Webasto Works GOOD!!!
11-22-2006, 02:49
Howdy, Y'all.
At night the temperature has been dropping down into the low 30's, here in Hondo, TX. The previous owner of our coach converted the Primus heating system to a Webasto heating system. This works really well and it produces heat very quickly. I mean within 6-8 minutes, I can feel very warm air being circulated by the fans. The only thing that we don't know if how much fuel is burned to produce the heat. I reckon I'll keep an eye on the fuel gauge. I just wanted to post our experiences if you are considering doing this heating system conversion. Happy Thanksgiving, Jack and Liz Pearce Fullltiming in a 1993 Wanderlodge Wintering in Hondo, TX |
11-22-2006, 16:36
The Webasto furnaces do use a lot of fuel. I had the DBW 2010, (20,000 btu) on
a 40' boat and it worked great but used lots of fuel. (The DBW2020, (40,000 btu) unit used even more). But then, it's heat you are looking for, right? The Primus propane system uses a lot of fuel also and seems to have it's own other issues as well. I can't quantify what a "lot of fuel" is but let's just say that they are not very fuel efficient, none of them. We now have 3 Suburban furnaces in our "older" coach and they seem to be quite stingy on propane. However, unlike your system, we usually do not heat the whole coach by having all 3 on at once. Dick Hayden - '87 PT 38 - Lake Stevens, WA [Non-text portions of this message have been removed] |
11-26-2006, 12:43
We converted to a Wabasto Scholastic Series diesel fired hydronic system two
years ago. Info from my spec book. 1. Fuel usage .4 gph, actual burn time, not circulation time. 2. Burner starts at 167 degree water temp or below. 3. Interior thermostat shuts off the burner when interior temp reaches desired setting. Circulation is continuous. 4. 45,000 btu While we have no way of checking fuel burn, I would estimate 5 gallon per day if the system is on all day. 24 hrs. It works great and we no longer need to move the coach to get LP gas. LP is used for the kitchen stove, the fridge and the outside grill. Haven't filled the LP tank in almost 2 years. Regards. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Jack and Liz Pearce To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, November 22, 2006 8:49 AM Subject: [WanderlodgeForum] Webasto Works GOOD!!! Howdy, Y'all. At night the temperature has been dropping down into the low 30's, here in Hondo, TX. The previous owner of our coach converted the Primus heating system to a Webasto heating system. This works really well and it produces heat very quickly. I mean within 6-8 minutes, I can feel very warm air being circulated by the fans. The only thing that we don't know if how much fuel is burned to produce the heat. I reckon I'll keep an eye on the fuel gauge. I just wanted to post our experiences if you are considering doing this heating system conversion. Happy Thanksgiving, Jack and Liz Pearce Fullltiming in a 1993 Wanderlodge Wintering in Hondo, TX [Non-text portions of this message have been removed] |
11-27-2006, 12:11
> > We converted to a Wabasto Scholastic Series diesel fired hydronic system two years ago. Sounds like we have the same system, Leroy. Jack and Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Wintering In Hondo, TX - 2006 |
11-27-2006, 15:59
Jack& Liz:
Love it. Gets warm fast. We will be in San Antonio area from Dec 18-22 if all goes well. Bring us some good weather, please. Leroy and Rhonda Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Jack and Liz Pearce To: WanderlodgeForum@yahoogroups.com Sent: Monday, November 27, 2006 6:11 PM Subject: [WanderlodgeForum] Re: Webasto Works GOOD!!! --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > We converted to a Wabasto Scholastic Series diesel fired hydronic system two years ago. Sounds like we have the same system, Leroy. Jack and Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Wintering In Hondo, TX - 2006 [Non-text portions of this message have been removed] |
11-30-2006, 03:53
> > Jack& Liz: > Love it. Gets warm fast. > We will be in San Antonio area from Dec 18-22 if all goes well. Bring us some good weather, please. > > Leroy and Rhonda Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL Good. Where will you be? We will come over and put the old iball on you. Regards, Liz |
11-30-2006, 05:10
Liz:
Would love to meet you folks. We will be at Traveler's World RV Park, 2617 Roosevelt Ave.,in San Antonio. They assured me I can get in with the trailer. Want to take the grandkids to Alamo and the River Walk, stuff like that. Then on to South Padre on the 23rd. Cell-850-830-9163 or 850-830-5149. We could also come to your location if that's more convienent. Leroy & Rhonda Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Jack and Liz Pearce To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 30, 2006 9:53 AM Subject: [WanderlodgeForum] Re: Webasto Works GOOD!!! --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Jack& Liz: > Love it. Gets warm fast. > We will be in San Antonio area from Dec 18-22 if all goes well. Bring us some good weather, please. > > Leroy and Rhonda Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL Good. Where will you be? We will come over and put the old iball on you. Regards, Liz [Non-text portions of this message have been removed] |
11-30-2006, 05:50
I have an AquaHot heater that is powered by the Webasto DBW2010
burner. In this application this Webasto uses a .35 GPH nozzle and produces approximately 40,000 BTU's. DBW 2010's are rated from 40,000 to 45,000 depending on the nozzle. The DBW2020 puts out from 80,000 to 105,000 BTU's, more than what is needed in motorhome applications. In actual use you must take into consideration whether or not your setup includes an additional electric element. With that included in the AquaHot and plugged in to shore power I used less that 60 gallons all last winter to keep the coach at 50 degrees in a cold New England barn. In actual use when heating both hot water for showers and heat for the coach you will be hard pressed to use 2 to 3 gallons per day at 30 degree temperatures. With no electric you will use more, if you are not heating the domestic hot water you will use less. Six hours per 24 hour period is a lot of run time for the burner unless you have really cold, below zero temps. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > We converted to a Wabasto Scholastic Series diesel fired hydronic system two years ago. > Info from my spec book. > 1. Fuel usage .4 gph, actual burn time, not circulation time. > 2. Burner starts at 167 degree water temp or below. > 3. Interior thermostat shuts off the burner when interior temp reaches desired setting. Circulation is continuous. > 4. 45,000 btu > While we have no way of checking fuel burn, I would estimate 5 gallon per day if the system is on all day. 24 hrs. > It works great and we no longer need to move the coach to get LP gas. LP is used for the kitchen stove, the fridge and the outside grill. Haven't filled the LP tank in almost 2 years. > Regards. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > > > > > > ----- Original Message ----- > From: Jack and Liz Pearce > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, November 22, 2006 8:49 AM > Subject: [WanderlodgeForum] Webasto Works GOOD!!! > > > Howdy, Y'all. > > At night the temperature has been dropping down into the low 30's, here > in Hondo, TX. The previous owner of our coach converted the Primus > heating system to a Webasto heating system. This works really well and > it produces heat very quickly. I mean within 6-8 minutes, I can feel > very warm air being circulated by the fans. The only thing that we > don't know if how much fuel is burned to produce the heat. I reckon > I'll keep an eye on the fuel gauge. I just wanted to post our > experiences if you are considering doing this heating system conversion. > > Happy Thanksgiving, > Jack and Liz Pearce > Fullltiming in a 1993 Wanderlodge > Wintering in Hondo, TX > > > > > > [Non-text portions of this message have been removed] > |
11-30-2006, 06:31
Rich:
Thanks for the actual fuel burn info. I was estimating 50% burn time when in actual long-term cold weather use it's more like 25% burn time. Very helpful. I'm certain Jack and Liz out in Hondo, TX will be interested also. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: g_man1146 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 30, 2006 11:50 AM Subject: [WanderlodgeForum] Re: Webasto Works GOOD!!! I have an AquaHot heater that is powered by the Webasto DBW2010 burner. In this application this Webasto uses a .35 GPH nozzle and produces approximately 40,000 BTU's. DBW 2010's are rated from 40,000 to 45,000 depending on the nozzle. The DBW2020 puts out from 80,000 to 105,000 BTU's, more than what is needed in motorhome applications. In actual use you must take into consideration whether or not your setup includes an additional electric element. With that included in the AquaHot and plugged in to shore power I used less that 60 gallons all last winter to keep the coach at 50 degrees in a cold New England barn. In actual use when heating both hot water for showers and heat for the coach you will be hard pressed to use 2 to 3 gallons per day at 30 degree temperatures. With no electric you will use more, if you are not heating the domestic hot water you will use less. Six hours per 24 hour period is a lot of run time for the burner unless you have really cold, below zero temps. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > We converted to a Wabasto Scholastic Series diesel fired hydronic system two years ago. > Info from my spec book. > 1. Fuel usage .4 gph, actual burn time, not circulation time. > 2. Burner starts at 167 degree water temp or below. > 3. Interior thermostat shuts off the burner when interior temp reaches desired setting. Circulation is continuous. > 4. 45,000 btu > While we have no way of checking fuel burn, I would estimate 5 gallon per day if the system is on all day. 24 hrs. > It works great and we no longer need to move the coach to get LP gas. LP is used for the kitchen stove, the fridge and the outside grill. Haven't filled the LP tank in almost 2 years. > Regards. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > > > > > > ----- Original Message ----- > From: Jack and Liz Pearce > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, November 22, 2006 8:49 AM > Subject: [WanderlodgeForum] Webasto Works GOOD!!! > > > Howdy, Y'all. > > At night the temperature has been dropping down into the low 30's, here > in Hondo, TX. The previous owner of our coach converted the Primus > heating system to a Webasto heating system. This works really well and > it produces heat very quickly. I mean within 6-8 minutes, I can feel > very warm air being circulated by the fans. The only thing that we > don't know if how much fuel is burned to produce the heat. I reckon > I'll keep an eye on the fuel gauge. I just wanted to post our > experiences if you are considering doing this heating system conversion. > > Happy Thanksgiving, > Jack and Liz Pearce > Fullltiming in a 1993 Wanderlodge > Wintering in Hondo, TX > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
