working on water, no juice to pump
11-23-2006, 08:10
Hi Group
in working on the water issue there is now no juice to the pump or pump switch in the galley panel. Checked the load center L rear and L middle, isn't there another load center in the very front L somewhere...where? thanks Rose Mary 82 FC Side bath in Reno cell 541 817 5826 |
11-23-2006, 10:10
My outside switch had bit the dust. Replaced that- works great.
Ernie Ekberg and Brenda gonna get cold- making plans for the trip home 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
11-23-2006, 11:51
Rose Mary:
Before you go too far, have you checked to see if the pump will work from the bathroom. The galley and bathroom switches are hooked up like a 3 way switch in your house. You might have to check it a number of ways if the switch was installed wrong. Try by having both switches up, or down, and then in opposite positions. When I get to the apartment tonight I will look at the drawings to see if any other possibilities. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Rose Mary To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 23, 2006 12:10:28 PM Subject: [WanderlodgeForum] working on water, no juice to pump Hi Group in working on the water issue there is now no juice to the pump or pump switch in the galley panel. Checked the load center L rear and L middle, isn't there another load center in the very front L somewhere... where? thanks Rose Mary 82 FC Side bath in Reno cell 541 817 5826 __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
11-23-2006, 14:24
Rose Mary:
If you have a pump switch at the outside water fill point you might want to make sure it is turned on. On mine '82 if the switch was in the wrong position the pump would not work. Marv Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Rose Mary: > Before you go too far, have you checked to see if the pump will work from the bathroom. > The galley and bathroom switches are hooked up like a 3 way switch in your house. > You might have to check it a number of ways if the switch was installed wrong. > Try by having both switches up, or down, and then in opposite positions. > When I get to the apartment tonight I will look at the drawings to see if any other possibilities. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ----- Original Message ---- > From: Rose Mary > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, November 23, 2006 12:10:28 PM > Subject: [WanderlodgeForum] working on water, no juice to pump > > Hi Group > in working on the water issue there is now no juice to the pump or > pump switch in the galley panel. > Checked the load center L rear and L middle, isn't there another load > center in the very front L somewhere... where? > thanks > Rose Mary > 82 FC Side bath > in Reno > > cell 541 817 5826 > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > |
