Rediline relay
11-19-2006, 03:48
Rediline relay
MR,
I have looked everywhere for that relay. Must have sold it at one of the RIV's swap meet. Looked in the database, files in both forums, can't find the part number. Someone here has got that info. Could someone provide the part number for the ice maker relay here? Thanks Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > M.R., > > Replace the relay and the noise will be gone. If ya want, I'll see if > I still have one around here. I put it in and then shortly after, > installed a Xantrex 2,500 watt inverter/charger. So, the rlay comes > out permanently with the inverter update. > > Where r u from? > > Does your dash a/c work? > > Jay Darst > 85PT40 > Springfield, IL > > > > > --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@> > wrote: > > > > Greetings All: > > > > Anyone have a suggested modification to cure the noisy Rediline > relay? > > Perhaps a replacement latching relay that won't hum? I would like > to > > keep the option of using the Rediline, but the noise is too obnoxious > > when in an otherwise quiet environment. > > > > Thanks-- > > M.R.Kane > > '85 PT40 > > > |
11-19-2006, 10:33
Rediline relay
The "ice maker relay" part is as follows:
Potter Brumfield part number PRD11AGO-120 Magnacraft part number W199ABX-14 phone number 312-564-8800 Magnacraft 1910 Techny Rd. Northbrook, Illinois 60062 another source: wwwdotsmcelectonicsdotcom dandarst86fc35rbhuntleyil. >From: "Jay Darst" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Rediline relay >Date: Sun, 19 Nov 2006 15:48:59 -0000 > >MR, > >I have looked everywhere for that relay. Must have sold it at one of >the RIV's swap meet. > >Looked in the database, files in both forums, can't find the part >number. > >Someone here has got that info. Could someone provide the part >number for the ice maker relay here? > >Thanks >Jay Darst >85PT40 >Springfield, IL > > >--- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > M.R., > > > > Replace the relay and the noise will be gone. If ya want, I'll see >if > > I still have one around here. I put it in and then shortly after, > > installed a Xantrex 2,500 watt inverter/charger. So, the rlay >comes > > out permanently with the inverter update. > > > > Where r u from? > > > > Does your dash a/c work? > > > > Jay Darst > > 85PT40 > > Springfield, IL > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@> > > wrote: > > > > > > Greetings All: > > > > > > Anyone have a suggested modification to cure the noisy Rediline > > relay? > > > Perhaps a replacement latching relay that won't hum? I would >like > > to > > > keep the option of using the Rediline, but the noise is too >obnoxious > > > when in an otherwise quiet environment. > > > > > > Thanks-- > > > M.R.Kane > > > '85 PT40 > > > > > > > > _________________________________________________________________ View Athleteâs Collections with Live Search http://sportmaps.live.com/index.html?sou...ORM=MGAC01 |
11-19-2006, 15:21
Rediline relay
Thanks for the replies. The relay referenced is an "open" type. Is
this correct for our application in an environment where LP gas might be present? [I haven't removed the cover on mine to look yet as it is on the galley wall under the sink behind some plumbing. Only wanted to fight the access problem once ;-) .] --M.R.Kane '85 PT40 --- In WanderlodgeForum@yahoogroups.com, "Dan Darst" > > The "ice maker relay" part is as follows: > > Potter Brumfield part number PRD11AGO-120 > Magnacraft part number W199ABX-14 phone number 312-564-8800 Magnacraft 1910 > Techny Rd. Northbrook, Illinois 60062 > > another source: wwwdotsmcelectonicsdotcom > > dandarst86fc35rbhuntleyil. > > |
11-19-2006, 15:42
Rediline relay
Cannot answer whether its an "open" type. Mine was enclosed in a steel
junction box typically used for electric connections, and was located in an area similar to what you have described. I gave my new relay to John Finn two or three years ago when I put in the new inverter, so I don't have it any longer and do not use one. dandarst86fc35rbhuntleyil. >From: "mrkane1952" <mrkane@...> >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Rediline relay >Date: Mon, 20 Nov 2006 03:21:25 -0000 > >Thanks for the replies. The relay referenced is an "open" type. Is >this correct for our application in an environment where LP gas might >be present? [I haven't removed the cover on mine to look yet as it is >on the galley wall under the sink behind some plumbing. Only wanted to >fight the access problem once ;-) .] > >--M.R.Kane >'85 PT40 > > >--- In WanderlodgeForum@yahoogroups.com, "Dan Darst" > > > > The "ice maker relay" part is as follows: > > > > Potter Brumfield part number PRD11AGO-120 > > Magnacraft part number W199ABX-14 phone number 312-564-8800 >Magnacraft 1910 > > Techny Rd. Northbrook, Illinois 60062 > > > > another source: wwwdotsmcelectonicsdotcom > > > > dandarst86fc35rbhuntleyil. > > > > > > _________________________________________________________________ Get the latest Windows Live Messenger 8.1 Beta version. Join now. http://ideas.live.com |
