Florescent light tool
11-24-2006, 05:25
Scott- so you mean the pair of channel locks I use is not as good as your
nonskid??? Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
11-24-2006, 07:54
I see that there are several posts about the lights in our coaches. I
dont know about you but I found removing the light bulbs to be a true lesson in patience, no to mention doing it with my eyes closed waiting for the bulb to explode. I have changed many lights inside the coach and found the best tool for removing the lights... Take about a two inch wide by 6"-8" long piece of non skid (the stuff the wife uses to keep dishes from sliding around) now insert one side of it up one side of and around the bulb. pulling it out the other side. THEN CRISS CROSS the non skid and pull it tight so it twists the light and viola... out comes the light.. Stephen, maybe we could add that to your parts inventory?? Just a little tip ScottB 86FC35 RUBY 4 sale Murrells Inlet SC "right next to heaven" |
11-24-2006, 12:58
Ernie, they work pretty good..you just gotta be careful and not tear
the non-skid with em.. :>) ScottB 865FC SC --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Scott- so you mean the pair of channel locks I use is not as good as your > nonskid??? > > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] > |
