawlessly for 3 years now. There are pumps > with higher GPM and pressure, I haven't needed anything larger than > the 4.5GPM, 40PSI. > > I think my house runs about 60psi, so the pump is really close to > provideing the same pressure as home. It definitely provides more > flow(GPM) than shore water does. > > I like it alot. My borther has the next bigger pump. Its a Shurflo > Smart Sensor 5.7, 65psi. He likes it I think. Maybe he'll comment > here, he's real bashful or doesn't talk much or sumthin.. ;~} > > Anyway, yea, make the change > > Jay Darst > 85PT40 > Springfield, IL where the lows are 29 degrees and the highs are in > the 40's, kinda sucks for this time of year... > > --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > wrote: > >> Has anyone tried the Flojet variable speed water pump? They >> > advertise higher flow rates and > >> less noise. We have a Shurflo that pump that is noisey and has >> > sprung a leak so I'm tempted > >> to try the Flojet. >> >> Eric in San Antonio >> 84FC35SBWL2 >> >> [Non-text portions of this message have been removed] |
11-19-2006, 12:47
David,
I removed my old noisey diaphram pump, the accumulator and the on board water filter. All of this was in the same crampt spot, so really made some room with just the pump going back in. If I do it over again, I'd get the Shurflo Smart Sensor 5.7. Brother has it, works great, bit higher shower pressure, little better volume (in case some in the kitchen while I'm in the shower). The pump will come with a variety of connectors for the water lines. I didn't have to buy anything else(85PT40) as they sent everything I needed. Not seen the much newer '02 pump set up. Do the redundant pumps run simultaneously? Get rid of the accunulator and both pumps, the variable speed pumps do a very good job. Was pleasantly surprised when it performed as described, you DO NOT need an accumulator. The only time I notice the micro second delay is while shaving, rinsing the razor without just leaving the water on. (not supposed shave while playing anyway ;~} ...) Make the change and don't look back! Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Hi Jay, > > My FloJet accumulator tank just threw in the towel. In addition, > in my short time with my coach I've gone through 2 Shurflo diaphragm > water pumps; time to look for alternatives, which leads me to > your serendipitous post. Is there anything I need to know about > adapting the Jabsco 31755 to my bus, or is it simply remove the > rats nest of parallel Shurflo's and the accumulator tank along with > all the associated plumbing and drop in one single elegant device, > the Jabsco? > > Thanks > David Brady > '02 LXi, Smoke > Va, "but not for long" > > Jay Darst wrote: > > Eric, > > > > I replaced my factory water pump with a Jabsco model#31755. It > > provides 4.5 gallons per minute(GPM) and has a 12amp/12volt draw. > > > > I like it because its quiet, variable speed, variable flow, constant > > pressure(about 40 psi) and I could remove the accumulator tank. The > > accumulator tank can have its issues, such as trying to get the > > proper air pressure on the bladder side. > > > > The new pump has worked flawlessly for 3 years now. There are pumps > > with higher GPM and pressure, I haven't needed anything larger than > > the 4.5GPM, 40PSI. > > > > I think my house runs about 60psi, so the pump is really close to > > provideing the same pressure as home. It definitely provides more > > flow(GPM) than shore water does. > > > > I like it alot. My borther has the next bigger pump. Its a Shurflo > > Smart Sensor 5.7, 65psi. He likes it I think. Maybe he'll comment > > here, he's real bashful or doesn't talk much or sumthin.. ;~} > > > > Anyway, yea, make the change > > > > Jay Darst > > 85PT40 > > Springfield, IL where the lows are 29 degrees and the highs are in > > the 40's, kinda sucks for this time of year... > > > > --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > > wrote: > > > >> Has anyone tried the Flojet variable speed water pump? They > >> > > advertise higher flow rates and > > > >> less noise. We have a Shurflo that pump that is noisey and has > >> > > sprung a leak so I'm tempted > > > >> to try the Flojet. > >> > >> Eric in San Antonio > >> 84FC35SBWL2 > >> > >> > > > > [Non-text portions of this message have been removed] > |
11-19-2006, 13:07
Thanks Jay,
On my coach the Shurflo 2088 pumps run simultaneously. Others have wired in a switch to use one as a backup. Do you have a preferred vendor to buy the pump from? Looking forward to freeing up some space in the basement water pump closet. David B '02 LXi, Smokey Va, soon to be NC Jay Darst wrote: > David, > > I removed my old noisey diaphram pump, the accumulator and the on > board water filter. All of this was in the same crampt spot, so > really made some room with just the pump going back in. > > If I do it over again, I'd get the Shurflo Smart Sensor 5.7. Brother > has it, works great, bit higher shower pressure, little better volume > (in case some in the kitchen while I'm in the shower). > > The pump will come with a variety of connectors for the water lines. > I didn't have to buy anything else(85PT40) as they sent everything I > needed. Not seen the much newer '02 pump set up. > > Do the redundant pumps run simultaneously? > > Get rid of the accunulator and both pumps, the variable speed pumps > do a very good job. Was pleasantly surprised when it performed as > described, you DO NOT need an accumulator. > > The only time I notice the micro second delay is while shaving, > rinsing the razor without just leaving the water on. (not supposed > shave while playing anyway ;~} ...) > > Make the change and don't look back! > > Jay Darst > 85PT40 > Springfield, IL > > > --- In WanderlodgeForum@yahoogroups.com, David Brady > wrote: > >> Hi Jay, >> >> My FloJet accumulator tank just threw in the towel. In addition, >> in my short time with my coach I've gone through 2 Shurflo >> > diaphragm > >> water pumps; time to look for alternatives, which leads me to >> your serendipitous post. Is there anything I need to know about >> adapting the Jabsco 31755 to my bus, or is it simply remove the >> rats nest of parallel Shurflo's and the accumulator tank along with >> all the associated plumbing and drop in one single elegant device, >> the Jabsco? >> >> Thanks >> David Brady >> '02 LXi, Smoke >> Va, "but not for long" >> >> Jay Darst wrote: >> >>> Eric, >>> >>> I replaced my factory water pump with a Jabsco model#31755. It >>> provides 4.5 gallons per minute(GPM) and has a 12amp/12volt draw. >>> >>> I like it because its quiet, variable speed, variable flow, >>> > constant > >>> pressure(about 40 psi) and I could remove the accumulator tank. >>> > The > >>> accumulator tank can have its issues, such as trying to get the >>> proper air pressure on the bladder side. >>> >>> The new pump has worked flawlessly for 3 years now. There are >>> > pumps > >>> with higher GPM and pressure, I haven't needed anything larger >>> > than > >>> the 4.5GPM, 40PSI. >>> >>> I think my house runs about 60psi, so the pump is really close >>> > to > >>> provideing the same pressure as home. It definitely provides >>> > more > >>> flow(GPM) than shore water does. >>> >>> I like it alot. My borther has the next bigger pump. Its a >>> > Shurflo > >>> Smart Sensor 5.7, 65psi. He likes it I think. Maybe he'll >>> > comment > >>> here, he's real bashful or doesn't talk much or sumthin.. ;~} >>> >>> Anyway, yea, make the change >>> >>> Jay Darst >>> 85PT40 >>> Springfield, IL where the lows are 29 degrees and the highs are >>> > in > >>> the 40's, kinda sucks for this time of year... >>> >>> --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" >>> > > >>> wrote: >>> >>> >>>> Has anyone tried the Flojet variable speed water pump? They >>>> >>>> >>> advertise higher flow rates and >>> >>> >>>> less noise. We have a Shurflo that pump that is noisey and has >>>> >>>> >>> sprung a leak so I'm tempted >>> >>> >>>> to try the Flojet. >>>> >>>> Eric in San Antonio >>>> 84FC35SBWL2 >>>> >>>> >>>> >> >> [Non-text portions of this message have been removed] >> >> > > > > > > > [Non-text portions of this message have been removed] |
11-19-2006, 13:34
David,
The supplier Dan I both used was https://www.rvpartsoutlet.com/newstore/nojava/index.cfm The pump I reccomend is https://www.rvpartsoutlet.com/newstore/n...wprod.cfm? ID=3513&src=shurflo&refid=9CDF3CAF%2DCDA5%2D4DC8%2D8D99A5E0D4D79D92 If you have trouble with the link, its their Stock Number:19-0163 Its currently on special for $149.95, a pretty good buy on this pump. Its $169.95 over at PPL, and $193.50 at Camping World. Have used RVPartsOutlet.com many times, great prices and same great service. Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Thanks Jay, > > On my coach the Shurflo 2088 pumps run simultaneously. Others > have wired in a switch to use one as a backup. Do you have a preferred > vendor to buy the pump from? Looking forward to freeing up some > space in the basement water pump closet. > > David B > '02 LXi, Smokey > Va, soon to be NC > > Jay Darst wrote: > > David, > > > > I removed my old noisey diaphram pump, the accumulator and the on > > board water filter. All of this was in the same crampt spot, so > > really made some room with just the pump going back in. > > > > If I do it over again, I'd get the Shurflo Smart Sensor 5.7. Brother > > has it, works great, bit higher shower pressure, little better volume > > (in case some in the kitchen while I'm in the shower). > > > > The pump will come with a variety of connectors for the water lines. > > I didn't have to buy anything else(85PT40) as they sent everything I > > needed. Not seen the much newer '02 pump set up. > > > > Do the redundant pumps run simultaneously? > > > > Get rid of the accunulator and both pumps, the variable speed pumps > > do a very good job. Was pleasantly surprised when it performed as > > described, you DO NOT need an accumulator. > > > > The only time I notice the micro second delay is while shaving, > > rinsing the razor without just leaving the water on. (not supposed > > shave while playing anyway ;~} ...) > > > > Make the change and don't look back! > > > > Jay Darst > > 85PT40 > > Springfield, IL > > > > > > --- In WanderlodgeForum@yahoogroups.com, David Brady > > wrote: > > > >> Hi Jay, > >> > >> My FloJet accumulator tank just threw in the towel. In addition, > >> in my short time with my coach I've gone through 2 Shurflo > >> > > diaphragm > > > >> water pumps; time to look for alternatives, which leads me to > >> your serendipitous post. Is there anything I need to know about > >> adapting the Jabsco 31755 to my bus, or is it simply remove the > >> rats nest of parallel Shurflo's and the accumulator tank along with > >> all the associated plumbing and drop in one single elegant device, > >> the Jabsco? > >> > >> Thanks > >> David Brady > >> '02 LXi, Smoke > >> Va, "but not for long" > >> > >> Jay Darst wrote: > >> > >>> Eric, > >>> > >>> I replaced my factory water pump with a Jabsco model#31755. It > >>> provides 4.5 gallons per minute(GPM) and has a 12amp/12volt draw. > >>> > >>> I like it because its quiet, variable speed, variable flow, > >>> > > constant > > > >>> pressure(about 40 psi) and I could remove the accumulator tank. > >>> > > The > > > >>> accumulator tank can have its issues, such as trying to get the > >>> proper air pressure on the bladder side. > >>> > >>> The new pump has worked flawlessly for 3 years now. There are > >>> > > pumps > > > >>> with higher GPM and pressure, I haven't needed anything larger > >>> > > than > > > >>> the 4.5GPM, 40PSI. > >>> > >>> I think my house runs about 60psi, so the pump is really close > >>> > > to > > > >>> provideing the same pressure as home. It definitely provides > >>> > > more > > > >>> flow(GPM) than shore water does. > >>> > >>> I like it alot. My borther has the next bigger pump. Its a > >>> > > Shurflo > > > >>> Smart Sensor 5.7, 65psi. He likes it I think. Maybe he'll > >>> > > comment > > > >>> here, he's real bashful or doesn't talk much or sumthin.. ;~} > >>> > >>> Anyway, yea, make the change > >>> > >>> Jay Darst > >>> 85PT40 > >>> Springfield, IL where the lows are 29 degrees and the highs are > >>> > > in > > > >>> the 40's, kinda sucks for this time of year... > >>> > >>> --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > >>> > > > > > >>> wrote: > >>> > >>> > >>>> Has anyone tried the Flojet variable speed water pump? They > >>>> > >>>> > >>> advertise higher flow rates and > >>> > >>> > >>>> less noise. We have a Shurflo that pump that is noisey and has > >>>> > >>>> > >>> sprung a leak so I'm tempted > >>> > >>> > >>>> to try the Flojet. > >>>> > >>>> Eric in San Antonio > >>>> 84FC35SBWL2 > >>>> > >>>> > >>>> > >> > >> [Non-text portions of this message have been removed] > >> > >> > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
11-19-2006, 14:08
Try www dot rvpartsoutlet dot com
dandarst86fc35rbhuntleyil. >From: David Brady >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: Coach Potable Water Pump >Date: Sun, 19 Nov 2006 20:07:32 -0500 > >Thanks Jay, > >On my coach the Shurflo 2088 pumps run simultaneously. Others >have wired in a switch to use one as a backup. Do you have a preferred >vendor to buy the pump from? Looking forward to freeing up some >space in the basement water pump closet. > >David B >'02 LXi, Smokey >Va, soon to be NC > >Jay Darst wrote: > > David, > > > > I removed my old noisey diaphram pump, the accumulator and the on > > board water filter. All of this was in the same crampt spot, so > > really made some room with just the pump going back in. > > > > If I do it over again, I'd get the Shurflo Smart Sensor 5.7. Brother > > has it, works great, bit higher shower pressure, little better volume > > (in case some in the kitchen while I'm in the shower). > > > > The pump will come with a variety of connectors for the water lines. > > I didn't have to buy anything else(85PT40) as they sent everything I > > needed. Not seen the much newer '02 pump set up. > > > > Do the redundant pumps run simultaneously? > > > > Get rid of the accunulator and both pumps, the variable speed pumps > > do a very good job. Was pleasantly surprised when it performed as > > described, you DO NOT need an accumulator. > > > > The only time I notice the micro second delay is while shaving, > > rinsing the razor without just leaving the water on. (not supposed > > shave while playing anyway ;~} ...) > > > > Make the change and don't look back! > > > > Jay Darst > > 85PT40 > > Springfield, IL > > > > > > --- In WanderlodgeForum@yahoogroups.com, David Brady > > wrote: > > > >> Hi Jay, > >> > >> My FloJet accumulator tank just threw in the towel. In addition, > >> in my short time with my coach I've gone through 2 Shurflo > >> > > diaphragm > > > >> water pumps; time to look for alternatives, which leads me to > >> your serendipitous post. Is there anything I need to know about > >> adapting the Jabsco 31755 to my bus, or is it simply remove the > >> rats nest of parallel Shurflo's and the accumulator tank along with > >> all the associated plumbing and drop in one single elegant device, > >> the Jabsco? > >> > >> Thanks > >> David Brady > >> '02 LXi, Smoke > >> Va, "but not for long" > >> > >> Jay Darst wrote: > >> > >>> Eric, > >>> > >>> I replaced my factory water pump with a Jabsco model#31755. It > >>> provides 4.5 gallons per minute(GPM) and has a 12amp/12volt draw. > >>> > >>> I like it because its quiet, variable speed, variable flow, > >>> > > constant > > > >>> pressure(about 40 psi) and I could remove the accumulator tank. > >>> > > The > > > >>> accumulator tank can have its issues, such as trying to get the > >>> proper air pressure on the bladder side. > >>> > >>> The new pump has worked flawlessly for 3 years now. There are > >>> > > pumps > > > >>> with higher GPM and pressure, I haven't needed anything larger > >>> > > than > > > >>> the 4.5GPM, 40PSI. > >>> > >>> I think my house runs about 60psi, so the pump is really close > >>> > > to > > > >>> provideing the same pressure as home. It definitely provides > >>> > > more > > > >>> flow(GPM) than shore water does. > >>> > >>> I like it alot. My borther has the next bigger pump. Its a > >>> > > Shurflo > > > >>> Smart Sensor 5.7, 65psi. He likes it I think. Maybe he'll > >>> > > comment > > > >>> here, he's real bashful or doesn't talk much or sumthin.. ;~} > >>> > >>> Anyway, yea, make the change > >>> > >>> Jay Darst > >>> 85PT40 > >>> Springfield, IL where the lows are 29 degrees and the highs are > >>> > > in > > > >>> the 40's, kinda sucks for this time of year... > >>> > >>> --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > >>> > > > > > >>> wrote: > >>> > >>> > >>>> Has anyone tried the Flojet variable speed water pump? They > >>>> > >>>> > >>> advertise higher flow rates and > >>> > >>> > >>>> less noise. We have a Shurflo that pump that is noisey and has > >>>> > >>>> > >>> sprung a leak so I'm tempted > >>> > >>> > >>>> to try the Flojet. > >>>> > >>>> Eric in San Antonio > >>>> 84FC35SBWL2 > >>>> > >>>> > >>>> > >> > >> [Non-text portions of this message have been removed] > >> > >> > > > > > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > _________________________________________________________________ MSN Shopping has everything on your holiday list. Get expert picks by style, age, and price. Try it! http://shopping.msn.com/content/shp/?ctI...code=\ wlmtagline |
