Low Volt Buzzer
11-23-2006, 16:09
Low Volt Buzzer
Why would my buzzer sound for the low battery voltage when I turn on a
few lights around the coach? Sometimes, I have to go up front and reset the low volts reset on the dash that controls the fuse panel under the couch. I do not understand why it would be low.. I have 4 new 6 volt batteries, and the new battery charger was on! The volts on the dash gauge read over 13, when I reset the low volt switch.. Coach starts fine, (buzzer does sound while turning over starter)--but lights were never dim, or low when the buzzer sounds, and trips the low volts breaker. I had the solon lights on, the over door, and bedroom lights on (all florescent), then it buzzed. Does this sound like a problem with my PMMI buzzer? Or Ground? I know it's not my batteries, or new Progressive Dynamics charger... Now, I have the Gremlin!!! Stephen H 81 FC-33SB Plant City, FL |
